clutch #1055246
08/18/11 12:56 AM
08/18/11 12:56 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I just lost my trans reverse in my baracuda, i rebuilt it myself and had issues with the front pump seal 2x's. I could just pull it and try to fix it again OR i have a A body 18 spline 4 speed sitting in my garage begging to be used. I have a 8 bolt crank in my motor and no clutch or flywheel. I have a lakewood bellhousing, so im good there, and will be putting in my fenderwell headers so linkage shouod not be an issue, thinking of converting to hydro from a ram.
my question is does anyonje know where i could get a decent 18 spline clutch for under 300. I cant seem to find much more than twin disc setups for over 1000. I cannot afford that.
its a stroker 440 8 bolt like i said- if you have a flywheel or clutch you would like to sell let me know! Or if you just have info on where to buy it i would greatly apprecite it.
Re: clutch [Re: 8urvette] #1055247
08/18/11 08:33 AM
08/18/11 08:33 AM
Netherlands
72Challenger Online content
72Challenger  Online Content
Netherlands
You could try a dual friction Centerforce setup... Don't know the power level etc. but was slightly to weak in my 750hp 3900lbs street / strip ride couple of years back. On the street is was fine but on the strip it start smoking the clutch.
Re: clutch [Re: 72Challenger] #1055248
08/18/11 09:20 AM
08/18/11 09:20 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
Tim is one of the "good guys" in the business, devilvers amazing quality, and is always happy to talk through any questions you may have. If you're thinking of getting a new clutch set up or any type of clutch service give Tim Hyatt a call.
Hyatt Racing Services, Inc.
13429 State Route 86
Painesville, OH 44077
Phone: (440) 254-1311
Re: clutch [Re: 10.90 Racer] #1055249
08/18/11 11:52 AM
08/18/11 11:52 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
so after a ton more research it looks like the only way to get a 4 speed into my car that will hold the TQ of a stroker is to spend big bucks. Which sucks and means the car will be sitting for a while, again...
Re: clutch [Re: 10.90 Racer] #1055250
08/18/11 11:53 AM
08/18/11 11:53 AM
Netherlands
Netherlands
Also, give us some more info here... engine output, power band, gearing, tires, weight etc.
Re: clutch [Re: 72Challenger] #1055251
08/18/11 11:58 AM
08/18/11 11:58 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
68 notchback, 540 10.1 to 1 comp, victor heads that have been cleaned, 1050 dominatior on a victor intake, proparts headers, big solid roller cam, 680 lift 290ish duration, 8 3/4 with 3.23 or 3.91 posi (i have both center chunks) tires are 26 x 10.5 which makes me want to run the 3.23 i think.
Re: clutch [Re: 8urvette] #1055252
08/18/11 11:18 PM
08/18/11 11:18 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
If your going to run a stick then you will need to put a dana or 9" rear in it with good axles. My 8 3/4 lasted 15-20 passes the first time and 7 the last.
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: clutch [Re: gearjammerdart] #1055253
08/19/11 02:17 AM
08/19/11 02:17 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i know i will find my weakest link quickly, and it will most likely be the rear end. but i am working with a dana 60 at the moment. i also do not plan on hard launches. i will be back bracing my rear, to help some, also the small slicks shouldnt create too much traction on ss springs.
Re: clutch [Re: 8urvette] #1055254
08/19/11 06:40 AM
08/19/11 06:40 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I know someone that would be interested in that 18 spline box.
