trw 2295 dome piston's #1054955
08/17/11 08:01 PM
08/17/11 08:01 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
hi guy's rather new here so here's the question. just dropped my pistons off along with the rest of my rotating assembly at the machine shop. do i have to have my rods bushed for the floating pins in my new pistons.
Re: trw 2295 dome piston's [Re: buck440] #1054956
08/17/11 08:05 PM
08/17/11 08:05 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
They can be PRESSED ON also. YERR choice ...
Re: trw 2295 dome piston's [Re: dOoC] #1054957
08/17/11 08:15 PM
08/17/11 08:15 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok say they are pressed on do i still need the pin locks?
Re: trw 2295 dome piston's [Re: buck440] #1054958
08/17/11 08:20 PM
08/17/11 08:20 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
Used these pistons for years and found several times with press fit the wrist pin on a piston or two were binding and had to re-hone the pistons in question.Finally full floated them with bushings and never had it happen again after 100/s of runs on the car.Good Luck
Re: trw 2295 dome piston's [Re: hankcrank] #1054959
08/17/11 08:25 PM
08/17/11 08:25 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
thanks. thats all i needed to hear full float it is
Re: trw 2295 dome piston's [Re: buck440] #1054960
08/17/11 08:28 PM
08/17/11 08:28 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Best way is to float them..Do you have the right locks for them ? they are round wire type.
Re: trw 2295 dome piston's [Re: buck440] #1054961
08/17/11 08:46 PM
08/17/11 08:46 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
When you say full float do you mean bushing the rod small end? I have seen shops hone the rod for a slip fit for the pin then an oil hole in the top (steel on steel). I would NOT recommend this.
Bushing the rods can be costly also. Aftermarket rods may be an option.
Looks like you are beginning a journey.
Re: trw 2295 dome piston's [Re: VernMotor] #1054962
08/17/11 08:48 PM
08/17/11 08:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I wouldnt waste my time floating them... For your application you will only see your wallet lighten.
They use to come with one thick snap ring per side, totally diff from the new spiral type locks.
Compression is also no where near what the adv either...
closer to 9:1 than 11:1
Re: trw 2295 dome piston's [Re: hankcrank] #1054963
08/17/11 09:21 PM
08/17/11 09:21 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
WHY does this happen? ...I have a set of used 383 ones on rods and a couple of them are binding.
Re: trw 2295 dome piston's [Re: AAR-B4] #1054964
08/17/11 09:31 PM
08/17/11 09:31 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
yes exactly i meant bush them. it's not nothing radical just 440 2295's, stealth heads, 564lift cam, torker or victor intake just useing up some parts around the garage. gettin mixed signals now as for cost the machinist owes me a couple bucks
Re: trw 2295 dome piston's [Re: buck440] #1054965
08/17/11 09:36 PM
08/17/11 09:36 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
TOOOO many negs on floating them
The cost .... and the possiblity of breaking or blowing out a lock .. and then THAT damaging the whole motor.
Re: trw 2295 dome piston's [Re: buck440] #1054966
08/17/11 09:48 PM
08/17/11 09:48 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
one of my duster's all aluminum floors,tubs,dash certified 8.50 cage 2700 with iron head 383.
Re: trw 2295 dome piston's [Re: dOoC] #1054967
08/17/11 09:49 PM
08/17/11 09:49 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Bushing the rods should not be big money.
Re: trw 2295 dome piston's [Re: VernMotor] #1054968
08/17/11 09:52 PM
08/17/11 09:52 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
if you had to guess how much?
Re: trw 2295 dome piston's [Re: buck440] #1054969
08/17/11 10:04 PM
08/17/11 10:04 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I just had a set done about 4-5 months ago. I was thinking it was less than 150.00 with the bushings.I see if I can find my receipt.
Re: trw 2295 dome piston's [Re: buck440] #1054970
08/17/11 10:05 PM
08/17/11 10:05 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Slow down..... take 1 step back. stop. Think.
1 what rods are you using onthis build? ly?
do you know the condition of them? did you magnaflux them? rebuild the big ends?
how about new bolts.???
I have used 2295 a long time ago. THEY ARE VER HEAVY. and the pin is heavy
turning 6500 with those iis like turning 7500n with a lighter piston.
eventually .. one of those rods will break.
SO I would recommend an NEW aftermarket rod. they will be brand new , good materials, good bolts and bushed pins and MUCH stronger than stock. For a small expense now, or actually the same once you get done working on the rods you have, you will have something that will last.
Re: trw 2295 dome piston's [Re: bumps440] #1054971
08/17/11 10:16 PM
08/17/11 10:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
agree with this..they was a set of aftermarket rods I had re bushed..long story
Re: trw 2295 dome piston's [Re: VernMotor] #1054972
08/17/11 10:47 PM
08/17/11 10:47 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
turning 6500 with those is like turning 7500n with a lighter piston.
Sorry I cant see spending what $600+ for a new set of rods, and then a re-balance of another $200 for what kind of power gains?
Little to no HP gains.. He still has a heavy rotating assembly in the end too.
Id say his future isn't calling for him to spin this engine much over 6K.
My point I'm trying to make is .. "why take a shower and put back on dirty under wear"
Bushing those rods with those heavy pistons is a waste...
Buying new rods, and running those slugs would be a waste..
Spending $700-$800 for new rods and a re-balance with no power gains is a huge waste.
Those pistons were design to be a cheap alternative to Cast pistons... They were made to be run without a re-balance too.
Im not saying that floating rods isnt worth it... With New rods, and a re-balance yea... But not with those boat anchors.
Re: trw 2295 dome piston's [Re: Bob_Coomer] #1054973
08/17/11 10:56 PM
08/17/11 10:56 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
ok guy's im really gonna make your heart stop with this one. the rods are the extra heavy sixpack rods lol and im not turning more than 6000 to6200 thatsit. just tryn to get back racing rather cheap and like i said the machine work is not costing a thing. i made a trade deal for work. if i can get away with removng the stock piston's and putn those on with out re balance i will do that.
Re: trw 2295 dome piston's [Re: buck440] #1054974
08/17/11 10:59 PM
08/17/11 10:59 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Id say you have the offcial Moparts Time Bomb there..
Im going to my corner now! The other can have this one!
