Hoosier QTP vs. M/T ET Streets? #1054730
08/17/11 01:27 PM
08/17/11 01:27 PM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
In the market for a bias ply cheater slick for my Valiant and debating between Hoosiers and Mickey Thompson. I used to run M/T ET Streets and liked them, but wondering if the Hoosiers hook better, similar or worse. Has anyone run both brands to compare?
I recently wore out my M/T ET Radials at the Nats and I'm finally buying an extra set of rims to run standard street tires for street cruising and then a race specific DOT cheater slick at the track. Therefore expected life of driving them on the street is NOT a concern. Only worried about how they hook and last at the track.
I know a real race slick would be best, but I need to stay with a DOT type tire due to race class.
Car is an automatic and has 1.60 sixty-foot times with my current M/T Radials.
THANKS in advance for the input.
Re: Hoosier QTP vs. M/T ET Streets? [Re: Valiant_Showoff] #1054731
08/17/11 01:31 PM
08/17/11 01:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
M/T ET Streets are basically slicks w/ 2 groves cut in them. The radial ET's are pretty nice and have a stiffer side wall that makes the car drive nicer. I'm running Hoosier Drag radials now and pulled a few 1.60's. Probably can squeeze a little more out of them. I think either would work for your car.
Coming soon!!!!
Re: Hoosier QTP vs. M/T ET Streets? [Re: Valiant_Showoff] #1054732
08/17/11 01:43 PM
08/17/11 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I like the QTP`s better myself............I run the 29x13.5x15`s.
Re: Hoosier QTP vs. M/T ET Streets? [Re: Thumperdart] #1054733
08/17/11 01:58 PM
08/17/11 01:58 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I run the QTP's 28 x 14.50 x 15 and they seem to work really good. I dont have the best 60' at 1.51 but its the car not the tires. They have stiifer sidewalls then the slicks so they seem more stable on the road and on the top end. Alot of people say they hook as good as the slicks but seem to be more stable.
67' charger 499 RB 10.57 at 127
Re: Hoosier QTP vs. M/T ET Streets? [Re: Valiant_Showoff] #1054734
08/17/11 02:44 PM
08/17/11 02:44 PM
Az
Crizila Offline
Crizila  Offline
Az
Tried them both and I liked the Hoosiers better. They seemed to be more consistant and had a better feel to them IMO. The MT's got real gooey when thet got hot and it was difficult for me to tell just how well they were hooking. LOTS more rubber on my white rear fender quarters with the MT's.
Fastest 300
Re: Hoosier QTP vs. M/T ET Streets? [Re: Crizila] #1054735
08/17/11 06:40 PM
08/17/11 06:40 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
QTP's.....BAR NONE!!!!!!!!
Re: Hoosier QTP vs. M/T ET Streets? [Re: MIKES_DUSTER] #1054736
08/17/11 07:56 PM
08/17/11 07:56 PM
maryland
buck440 Offline
buck440  Offline
maryland
i agree had both qtp's hooked my car alot better than the m/t radials 325 50 15 m/t 28 13.50 qtp's
Re: Hoosier QTP vs. M/T ET Streets? [Re: MIKES_DUSTER] #1054737
08/17/11 07:59 PM
08/17/11 07:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I got 3 seasons of street driving m/t sportsman pro's,but they did not hook on my car.I will try the e/t streets 16.5 x 31's
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hoosier QTP vs. M/T ET Streets? [Re: hemi-itis] #1054738
08/17/11 11:49 PM
08/17/11 11:49 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Hate to hijack, but are you guys using tubes or not
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Hoosier QTP vs. M/T ET Streets? [Re: BloFish] #1054739
08/18/11 12:27 AM
08/18/11 12:27 AM
hemi-itis Offline
hemi-itis  Offline
No tubes in the Spoetsman pro's or my slicks.
Re: Hoosier QTP vs. M/T ET Streets? [Re: BloFish] #1054740
08/18/11 12:42 AM
08/18/11 12:42 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have run both, and for me the QTP works a little better and holds air with no tubes. The et streets with no tubes will leak down. If you run et streets make sure you measure the rollout they are not always sold as a matched set!
"Just a Bracket car dressed up like a streetcar"
Re: Hoosier QTP vs. M/T ET Streets? [Re: BloFish] #1054741
08/18/11 12:48 AM
08/18/11 12:48 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No tubes here and they hold pressure pretty well unless my car sits for a few weeks then they MIGHT lose 2-3lbs.
Re: Hoosier QTP vs. M/T ET Streets? [Re: Thumperdart] #1054742
08/18/11 07:49 AM
08/18/11 07:49 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Hooiser QTP here. I have run them with and without tubes....they hook well either way, but I prefer to run them without tubes. No issues holding air, I think the tires lost about a pound when it sat for a month.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Hoosier QTP vs. M/T ET Streets? [Re: FlyFish] #1054743
08/18/11 10:07 AM
08/18/11 10:07 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
No tubes. I soaped the inside of mine and they hold air all winter long!
Re: Hoosier QTP vs. M/T ET Streets? [Re: dragram440] #1054744
08/18/11 10:58 AM
08/18/11 10:58 AM
Az
Crizila Offline
Crizila  Offline
Az
I run tubes in my QTP's. I think they recommend tubes.
Fastest 300
Re: Hoosier QTP vs. M/T ET Streets? [Re: Crizila] #1054745
08/18/11 11:06 AM
08/18/11 11:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No tubes in my ET streets... they've held the same
pressure in the shop(on the car for MONTHS)... according
to M/T the set I have (295/65-15) dont require tubes
Re: Hoosier QTP vs. M/T ET Streets? [Re: MR_P_BODY] #1054746
08/18/11 02:02 PM
08/18/11 02:02 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I had tubes in mine and the hoosier salesman in BIR told me not to run tubes. I had him pull em out.
Re: Hoosier QTP vs. M/T ET Streets? [Re: dragram440] #1054747
08/18/11 03:40 PM
08/18/11 03:40 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Are you guys running the QTPs on the street? How do they wear and drive on the street?
thanks
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: Hoosier QTP vs. M/T ET Streets? [Re: 65signet] #1054748
08/18/11 04:37 PM
08/18/11 04:37 PM
Alliance, Ohio
V
V
Alliance, Ohio
Hoosier recommends tubes with the Quick Time Pros, but it sounds like many are running them without. Am I reading this right?
Re: Hoosier QTP vs. M/T ET Streets? [Re: Valiant_Showoff] #1054749
08/18/11 04:46 PM
08/18/11 04:46 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That's how I am reading it. When I get a new set, I may try them without the tubes.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
