Re: Hoosier QTP vs. M/T ET Streets?
[Re: Thumperdart]
#1054733
08/17/11 01:58 PM
08/17/11 01:58 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I run the QTP's 28 x 14.50 x 15 and they seem to work really good. I dont have the best 60' at 1.51 but its the car not the tires. They have stiifer sidewalls then the slicks so they seem more stable on the road and on the top end. Alot of people say they hook as good as the slicks but seem to be more stable.
67' charger 499 RB
10.57 at 127
[Re: Valiant_Showoff]
#1054734
08/17/11 02:44 PM
08/17/11 02:44 PM
Posts: 7,506 Az
Crizila
Az
Tried them both and I liked the Hoosiers better. They seemed to be more consistant and had a better feel to them IMO. The MT's got real gooey when thet got hot and it was difficult for me to tell just how well they were hooking. LOTS more rubber on my white rear fender quarters with the MT's.
Fastest 300
[Re: BloFish]
#1054740
08/18/11 12:42 AM
08/18/11 12:42 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have run both, and for me the QTP works a little better and holds air with no tubes. The et streets with no tubes will leak down. If you run et streets make sure you measure the rollout they are not always sold as a matched set!
"Just a Bracket car dressed up like a streetcar"
[Re: Thumperdart]
#1054742
08/18/11 07:49 AM
08/18/11 07:49 AM
Posts: 1,178 Indy
FlyFish
Indy
Hooiser QTP here. I have run them with and without tubes....they hook well either way, but I prefer to run them without tubes. No issues holding air, I think the tires lost about a pound when it sat for a month.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1054743
08/18/11 10:07 AM
08/18/11 10:07 AM
dragram440
bigfork mn
No tubes. I soaped the inside of mine and they hold air all winter long!
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1054744
08/18/11 10:58 AM
08/18/11 10:58 AM
Posts: 7,506 Az
Crizila
Az
I run tubes in my QTP's. I think they recommend tubes.
Fastest 300
[Re: Crizila]
#1054745
08/18/11 11:06 AM
08/18/11 11:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
No tubes in my ET streets... they've held the same pressure in the shop(on the car for MONTHS)... according to M/T the set I have (295/65-15) dont require tubes
[Re: MR_P_BODY]
#1054746
08/18/11 02:02 PM
08/18/11 02:02 PM
dragram440
bigfork mn
I had tubes in mine and the hoosier salesman in BIR told me not to run tubes. I had him pull em out.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1054747
08/18/11 03:40 PM
08/18/11 03:40 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Are you guys running the QTPs on the street? How do they wear and drive on the street?
thanks
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
#1054749
08/18/11 04:46 PM
08/18/11 04:46 PM
Posts: 16,450 On the run…
BloFish
On the run…
That's how I am reading it. When I get a new set, I may try them without the tubes.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
