Re: 1/2 alum fuel line without a bender? [Re: POS Dakota] #1054580
08/18/11 10:04 AM
08/18/11 10:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Scratch'n, that's fine for the street but it won't pass tech. There can't be any fuel components mounted on the firewall in line with the flywheel/converter area - I think it has to be 6" in front (or behind). They don't want brake lines run across the firewall (over top the bellhousing area), either. Not trying to nit-pick - just a heads up to anyone who is going to try to pass tech.
What about fuel line? Is there a requirement for what line to run and where it's to be put as it passes the flywheel area?
You can run the fuel line across that area IF you
put the line in a steel tube... I forget what thickness
the steel has to be.... either 1/8 wall or 1/4"
BUT they wont pass with the regulator on the firewall...
must be 6" forward of it
Re: 1/2 alum fuel line without a bender? [Re: MR_P_BODY] #1054581
08/18/11 12:48 PM
08/18/11 12:48 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Thank You. Mine will be largely street driven, but I am going to the track occasionally too. I dont want to be told to take a hike when I have a lot of money in various SFI parts already.
Re: 1/2 alum fuel line without a bender? [Re: POS Dakota] #1054582
08/19/11 04:47 PM
08/19/11 04:47 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
well a water pump pulley is the smallest thing ihad that would not kink
dont know if would pass tech but its gonna get routed in same place the factory i took off was
except im not gonna try to route in the torsion bar crossmember like factory did
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
