1/2 alum fuel line without a bender?
#1054560
08/17/11 02:18 AM
08/17/11 02:18 AM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
bought a roll of 1/2 alum fuel line but my bender only goes up to 3/8 really wasnt looking to buy a bender for just one time use ever use anything else like a small pulley or anything with any luck?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 1/2 alum fuel line without a bender?
[Re: Thumperdart]
#1054563
08/17/11 06:18 AM
08/17/11 06:18 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Bent mine by hand and when I needed a descent bend, I put a length of extension cord inside w/lube, bent to desired shape and pulled out the cord. Chase each piece/section w/a good cleaner and compressed air and done.
clever...I would have thought the extension cord would have got stuck in there as the ID of the line got smaller on the bend. Ever pull 25 pair phone cables out of an old conduit? lol I was doing chin-ups off it. LOL
I initially bought braided line to run from my cell, but I am slowly thinking I should run a hard line and that's good info.
Topless' idea of bending it around a v groove pulley would probably also work too though within reason. I know it can be done. I like the extension cord idea too though.
[Re: POS Dakota]
#1054564
08/17/11 07:27 AM
08/17/11 07:27 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
That cord deal sounds like a great idea.
I found years ago that the fittings is where the most money is spent. Braided line is so much easier and the line itself is not that expensive.
That is just a decision you have to make for yourself. But, you cannot run alluminum line outside the confines of the frame or inside the frame in the driveline area. I think on UNIBODY cars the rocker is considered part of your frame as long as it is complete. You may want to ask a NHRA tech guy to be sure.
Leon
[Re: toplescuda]
#1054565
08/17/11 08:35 AM
08/17/11 08:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You can fill it with sand and it'll bend easy...fill it and crimp over the ends then when done cut the ends off and clean it
[Re: PorkyPig]
#1054568
08/17/11 11:06 AM
08/17/11 11:06 AM
Posts: 15,487 Florida
scratchnfotraction
I did mine by hand and used a fat propane bottle to make a loop of 3-4 coils at the ends for future repairs. v-groove pully works good also i used a a couple diff size pvc pipe pieces to make smaller bend in the 1/2 alum line. I ran alum from pump up towards the reg and then went back to braided line,so everything you see is braided and the supply and return line down the frame is alum line,i also used the foam insulation for the home a/c lines on the hard lines down the frame then straped them together and to the frame. very cheap and may help keep the fuel cool and alum for chaffing on the frame. heres what the vent line looks like around the fatt propane bottle
[Re: scratchnfotraction]
#1054569
08/17/11 12:10 PM
08/17/11 12:10 PM
POS Dakota
detroit, mi
I knew perfect looking coils like that couldnt have possibly been done with a tubing bender...there's another good tip. I have 2 vents in my aeromotive stealth cell and I wante dto do this. I may do it today as a matter of fact now that I got some good pointers.
So the aluminum bends that easy around te bottle?
[Re: Leon441]
#1054570
08/17/11 12:14 PM
08/17/11 12:14 PM
POS Dakota
detroit, mi
Leon
yeah man! I have a lot of money sitting here in fittings. I didnt know that about the aluminum line in the driveline area. That being the case, I guess, I'll make coils for my vents like scratch'n did out of aluminum and run my -10 and -8 returns in braided. I already have it, but depending on who you ask they say it's better to run a hard line.
But I'll check on rules...
[Re: PorkyPig]
#1054572
08/17/11 03:22 PM
08/17/11 03:22 PM
Posts: 16,928 NC
440Jim
NC
I picked up something from a hardware store years ago that works. Its a set of external coils in different sizes (1/2, 3/8) that you slide over the fuel line to keep the line from crimping when bending by hand.
I have used that too. Just don't get crazy trying to bend too sharp.
[Re: dOoC]
#1054573
08/17/11 03:54 PM
08/17/11 03:54 PM
Challenger 1
Cincinnati, Ohio
A little side-bar Q ... how does this alky blended fuel affect the alum line?
Very good point...
[Re: Challenger 1]
#1054574
08/17/11 04:31 PM
08/17/11 04:31 PM
scratchnfotraction
or the inside of the alum fuel cell its soft alum tubing,you do have to work it kinda slow but can be done by hand..i did have a buddy help hold the can. I had the line all the way to the reg,flared both ends and used the flare nuts,then went back and cut it back down under the firewall and used a hardline comp fitting to braid line. I was gonna poke the vent line down thru the bed to vent under it...but with short pipes I thought I best not and made that coil set up with a flare nut. gonna get one of those mini cone breathers for it on the open end ther is another coil on the return line under the truck below where the line comes up thru the bed.
#1054575
08/17/11 05:15 PM
08/17/11 05:15 PM
POS Dakota
detroit, mi
Why the coil on the return line? Cooling? Service loop? I am considering running my return line though one of those double-pass extruded heatsink coolers for that purpose.
[Re: POS Dakota]
#1054576
08/17/11 05:50 PM
08/17/11 05:50 PM
scratchnfotraction
service more than anything,i used the foam a/c insulation to help keep it cool. I am going to run a cool can up under the hood later on and just use ice to cool it just before the reg & carb. i ran a 1/2 feed to the filter/pump with a 3/8 return and a restrictor in the line so it is not free flowing back to the cell. from what I have read this will help the pump stay cool by moveing a lot of fuel for street duty. just have to plumb it in the feed to the reg and pack with ice
[Re: Evil Spirit]
#1054578
08/18/11 12:58 AM
08/18/11 12:58 AM
POS Dakota
detroit, mi
Scratch'n, that's fine for the street but it won't pass tech. There can't be any fuel components mounted on the firewall in line with the flywheel/converter area - I think it has to be 6" in front (or behind). They don't want brake lines run across the firewall (over top the bellhousing area), either. Not trying to nit-pick - just a heads up to anyone who is going to try to pass tech.
What about fuel line? Is there a requirement for what line to run and where it's to be put as it passes the flywheel area?
[Re: Evil Spirit]
#1054579
08/18/11 09:22 AM
08/18/11 09:22 AM
scratchnfotraction
very good point
I am not going to the track with mine it is street/show duty only
I will be moveing it over to the inner fender when i plumb a cool can in.
[Re: MR_P_BODY]
#1054581
08/18/11 12:48 PM
08/18/11 12:48 PM
POS Dakota
detroit, mi
You can run the fuel line across that area IF you put the line in a steel tube... I forget what thickness the steel has to be.... either 1/8 wall or 1/4" BUT they wont pass with the regulator on the firewall... must be 6" forward of it
Thank You. Mine will be largely street driven, but I am going to the track occasionally too. I dont want to be told to take a hike when I have a lot of money in various SFI parts already.
[Re: POS Dakota]
#1054582
08/19/11 04:47 PM
08/19/11 04:47 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
well a water pump pulley is the smallest thing ihad that would not kink dont know if would pass tech but its gonna get routed in same place the factory i took off was except im not gonna try to route in the torsion bar crossmember like factory did
