Re: Alternate Antenna ideas?
[Re: Kern Dog]
#1053196
08/15/11 11:50 AM
08/15/11 11:50 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Cut & paste.. A Ground Plane is a flat surface of ferrous metal (galvanized, steel, etc) that a Magnet Mount or Body Mount antenna uses as an integrated part of it. For a Body mount antenna other metals may be used as it does not have a magnet that needs to stick to it. A Metal Car Body is a ground plane. The metal top of a refrigerator is a ground plane. A filing cabinet is a good ground plane. A tin roof is a Ground Plane. A ground plane can be a cookie sheet! A ground plane is NOT a metal roof gutter, a window frame, a downspout or any other piece of metal that is long and thin. A ground plane MUST satisfy BOTH length and width dimensions outlined below. Antenna gains are calculated with an infinite ground plane. Performance can be achieved with the minimums outlined below. Just as long as it is big enough: for Dual Band/800 MHz/Nextel = 14" x 14" Minimum (28" x 28" recommended) for 1900 MHz only = 6" x 6" minimum (12" x 12" recommended) A Ground Plane does not need to be electrically grounded. It simply needs to be a plane of metal. Your local hardware store sells galvanized roof flashing for cheap that can be used as a ground plane. Please note, the antenna should be mounted in the CENTER of the ground plane for a circular pattern. I've talked to many street rod owners with hidden antennas & none of them rave about the reception, they work but not very well... The ones that mount behind the windshield rather than in the headliner get better reception & the Hirschmann seems to be the best.... I wound up putting an amplified short (16" Hirschman Fuba) in the roof of my Falcon wagon since there was already a hole there from a CB antenna..
[Re: Kern Dog]
#1053197
08/15/11 01:47 PM
08/15/11 01:47 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Grove Enterprises in Brasstown NC used to manufacture and sell an antenna that was embedded in a clear length of tape and could be attached to either front or back window, but I just checked their online catalog and it is no longer there. They might make one on special request: http://www.grove-ent.com/widefrequencycoverageantennas.htmlto avoid the ground plane requirement you could make a simple FM band 'coaxial dipole' antenna at the end of a length of coax and mount that behind the grille, at the top back window, or below the rear bumper. This would still pick up reasonably good AM band, maybe better than an standard 28 inch quarter wave 'Marconi' antenna. http://en.wikipedia.org/wiki/Coaxial_antennamy experience with alternative hidden vehicle antennas was with a wide band antenna hidden underneath a ARE fiberglass tonneau bed cover on a Ram pickup... which worked great over a wide spread of frequencies. The official FCC cars hunting un-licensed radio transmitters (Pirate FM) have four hidden antennas that are still very effective.
[Re: 360view]
#1053199
08/15/11 02:54 PM
08/15/11 02:54 PM
Posts: 1,822 Colorado
denfireguy
Colorado
To see what you are up against for AM radio, the diagram shows the antenna rod to be 1/4 wavelength. At 850khz in the middle of the AM band, 1/4 wavelenghth is 290 feet! That is why AM radios in cars were usually more sensitive but still did not hear terribly well, buzzed under powerlines, etc. Windshield antennas worked even worse, so much so, the National Association of Broadcasters wanted them banned from new car manufacturing at one time. All AM antennas on a car are a compromise. A windshield antenna is a worse compromise since it will be directional, favoring where the car is pointed and shielded on three sides. FM is another story, 1/4 is about 30 inches, the length of the non adjustable antennas on 70s Mopars and most cars with fender mounted antennas today. It is much easier to hide an FM antenna and while the windshield is not ideal, it will work better than AM Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 360view]
#1053205
08/15/11 06:42 PM
08/15/11 06:42 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The reviews of "Universal Antenna Hideaway' by previous buyers are not encouraging:
Maybe you should have read more than just the first two !!!
There will always be whiners. Look at it this way, if you want to elininate the mast then your options are limited and you should be prepared to give up something in return.
[Re: Stanton]
#1053206
08/15/11 07:36 PM
08/15/11 07:36 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Can't you find an old magnetic mast and stick it sideways in the trunk beneath the back glass?
[Re: Kern Dog]
#1053209
08/15/11 09:46 PM
08/15/11 09:46 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
What about a hidden power antenna? I've seen them on Street Rods but have no idea how well they work. When down, you would only see the small tip of the antenna. File it to match the contour of the fender and paint it body color and it will pretty much disappear to the casual observer. All mounting hardware is under the fender. I couldn't find a picture of it on a Street Rod, but, did find a kit: antenna .
John
