Alternate Antenna ideas? #1053193
08/15/11 01:03 AM
08/15/11 01:03 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I'm working on a 72 Duster project. The owner and I decided to shave the side marker holes along with the trunk lock. We're also adding in a flip top gas cap, set in to sit nearly flush. Now I'm considering filling in the stock antenna hole in the right fender. IF I do this, what are the options for an alternate antenna? GM cars used windshield antennas for years, which got me wondering if there were other places to hide one. Can one be fashioned BEHIND the windshield trim and still be functional? What about behind the grille? I'm looking for a way to have it hidden yet still provide decent reception.
Ideas, anyone?
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053194
08/15/11 02:00 AM
08/15/11 02:00 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Unless designed specifically without one, the antenna needs a ground plane to get good reception. Tim
Re: Alternate Antenna ideas? [Re: astjp2] #1053195
08/15/11 04:06 AM
08/15/11 04:06 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Hey, I spell well but I certainly can't claim to understand everything! Care to explain what "Ground plane" means!!?
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053196
08/15/11 11:50 AM
08/15/11 11:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Cut & paste..
A Ground Plane is a flat surface of ferrous metal (galvanized, steel, etc) that a Magnet Mount or Body Mount antenna uses as an integrated part of it. For a Body mount antenna other metals may be used as it does not have a magnet that needs to stick to it.
A Metal Car Body is a ground plane.
The metal top of a refrigerator is a ground plane.
A filing cabinet is a good ground plane.
A tin roof is a Ground Plane.
A ground plane can be a cookie sheet!
A ground plane is NOT a metal roof gutter, a window frame, a downspout or any other piece of metal that is long and thin.
A ground plane MUST satisfy BOTH length and width dimensions outlined below. Antenna gains are calculated with an infinite ground plane. Performance can be achieved with the minimums outlined below.
Just as long as it is big enough:
for Dual Band/800 MHz/Nextel = 14" x 14" Minimum (28" x 28" recommended)
for 1900 MHz only = 6" x 6" minimum (12" x 12" recommended)
A Ground Plane does not need to be electrically grounded. It simply needs to be a plane of metal.
Your local hardware store sells galvanized roof flashing for cheap that can be used as a ground plane.
Please note, the antenna should be mounted in the CENTER of the ground plane for a circular pattern.
I've talked to many street rod owners with hidden antennas & none of them rave about the reception, they work but not very well... The ones that mount behind the windshield rather than in the headliner get better reception & the Hirschmann seems to be the best.... I wound up putting an amplified short (16" Hirschman Fuba) in the roof of my Falcon wagon since there was already a hole there from a CB antenna..
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053197
08/15/11 01:47 PM
08/15/11 01:47 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Grove Enterprises in Brasstown NC used to manufacture and sell an antenna that was embedded in a clear length of tape and could be attached to either front or back window,
but I just checked their online catalog and it is no longer there.
They might make one on special request:
http://www.grove-ent.com/widefrequencycoverageantennas.html
to avoid the ground plane requirement
you could make a simple FM band
'coaxial dipole'
antenna at the end of a length of coax and mount that
behind the grille,
at the top back window,
or below the rear bumper.
This would still pick up reasonably good AM band, maybe better than an standard 28 inch quarter wave 'Marconi' antenna.
http://en.wikipedia.org/wiki/Coaxial_antenna
my experience with alternative hidden vehicle antennas
was with a wide band antenna hidden underneath a ARE fiberglass tonneau bed cover on a Ram pickup... which worked great over a wide spread of frequencies.
The official FCC cars hunting un-licensed radio transmitters (Pirate FM) have four hidden antennas that are still very effective.
Re: Alternate Antenna ideas? [Re: 360view] #1053198
08/15/11 01:59 PM
08/15/11 01:59 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Years ago we had an antenna under a car; it ran lengthways, secured at its base and with a small clamp at its end to keep it tucked up. Reception was OK for the stronger stations but not as good as OEM.
The easy way out for you might be a power-retracting antenna, especially if it could be hidden in a body gap so that when it's retracted it disappears...
Re: Alternate Antenna ideas? [Re: 360view] #1053199
08/15/11 02:54 PM
08/15/11 02:54 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
'coaxial dipole'
behind the grille,
To see what you are up against for AM radio, the diagram shows the antenna rod to be 1/4 wavelength. At 850khz in the middle of the AM band, 1/4 wavelenghth is 290 feet! That is why AM radios in cars were usually more sensitive but still did not hear terribly well, buzzed under powerlines, etc. Windshield antennas worked even worse, so much so, the National Association of Broadcasters wanted them banned from new car manufacturing at one time.
All AM antennas on a car are a compromise. A windshield antenna is a worse compromise since it will be directional, favoring where the car is pointed and shielded on three sides.
FM is another story, 1/4 is about 30 inches, the length of the non adjustable antennas on 70s Mopars and most cars with fender mounted antennas today. It is much easier to hide an FM antenna and while the windshield is not ideal, it will work better than AM
Craig
Re: Alternate Antenna ideas? [Re: denfireguy] #1053200
08/15/11 03:18 PM
08/15/11 03:18 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Wow, thats a lot of smarts jammed into a short post. After reading these posts I feel like I just looked inside the human brain! I feel dumber than when I started!
Re: Alternate Antenna ideas? [Re: denfireguy] #1053201
08/15/11 03:32 PM
08/15/11 03:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Screw all that techno mumble-jumble, just buy one of these:
http://www.crutchfield.com/p_12044UA20/Universal-Antenna.html?search=antenna&tp=3449
Re: Alternate Antenna ideas? [Re: Stanton] #1053202
08/15/11 05:22 PM
08/15/11 05:22 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Hmmm.
Simple and interesting. Thanks.
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053203
08/15/11 06:10 PM
08/15/11 06:10 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
I've heard of a trunk lid being used as an antenna. No ideas on the technical aspects of how it can be done. I'm not positive, but I think the Japanese built Dodge Challengers of the late 1970's had these from the factory. I have NO idea how well this worked.
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053204
08/15/11 06:26 PM
08/15/11 06:26 PM
USA
3
360view Offline
360view  Offline
3
USA
The reviews of
"Universal Antenna Hideaway'
by previous buyers are not encouraging:
http://www.crutchfield.com/p_12044UA20/U...mp;rvm=ShowAllt
Electrically isolating a metal body part
like the trunk lid
can can work about as well as a 28 inch whip on the AM band,
but it won't be anywhere near 'resonance' for the FM band, although you still may be able to pick up the stronger stations.
Another replacement antenna with slightly better reviews:
http://www.amazon.com/Scosche-Windshield...howViewpoints=1
Re: Alternate Antenna ideas? [Re: 360view] #1053205
08/15/11 06:42 PM
08/15/11 06:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The reviews of
Maybe you should have read more than just the first two !!!
There will always be whiners. Look at it this way, if you want to elininate the mast then your options are limited and you should be prepared to give up something in return.
Re: Alternate Antenna ideas? [Re: Stanton] #1053206
08/15/11 07:36 PM
08/15/11 07:36 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Can't you find an old magnetic mast and stick it sideways in the trunk beneath the back glass?
- Stu Harmon
Re: Alternate Antenna ideas? [Re: feets] #1053207
08/15/11 09:25 PM
08/15/11 09:25 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Hey, I'll consider all ideas. Thanks for everything guys.
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053208
08/15/11 09:43 PM
08/15/11 09:43 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Similar subject came up awhile back. Check out this thread:
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=6752745&Main=6752462
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053209
08/15/11 09:46 PM
08/15/11 09:46 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
What about a hidden power antenna? I've seen them on Street Rods but have no idea how well they work. When down, you would only see the small tip of the antenna. File it to match the contour of the fender and paint it body color and it will pretty much disappear to the casual observer. All mounting hardware is under the fender.
I couldn't find a picture of it on a Street Rod, but, did find a kit: antenna .
John
Re: Alternate Antenna ideas? [Re: SattyNoCar] #1053210
08/15/11 10:20 PM
08/15/11 10:20 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I think I just read in car craft or hotrod that some new special edition camaro has the antenna inside the rear spoiler...if the duster doesn't have a rear spoiler, that might be a problem.
Re: Alternate Antenna ideas? [Re: Pool Fixer] #1053211
08/16/11 12:35 AM
08/16/11 12:35 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
We have no plans to install a rear spoiler, though that is a great idea.
Re: Alternate Antenna ideas? [Re: Kern Dog] #1053212
08/16/11 08:56 AM
08/16/11 08:56 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I've been a radio guy for most of my life. For the best performance you need the antenna out in the clear as far away from metal as you can get. All the hidden antennas are a poor compromise to the stock fender mounted antenna. The hidden power antenna is a good way to go.
