Temperature spike after shut off on a new motor?
#1053092
08/14/11 10:35 PM
08/14/11 10:35 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
My 440 has less than 500 miles on it and I was just curious to see what's normal for temperature spike after shut off.
Thanks for your time.
Moparlee
Re: Temperature spike after shut off on a new motor?
[Re: Robbins]
#1053094
08/14/11 10:45 PM
08/14/11 10:45 PM
Posts: 15,487 Florida
scratchnfotraction
they will do that. mine is about 20*-30* increase at shut down from a 40 mile run,maybe less in the winter. I just added a 7 blade thrmo clutch fan to my BB in the 88 truck,it would climb past 190*-200* idleing for a long time with the 5 blade,it now stays right at 180* or just under. has about 10*-20* increase now
[Re: scratchnfotraction]
#1053095
08/15/11 12:23 AM
08/15/11 12:23 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Iron heads? It's normal
The cast iron will hold heat, once it's shut off, that heat soaks into the water. Aluminum heads help to reduce this as they dissipate heat into the water faster, and won't "hold heat".
As long as the temps drop again once you start it and get the water flowing, then you don't have a problem. Only way to remedy the issue is to get an electric water pump and fan to continue the cooling after the engine is shut off, but going all electric cooling isn't needed on the street
**Photobucket sucks**
[Re: 70Cuda383]
#1053096
08/15/11 07:15 PM
08/15/11 07:15 PM
Robbins
Joplin, MO USA
Thanks guys I appreciate the feed back. I've got the live temp and guage on the dash also that I'm looking at also using the new temp gun from Amazon........Raytek(a fluke company)AutoPro gun. I was checking things out on it too.
It crawls up towing also, and once driving also. Not real bad, just thinking of going with the help of an electric fan, maybe in the shroud like my 2002 Dakota has.
Moparlee
[Re: Robbins]
#1053097
08/16/11 11:01 AM
08/16/11 11:01 AM
Posts: 230 Long Island, New York
Tony H
Just was playing with Thermoststs and E- fans last night on a new engine install. I shut off the engine, I left the E fans running. As the engine spiked about 15 degrees ( about 3 minutes after shutoff) I started it back up for about 5 seconds. The much cooler fan from the radiator was pumped into the Motor. Temp came down imediatley. I think this will be my shut down ritual in the future.
'75 CJ5 with all glass body and a 350 Chevy SB '85 Chevy Stepside (the wife's) '89 Volvo All 100% maintained by me. '70 valiant DD for my son '74 Dart Swinger..Latest endeavor http://home.lyse.net/brox/TonyPage4.html
