single field to double field alternator. #1052604
08/14/11 09:46 AM
08/14/11 09:46 AM
Long Island, New York
Tony H Offline OP
Tony H  Offline OP
Can I simply get a waffle alternator and add the additional green wire. Then buy the double field regulator? 'original' Blue and 'new' green get soldered to new style connector and black wire on Single field regulator goes to third pin on new style connector?
Is that all it would take? single pulley 45 amp single field alternators are not easy to find. Not to mention; I am running Electric fuel pump,electric fans and a high output electronic ignition on a '68 Cuda
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
Re: single field to double field alternator. [Re: Tony H] #1052605
08/14/11 10:15 AM
08/14/11 10:15 AM
Extend/Run the orig blue (ign1) wire to either alt field terminal & T into it back at the firewall & run that to the top terminal of the flat VR triangle w it facing up like a pyramid. then run the orig green wire from the other alt field terminal to the side terminal in the VR triangle. You can trim the sides of a flat VR & it will nestle neatly into the squarish firewall recess where the "box" VR once resided. clean the back a bit for a good VR to firewall ground & you're set EDIT I think there's a listing for a 70's or 80's M body that has an 78 amp alt. If you want to retain the single pulley an alt shop can switch them or slightly adj the spacing on the double pulley one to line it up
Re: single field to double field alternator. [Re: RapidRobert] #1052606
08/14/11 11:34 AM
08/14/11 11:34 AM
IN
ahy Offline
ahy  Offline
IN
From the archives... about 3/4 of the way down is a diagram.
http://www.moparts.org/Tech/Archive/elec/24.html
Re: single field to double field alternator. [Re: ahy] #1052607
08/14/11 03:05 PM
08/14/11 03:05 PM
Tony H Offline OP
Tony H  Offline OP
Thanks All. I tried searching and came up blank.
then I found this http://www.imperialclub.com/Repair/Electrical/charging.htm
Is it true the archives only go back 1 year? I have some good info from this site saved in my favorites but now when I click on them .. they don't exist.
'89 Volvo
Re: single field to double field alternator. [Re: Tony H] #1052608
08/14/11 03:43 PM
08/14/11 03:43 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: single field to double field alternator. [Re: Tony H] #1052609
08/14/11 06:00 PM
08/14/11 06:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I just run as is and ground the one field.
Re: single field to double field alternator. [Re: Dodgem] #1052610
08/14/11 06:30 PM
08/14/11 06:30 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
With the kind of electrical load you're showing there, I'd do more than just an alternator upgrade. Even a 78 amp dual field alternator will be too much for the stock wiring harness and ammeter. You'll want to do a MAD Electrical style bypass with some 10 gauge or better yet 8 gauge wire from the alternator to the starter relay. ( http://www.madelectrical.com/electricaltech/amp-gauges.shtml )
IMHO, do the bypass and install one of these babys:
12SI delco...get one of these in 94A...I did some really easy bracket modifications to install it. I have the 78 amp version and my volt meter is so rock solid you'd be amazed. No dimming at idle with everything on (I don't have an electric fuel pump or fan). I used a 78 amp mopar alternator before and it was great as long as it was above idle...but at idle, it was bad.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
