Clutch fan spacing? how close is too close #1052172
08/13/11 05:20 PM
08/13/11 05:20 PM
SINY
SanityLost Offline OP
SINY
Rule of thumb is usually a 1/2" of clearance between the clutch on the fan and the Radiator, right?
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052173
08/13/11 05:25 PM
08/13/11 05:25 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Correct, assuming the motor and trans mounts are in good shape and not letting the drivetrain move around too much...I've had closer and got away with it but I've also seen disasters reguarding the rad and fan trying to occupy the same space... The fan shroud is really the determining factor with how much/little spacing you need...Rule of thumb on that is blades half in/out the opening for optimum operation...
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052174
08/13/11 11:40 PM
08/13/11 11:40 PM
I always thought the closer the better (within reason) till a guy (on here) awhile back made a good case 4 too close disrupting the airflow, something about close fin/fan proximity disrupting the airflow boundary. I believe a good shaped (correct one for the vehicle) shroud is a far better way 2 go (fan ~2/3 in) but yes w no shroud it needs to b fairly close EDIT iirc he suggested 3/4"
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052175
08/13/11 11:57 PM
08/13/11 11:57 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
1/2" from what? The tank?The core? This is very vague and not something that can be answered. 1/2" fore and aft is MUCH different from horizontal movement. Just guessing based on this info,NO you don't have enough.
Re: Clutch fan spacing? how close is too close [Re: goldmember] #1052176
08/14/11 04:22 AM
08/14/11 04:22 AM
Australia
Charger VJ RB Offline
Australia
My stock 318 had 1.5 inch clearance. Rad core to tip of fan.
RB XE274H Q-850
Re: Clutch fan spacing? how close is too close [Re: goldmember] #1052177
08/14/11 09:11 AM
08/14/11 09:11 AM
SINY
SINY
Ummm, the core...
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052178
08/14/11 12:04 PM
08/14/11 12:04 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Do you have a shroud? If so, then you want the blades about halfway into the shroud. Ever see the shroud on a 70's Monte Carlo? Looks like a 50 gallon drum with the ends cut off. Your not going to put the fan 1/2" away from the core in that case. Need more info on what you have.
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052179
08/14/11 12:16 PM
08/14/11 12:16 PM
Kirkland, Washington
Pacnorthcuda Offline
Ummm, the core...
I would consider 1/2" to be the MINIMUM. And you need to make sure your measuring at the closest spot--often the plane of the core isn't perfectly parallel with the plane of the fan.
A STIFF fan is better than one with a bit of flex in this case as high RPMs will try to make the blades reach forward a bit, couple that variable with chassis and engine movement and things can happen. But---if you put the car through the paces and the radiator is not contacted, you are probably ok.
Re: Clutch fan spacing? how close is too close [Re: Pacnorthcuda] #1052180
08/14/11 01:02 PM
08/14/11 01:02 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
The MP viscous fan package put the clutch pretty much 1/2" away from the core...just enough to sneak a belt by it.
I am running a shorter clutch now from what I believe was a '72 400 with the max cool option. This still keeps the fan in the shroud pretty much half way but moves the clutch out about 1" from the core (safer distance for me)
I have heard of others running a clutch for a Jaguar with good results as well..
1MYTGTX
Re: Clutch fan spacing? how close is too close [Re: 1MYTGTX] #1052181
08/14/11 01:04 PM
08/14/11 01:04 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
This is the clutch I am using.
The 1" I get is with a recored 055 that is now a 3 core radiator
Using the stock '69 max cool 2863216 7 blade fan
1MYTGTX
Re: Clutch fan spacing? how close is too close [Re: 1MYTGTX] #1052182
08/14/11 02:28 PM
08/14/11 02:28 PM
SINY
SINY
Just kicking the idea around of running a different fan in my Dart. I have a 440 in there and I'm running an aluminum HOWE rad with a modified ford shroud.
I have been running a flex fan for about 15 years now and was just thinking of possibly changing it out for something different, WHY?.... boredom I guess.
I have a 7 blade fan off a 72 440 sitting around and I thought hmmm maybe I should try this, well after measuring The fan from the mounting base to the front of the clutch its 3".
If I was to mount the assembly, the clutch would be about 1/4" away from the CORE and pretty far into the shroud.
I read somewhere about the Jaguar type setup and some guys swear by them others not. Anyone have some measurements on the Jaguar type?
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052183
08/14/11 03:24 PM
08/14/11 03:24 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
A few topics here...
http://www.dodgecharger.com/forum/index.php/topic,52932.0.html
Hayden 2765 or NAPA 261306
1MYTGTX
Re: Clutch fan spacing? how close is too close [Re: 1MYTGTX] #1052184
08/14/11 04:34 PM
08/14/11 04:34 PM
SINY
SINY
Thanks Chris
Re: Clutch fan spacing? how close is too close [Re: SanityLost] #1052185
08/14/11 04:54 PM
08/14/11 04:54 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
...jag unit (XJ6) is about 2.6 high
.. any body try one?
..i just ordered one from summit..so i'm gonna' find out the hard way.
