Oil filter inspection #1051790
08/12/11 10:50 PM
08/12/11 10:50 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Any recommendation on how to cut open an oil filter canister for inspection without contaminating the filter with shavings??
Re: Oil filter inspection [Re: PolyDart] #1051791
08/12/11 11:03 PM
08/12/11 11:03 PM
There are a bunch of different oil filter cutters out there You have to remember(or know ) how a oil filter works so you won't be worreid about the shavings from the cutter confusing you when you inspect them I cut the top off of the canister and then cut the element loose form the center core(both ends ) and then split it longways in the middle, unroll it and look very closely in all of the pleats as well as the rest of the filter Mopar oil pumps make the oil flow through the filter from the outside edges into the pleated paper and then exit into the center of the oil filter before being pump into the motor Most of the oil filter cutters I have seen and used are like a pipe cutter, very little debris from cutting the filter canister open Buy one and use it always on every oil filter change
Re: Oil filter inspection [Re: Cab_Burge] #1051792
08/12/11 11:16 PM
08/12/11 11:16 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Thanks, I appreciate the info
Re: Oil filter inspection [Re: PolyDart] #1051793
08/12/11 11:21 PM
08/12/11 11:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
ALL filters inter on the outside and exit through the
center... reason why... more surface area to collect
the trash
EDIT
Best way is to get a filter cutting tool(Summit) and
like Cab said cut the one end off and lay it out flat
and eye ball it closely
Re: Oil filter inspection [Re: PolyDart] #1051794
08/14/11 05:55 PM
08/14/11 05:55 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
i use a system 1 reusable filter. you take it apart, inspect it, clean it and reinstll it. it's the last filter you will ever buy! you can get it @ JEGS part #888-209-512561.
Re: Oil filter inspection [Re: blracing] #1051795
08/14/11 06:15 PM
08/14/11 06:15 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
To the guys who cut apart your filters .... do you also have a magnet in the pan ? ...and how often do you drop-the-pan to inspect?
Re: Oil filter inspection [Re: blracing] #1051796
08/14/11 06:45 PM
08/14/11 06:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That's how it should be done.
Re: Oil filter inspection [Re: camastomcat] #1051797
08/14/11 07:12 PM
08/14/11 07:12 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Doesn't JCW have one of these too ? ...
