Summit Racing - Turbo Action Trans - Who's bought one? #1051588
08/12/11 04:51 PM
08/12/11 04:51 PM
Middle River, MD
Mapandjlp Offline OP
Middle River, MD
Anyone have any experience with this transmission? Looking at one for my mild 360...
http://www.summitracing.com/parts/TAC-19201L/
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Mapandjlp] #1051589
08/12/11 08:11 PM
08/12/11 08:11 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Excellent product.
Nautilus Racing-
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Chris2581] #1051590
08/12/11 09:13 PM
08/12/11 09:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Alum drum for a mild street car with a 904. Sounds like overkill to me.
TA makes good stuff. If you were closer there's a guy here that would build you a SOLID 904 for less than 1/2 that price.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: RobX4406] #1051591
08/13/11 10:22 AM
08/13/11 10:22 AM
Middle River, MD
Middle River, MD
Overkill? I hadn't even condisdered that. Here's the cheaper one at Summit. It's only rated to 300HP. I'm guessing I'm close to that number, maybe even a tad over. Plus the TA unit has the lower first gearset...
http://www.summitracing.com/parts/TCI-111338/
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Mapandjlp] #1051592
08/13/11 11:49 AM
08/13/11 11:49 AM
places
79powerwagon Offline
places
You probably don't want TCI (as it's know around here as Total Crap Incorporated). But why would you want to spend that kind of coin for a transmission?
What's wrong with the one you have?
What are you trying to built that requires such a specific 1st gear ratio?
Why not just build your own? They're EASY!!!!!
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: RobX4406] #1051593
08/13/11 01:26 PM
08/13/11 01:26 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
You don't want or need an alum drum in a street car. That is an all out race part.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Dabee] #1051594
08/13/11 02:42 PM
08/13/11 02:42 PM
RobX4406 Offline
RobX4406  Offline
Agreed
Find out who the local racers use for there stuff if you don't want to do it yourself. They are VERY easy to rebuild.
Get a good transtar kit from one of the trans house distributors (bulkpart, makco) and a tf-2 kit and your ready to roll. Parts are usually about $200ish.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: RobX4406] #1051595
08/13/11 02:50 PM
08/13/11 02:50 PM
Middle River, MD
Middle River, MD
I've done a couple of 727s in the past, so I'm sure I could get the job done. I was just being lazy, I guess. Maybe I'll give it a shot. Can you guys suggest a rebuild kit for the trans and good shift kit for the valve body?
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Mapandjlp] #1051596
08/13/11 03:07 PM
08/13/11 03:07 PM
RobX4406 Offline
RobX4406  Offline
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Mapandjlp] #1051597
08/14/11 12:57 AM
08/14/11 12:57 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Give John Cope at CRT a call (He is a sponsor here) tell him what the trans is going to be used for and he will set you up with the correct parts for your application.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: Dabee] #1051598
08/14/11 01:10 AM
08/14/11 01:10 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Until you make enough HP to run 10's you do not need much and the 727/904 is easy to build yourself and save the $$ for other things.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: goldmember] #1051599
08/14/11 09:34 AM
08/14/11 09:34 AM
Northern IL
meathead66 Offline
meathead66  Offline
Northern IL
Also try Kieth. He did me good.
http://www.727specialist.com/
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: meathead66] #1051600
08/14/11 06:11 PM
08/14/11 06:11 PM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Give ATI a call. They are in Baltimore, MD.
http://www.atiracing.com/
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: MadMax58] #1051601
08/14/11 11:07 PM
08/14/11 11:07 PM
New Jersey
69Chrgr Offline
69Chrgr  Offline
New Jersey
Call Frank Lupo at Dynamic converters, hes been doin chrysler stuff for 30 years.
Re: Summit Racing - Turbo Action Trans - Who's bought one? [Re: 69Chrgr] #1051602
08/15/11 12:34 AM
08/15/11 12:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It states "clutch hub" = aluminum.... not direct drum, besides ANYONE who's priced an aluminum drum for a torqueflight knows that the price of an alloy drum is pretty close to the price of that entire trans. Personally, I don't think a $1000 "trans in a box" is a bad deal. Can you build one cheaper....duh! Of course you can, but I bet this one bolt and go knowing TA's history.
CRT web site shows a "stock" 904 at close to $700, the next one up the line good for "500hp on the street" for $1450. Call me crazy, but neither of these prices sound bad to me either, and once again, you can pretty much bet you take it out, install it, and go.... no fuss, no muss!
