Coolant Leak from the back of 318 -- Freeze Plugs? #105066
08/14/08 10:18 PM
08/14/08 10:18 PM
Anonymous OP
Anonymous OP
My 72 Satellite Starting leaking from what appears to be below the back of the Driver's side head. Possibly a freeze plug. 127,000 original miles. If it is the freeze plug, what are my possible solutions? How easy to get them out?
Help.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? #105067
08/15/08 07:28 AM
08/15/08 07:28 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I am pretty sure there is a freeze plug in the back of the head , look at your passenger side head behind the altenator, that's what the back of the other head looks like.
The rear bolt on the exh manifold goes into the water passage also and can be a possible leak point if it's been messed with .
Or its the head gasket if the leak is truly at the deck surface .
Re: Coolant Leak from the back of 318 -- Freeze Plugs? #105068
08/15/08 07:48 AM
08/15/08 07:48 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Help.
Not easy at all to get to. If it is the freeze plug then you should figire on taking the whole motor out and replace all of them, becAUSE THEY WILL BE ALL READY TO FAIL AT THIS POINT IN TIME. Easy to replace once the motor is out. Sorry for the caps. There are freeze plugs on the back of the motor too. Those are ones that leaked on my motor and all of mine were paper thin when I replaced them.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: Challenger 1] #105069
08/15/08 07:50 AM
08/15/08 07:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Help.
Not easy at all to get to. If it is the freeze plug then you should figire on taking the whole motor out and replace all of them, becAUSE THEY WILL BE ALL READY TO FAIL AT THIS POINT IN TIME. Easy to relace once the motors out. Sorry for the caps.
especially the 2 between the engine and trans .
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: JohnRR] #105070
08/15/08 08:50 AM
08/15/08 08:50 AM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
Ive seen many small block Mopars and the freeze plugs weep/leak in the back of the motor where the tranny bellhousing area is and I've replaced them - that is common. I've only replaced one head gasket freeze plug in my life!
If you're sure its a head freeze plug for sure (use a mirror), you can always pull the one head to save some work. It may be years before the others start to leak...
Personally, pulling the motor is alot of work. No one can tell you when the others will leak. They all don't rust out at the same rate - I've seen motors where one freeze plug was leaking and all the others were good upon removal of them all.
Good luck
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: Fastfrankie] #105071
08/15/08 09:52 AM
08/15/08 09:52 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
More often if one is leaking the rest are not far behind. I would pull the engine and replace them all. If they have never been replaced there will be a lot of mud and crap lodged behind them. Do yourself a favor and do it right.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? #105072
08/15/08 10:06 AM
08/15/08 10:06 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's really all original, I'd find the means to pull it out, replace all the plugs, valve stem seals, and for sure the plastic timing gear and chain set too.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: buildanother] #105073
08/15/08 11:05 AM
08/15/08 11:05 AM
Cincinnati, Ohio
Cincinnati, Ohio
127K miles... the plastic timing gear does need a replacement too.
I took mine out on a Sat morning and put it back in on Sun and was driving it Sun nite. Knowsnothing is right, I found all kinds of gunk in the water jackets that I pressure washed out. Cleaned out my oil pan while I was at it. It's easier to remove tranny and motor at the same time. I also put a new front seal in my tranny while I was at it.
I built this motor in 1986 and installed steel freeze plugs at that time. So it took about twenty years for them to rust out. This time I replaced them with brass, so hopefully it and me will be around for another twenty years.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: Challenger 1] #105074
08/15/08 11:32 AM
08/15/08 11:32 AM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
I've posted this before,so I'll keep it short. You can pm me for more information.
We removed and replaced all the head freeze plugs from my Super Bee, and we only pulled the exhaust manifolds.
It can be done, and it's not that tough. We used a pipe clamp with a modified end. The pipe clamp is the length of the head. One end has the standard crank to tighten and loosen the thing. The modified end is a flat disk with a bolt attached to it.
1) install clamp to head with bolt pushing against the old freeze plug
2) tighten clamp until bolt pushes freeze plu 90 degrees
3) remove old freeze plug
4)center new freeze plug in hole.
5)replace the bolt on the clamp with a small socket. Install clamp so socket is centered inside the cup of the new freeze plug
6) tighten clamp, making sure plug goes in straight.
Viola! We had them in and out within 15 minutes.
*1969 383 4sp. Super Bee
*1966 Alfa Romeo Giulia Sprint GT
*1965 Porsche 356C
*2004 VW Passat Wagon
*2004 Mini Cooper S
*1967 Jaguar E-Type FHC
A mall cop is in our midst.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: new bee] #105075
08/15/08 12:10 PM
08/15/08 12:10 PM
dogdays Offline
dogdays  Offline
It's spelled, "v-o-i-l-a". Origin is something like the French words for "see" and "that". A viola is a stringed instrument and possibly a type of flower.
Nonetheless the use of the pipe clamp (took me a while to figure out that you mean a clamp made with a length of pipe, commonly used for cabinet work) is a really clever idea and I congratulate you. It's an idea that I will keep handy for future use.
R.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: dogdays] #105076
08/15/08 12:21 PM
08/15/08 12:21 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
oops...spelling!
Me flunk english? Thats unpossible!
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: new bee] #105077
08/15/08 12:52 PM
08/15/08 12:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
Great Idea!
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: Challenger 1] #105078
08/15/08 01:29 PM
08/15/08 01:29 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Great info. Can someone post a picture of this pipe clamp tool possibly from ebay or an internet supplier?? Thanks
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: UCUDANT] #105079
08/15/08 03:27 PM
08/15/08 03:27 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
Harbor freight has the stuff you will need to make one. I will try to get a photo of it online soon.
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: new bee] #105080
08/15/08 04:07 PM
08/15/08 04:07 PM
md
mopars4ever Offline
mopars4ever  Offline
md
What happens if you push the freeze plug into the head? How do you remove it? Mike
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: mopars4ever] #105081
08/15/08 04:43 PM
08/15/08 04:43 PM
portland or
new bee Offline
Richard Cranium
new bee  Offline
Richard Cranium
portland or
My experience is that you can get your fingers in there enough to rotate the thing, and work it out. I had two on the sides of the heads drop in, and I was able to carefully slide them up, turn them, and pull them out.
Needle nose pliers are useful as well.
*1965 Porsche 356C
*2004 Mini Cooper S
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: new bee] #105082
08/15/08 04:46 PM
08/15/08 04:46 PM
dogdays Offline
dogdays  Offline
picture attached
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: mopars4ever] #105083
08/15/08 05:52 PM
08/15/08 05:52 PM
Upper Midwest
Upper Midwest
Nothing, It won't go anyplace.
If it were mine I would pull the engine and do it right and not worry anymore about it. I would also install a timing chain and gears, pull the pan and check the bearings at that milage. Not that big a job to pull the engine out of there. Couple of hours max. including a beer break.
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: MoparforLife] #105084
08/15/08 07:33 PM
08/15/08 07:33 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Coolant Leak from the back of 318 -- Freeze Plugs? [Re: JohnRR] #105085
08/15/08 08:18 PM
08/15/08 08:18 PM
Upper Midwest
Upper Midwest
Just look at the heads. The other end is the same, They don't know front from back or left from right.
