Question for Body Guys: Bubbling at Seams? #104999
08/14/08 08:32 PM
08/14/08 08:32 PM
California
dg_dodge Offline OP
dg_dodge  Offline OP
California
Hey Guys,
I always thought this patch of bubbles right below the door jamb on my Bee was rust. I showed it to body guy yesterday. He thinks it might not be rust, but instead it is (brass?) seams that are bubbling up... (I didn't quite understand what this meant..).
Anyway, he said this would be a little better news than if it was rust -- which would require a metal patch. It sounded like this one could just be ground down?
Have you guys ever experienced bubbles right here and how did you end up dealing with it?
Thanks!
Re: Question for Body Guys: Bubbling at Seams? [Re: dg_dodge] #105000
08/14/08 08:37 PM
08/14/08 08:37 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
If it is not rust. It is getting moisture under the paint.
I would say grind it down and put a coat of fiberglass to seal the metal.
Then you can refinish it.
Re: Question for Body Guys: Bubbling at Seams? [Re: cyphre666] #105001
08/14/08 08:42 PM
08/14/08 08:42 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
There is a leaded joint in that spot. Lead doesn't rust, but can fall off. I'd take the paint off and keep digging until you get to the cause.
I have a feeling you will need to replace the area with lead or weld it solid and grind it flush.
Re: Question for Body Guys: Bubbling at Seams? [Re: dg_dodge] #105002
08/14/08 08:47 PM
08/14/08 08:47 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
my car has the same thing on one side...
Re: Question for Body Guys: Bubbling at Seams? [Re: dg_dodge] #105003
08/14/08 09:30 PM
08/14/08 09:30 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
Like Neil said that is a solder sealed seam (say that three times fast) heat it up and use a putty knife or wire brush to clean that stuff off don't sand or grind it or you'll be making potholders before you know it..
Re: Question for Body Guys: Bubbling at Seams? [Re: dg_dodge] #105004
08/14/08 09:56 PM
08/14/08 09:56 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Hey Guys,
Thanks!
Assuming it's original metal in that area, most likely it's either filler turning loose that someone wiped on top of the lead joint, or rust under the lead, pushing it outward. Filler will give some when pushed.
I've seen both in the past. If you are willing, stick the tip of a pocket knife into it and pick the paint off. If it's soft and silver, you have rust under it.
Steve
www.clarkclassic.com
Re: Question for Body Guys: Bubbling at Seams? [Re: dg_dodge] #105005
08/15/08 02:48 AM
08/15/08 02:48 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
But isn't the bottom line here is water/moisture is somehow getting thru or behind the paint to/thru the metal, and if that is not stopped any repair will only be temporary?
Re: Question for Body Guys: Bubbling at Seams? [Re: jcc] #105006
08/15/08 07:53 AM
08/15/08 07:53 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Pretty much the same amount of work no matter what the cause by what I'm seeing.
It'll have to go to bare clean metal and address what is or isn't there.
On the original seam it was leaded over an open spot welded lap joint. In harsh exposure over time moisture finds it's way through the seam under the lead and creates rust.
Best way to fix it(IMHO), is to remove the factory lead, clean up any rust, weld the seam solid, then re-lead it.
In this case you may even find hole(s) in the underlying metal that will require a metalpatch.
Rick
Re: Question for Body Guys: Bubbling at Seams? [Re: jcc] #105007
08/15/08 10:14 AM
08/15/08 10:14 AM
Greenville, N.C.
Greenville, N.C.
Moisture (rain, washing car) gets there by way of the 1/4 window. It gets past the window sweep and runs down into the 1/4. That's why the factory formed drain openings in the lower 1/4 pinch welds.
