can some one measure a 440 crank for me #1049938
08/09/11 01:21 PM
08/09/11 01:21 PM
madison, ohio
modified1090 Offline OP
madison, ohio
does any one have a 440 crank laying around with the timing gear on it that the can measure for me? i need the distance from the snout of the crank to the top of the timing gear.
Re: can some one measure a 440 crank for me [Re: modified1090] #1049939
08/09/11 02:09 PM
08/09/11 02:09 PM
Which type of timing gear do you want measured, stock, Cloyes True roller or? Do you want the gear measured or part of the crankshaft?
Re: can some one measure a 440 crank for me [Re: Cab_Burge] #1049940
08/09/11 02:31 PM
08/09/11 02:31 PM
madison, ohio
madison, ohio
i just have a double roller cloyes i need from the top of the gear to the end of the crank
Re: can some one measure a 440 crank for me [Re: modified1090] #1049941
08/09/11 07:25 PM
08/09/11 07:25 PM
from the inside edge of the gear to the top of the teeth is .694 to .696. The measurement from the inside edge of the gear that rides on the crankshaft to the bottom of the groove in between the teeth is right at .595 using a set of dial calipers These measurements are from a stock Mopar street hemi double roller crankshaft timing gear, not a Cloyse True roller crank gear,I don't have a Cloyes in stock, sorry IHTHs
Re: can some one measure a 440 crank for me [Re: modified1090] #1049942
08/09/11 09:18 PM
08/09/11 09:18 PM
NC
440Jim Offline
440Jim  Offline
NC
Sometimes a picture is worth a thousand words.
Is this the dimension you are looking for?
I came up with 1.767" +/-
Re: can some one measure a 440 crank for me [Re: 440Jim] #1049943
08/10/11 10:33 AM
08/10/11 10:33 AM
madison, ohio
madison, ohio
yep thats it! thank you. i know what the hub length is on my balancer. with this i can measure the installed balancer and know if it is all the way on or not.
much thanks!
