Removing Undercoating #1049897
08/09/11 12:50 PM
08/09/11 12:50 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Has anyone ever used the Eastwood undercoating remover? Is it any good/worth the price?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Removing Undercoating [Re: Erik] #1049898
08/09/11 01:12 PM
08/09/11 01:12 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
A heat gun and paint thinner works well.
Heat up the undercoating with the heat gun and scrap it off with a putty knife, you don't need a lot of heat to soften the undercoating. Once the you have the bulk of it scrapped off and the surface is cool, use paint thinner and a rag to remove whats left.
Re: Removing Undercoating [Re: sixpackbird] #1049899
08/09/11 01:56 PM
08/09/11 01:56 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Gary(Challenger 1) should be along shortly to show you his prefered method of undercoating removal. Pretty slick.
Re: Removing Undercoating [Re: Erik] #1049900
08/09/11 02:21 PM
08/09/11 02:21 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hello,
No I have never used it before. Is it flamable? Must not be the more I think about it. Didn't go to Eastwood yet to read about it.
How much do you want to remove and is the car on a rotissierie?
Re: Removing Undercoating [Re: burdar] #1049901
08/09/11 02:22 PM
08/09/11 02:22 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
They should do a reality show about this job. If you aren't doing it on a rotisserie, that job makes the crab fishermen look like a bunch of pusssies.
MB
Re: Removing Undercoating [Re: HPMike] #1049902
08/09/11 02:23 PM
08/09/11 02:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
MB
Re: Removing Undercoating [Re: Challenger 1] #1049903
08/09/11 03:59 PM
08/09/11 03:59 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Hello,
I want to remove it all. Yes, the car is now on a rotisserie. I wasn't about to be on my back srcaping that stuff off!
Re: Removing Undercoating [Re: Erik] #1049904
08/09/11 04:47 PM
08/09/11 04:47 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Be careful getting the old undercoating on bare skin when you're all sweaty. There's something in it that can cause a sever, long-lasting rash once it's embedded in your pores. PCB's?
Had a buddy that looked like he was boiled in oil for about 6 months. I've gotten a patch or two from it, but it wasn't nearly as bad as my friend's reaction to it.
Re: Removing Undercoating [Re: jbc426] #1049905
08/09/11 05:02 PM
08/09/11 05:02 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Didn't know that. Thanks! Long gloves!!!!
Re: Removing Undercoating [Re: Challenger 1] #1049906
08/09/11 05:53 PM
08/09/11 05:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
MB
I'm guessing we are laughing because we all did that job on our backs at one time or another. God did that suck.
Re: Removing Undercoating [Re: Morty426] #1049907
08/09/11 05:59 PM
08/09/11 05:59 PM
Propane torch and putty knife!
My 12 year-old son actually "got into it" and liked doing the last fender...
Oh yeah, I ran the blue flame while he scraped.
Re: Removing Undercoating #1049908
08/09/11 06:36 PM
08/09/11 06:36 PM
Home of the Dream Cruise
FPD031 Offline
FPD031  Offline
And get your wife to do it for you!
Re: Removing Undercoating [Re: FPD031] #1049909
08/10/11 11:49 PM
08/10/11 11:49 PM
New Jersey
W
Wild_Hemi Offline
Wild_Hemi  Offline
W
New Jersey
Eastwood Undercoating remover product does not work on traditional under coating.
Re: Removing Undercoating [Re: Erik] #1049910
08/11/11 12:57 PM
08/11/11 12:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
I removed all the undercoating, road tar and dirt from the bottem of my car in 3 1/2 hours with out even touching my car. Not one scratch or gouge mark anywhere. One afternoon and I was done.
Used a steam pressure washer with a little gasoline in a sprayer to soften the tuff stuff.
I've done it now on several cars and many trucks over the years.
It's worth the trouble/cost to rent a steam pressure washer for this job, imo.
I have been lucky to own several of these pressure washers that we use to maintain a small fleet of tanker trucks.
before
after same afternoon.
I removed all the seam sealer from the inside of the car also with it.
Re: Removing Undercoating [Re: Challenger 1] #1049911
08/11/11 01:22 PM
08/11/11 01:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
The pressurized container that I sprayed the gas with to soften the tuff undercoating that didn't come off the first pass.
The pressure washer. I was able to stand up, breath no fumes or dust, no open flame, no gouge marks, no skinned up hands and it was done in just few hours.
Now standing there with 1500 PSI ,4+gpm at 200 degree temp point blank for 3-4 hours is not real easy, but the job was done in one afternoon and only had to clean up once. And the less than 2 gallons of gas I used evaporated before it got to my grass, so it didn't cause any enviromental issues. I swept up the heavy undercoating off the driveway with a shovel and used my pressure washer to clean my driveway. 3 times now at home and still have a real nice yard with grass.
Oh yea,I used it to remove the repaint on the car that I'm drilling out the spot welds so I can see better before drilling in the picture below.
Here's the doors on my gold 71,
Used the same pressure washer to remove all paint from them. It'll remove any repaint leaving the original paint pretty much intack.
Did a hell of job on these fenders.
Bottem of my 71 before blasting and repaint after undercoating removal.
Re: Removing Undercoating [Re: Erik] #1049912
08/11/11 02:14 PM
08/11/11 02:14 PM
Denver
E
Explodo Offline
Explodo  Offline
E
Denver
You can also use one of those oscillating tools with the scraper blade. They make it pretty easy for getting the bulk of it off.
'67 440 Satellite
Re: Removing Undercoating [Re: Explodo] #1049913
08/11/11 03:43 PM
08/11/11 03:43 PM
Nebraska
Dodge-N-Shelby Offline
Nebraska
I wanted the undercoating removed from under my 55 Chevy BelAir. I have a Media Blasting setup and used Baking Soda to remove a 12" square area in a half hour, it just seemed to 'melt' and roll the stuff up like gum. I opened a bag of Grit-O-Cob, ground corncob. I ended up with the same results as what Challenger1 ended up in about the same amount of time (3-4 hours). But his process would be an easier and cheaper one for just anyone to do. My process worked great for me because I have the blaster, compressor, and access to cob, whereas I would have had to go out and rent a steamcleaner. Just more options to throw out there.
Re: Removing Undercoating [Re: Dodge-N-Shelby] #1049914
08/11/11 04:29 PM
08/11/11 04:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
Many ways to do it.
I like pressure washing first before media blasting because it allows me a very light media blast to get the metal bare and I'm not blasting grease and oil into the metal. I use less media too which makes cleanup easier.
I have been media blasting for like 25 years.
Re: Removing Undercoating [Re: Challenger 1] #1049915
08/11/11 05:03 PM
08/11/11 05:03 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've seen pics of it pressure washed that you posted before, my question is: how much did the equipment needed to do this cost? It does clean it very nice. I always went with a propane torch and scraper. Another issue is I have yet to scrape one that was that clean. I always have cars that have parts that had flaked off and rust... so I had to blast them after anyways and I would blast them anyways to have a good start for epoxy and needed body work.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Removing Undercoating [Re: Silver70] #1049916
08/11/11 06:37 PM
08/11/11 06:37 PM
Nebraska
Nebraska
If I read it right, Challenger1 may do some lite media blasting after its been steam/pressure washed. I like his method, especially for DIYers because of the fact that its sooooo less messy than trying to clean up all that old undercoating and media from your yard. I am lucky enough to have commercial blasting equipment and lots of outdoor area that I could just run a tractor blade over to level off and leave my mess. Also, when I did mine with cob, I hit it at about a 30 degree angle and mine flaked off in chunks because it was so dry. I'm sure that if my undercoating was still somewhat soft, it may have been a different story.
