440 head gaskets #1049833
08/09/11 11:15 AM
08/09/11 11:15 AM
Arizona
68CoronetRT Offline OP
Arizona
I am trying to settle on a head gasket set for my car. 11:1 compression, zero deck, .040 over TRW flat top pistons with 915 heads that will be a street car.
Read all the posts I could find and for a .039" compression height (trying for quench here) it seems some are recommending the Felpro Marine Gaskets others insist on Cometic but the prices are quite high for my budget.
Not sure if I need the fire ring style gaskets for this or if they are good insurance?
Any help/suggestions would be appreciated.
Re: 440 head gaskets [Re: 68CoronetRT] #1049834
08/09/11 11:18 AM
08/09/11 11:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Go with the Fel pro
Re: 440 head gaskets [Re: 68CoronetRT] #1049835
08/09/11 11:19 AM
08/09/11 11:19 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run the Marines on my 12.5 440 with Stealths.Put my old reworked 516s on the 62 300 with the 1009s.My 440 will clatter a bit under heavy pull with 93 octane.The 300 runs on it just fine.Rocky
Chrysler Firepower
Re: 440 head gaskets [Re: 68CoronetRT] #1049836
08/09/11 11:40 AM
08/09/11 11:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think a zero deck 440 w/ 915's would be a tad high thant 11:1 even with fel-pro's.
That said Fel-Pros.
Coming soon!!!!
Re: 440 head gaskets [Re: Mr.Yuck] #1049837
08/09/11 01:47 PM
08/09/11 01:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That said Fel-Pros.
How can you say that with the info he posted ?
I just ran the numbers assuming .040 overbore , 5cc valve reliefs, 80 cc heads and a 4.410/.039 gasket and get 10.55 , if the heads are 76 it's only 10.97.
Re: 440 head gaskets [Re: Mr.Yuck] #1049838
08/09/11 02:04 PM
08/09/11 02:04 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Toss a bit more camshaft at it if the worry is dynamic compression...
I would love those numbers in a street car...
CrAzYMoPaRGuY
Re: 440 head gaskets [Re: JohnRR] #1049839
08/09/11 02:17 PM
08/09/11 02:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That said Fel-Pros.
I was thinking they'd be closer to 76cc. not 80.
Re: 440 head gaskets [Re: Mr.Yuck] #1049840
08/09/11 03:04 PM
08/09/11 03:04 PM
Arizona
Arizona
Planning to use a Hughes cam and springs at present (haven't purchased a cam yet.)
Here's what I am looking at:
HEH3237BL
110 LSA
Intake/exhaust duration @ .050 232/237
Lift with 1.6 roller rockers: .576/.584
I'll go ahead and order the Felpro Marine Gaskets part #17059.
I really appreciate the help.
BTW this is all for the car in my sig.
Re: 440 head gaskets [Re: Mr.Yuck] #1049841
08/09/11 04:03 PM
08/09/11 04:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That said Fel-Pros.
They are over 80 stock , the set I have are 81
Re: 440 head gaskets [Re: JohnRR] #1049842
08/10/11 09:51 AM
08/10/11 09:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That said Fel-Pros.
Mine must have been milled a bunch because they were 74. I though stock 906's were 84?
Re: 440 head gaskets [Re: Mr.Yuck] #1049843
08/10/11 11:38 AM
08/10/11 11:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That said Fel-Pros.
yours were milled a bunch , 906's are 90-92cc factory fresh
Re: 440 head gaskets [Re: JohnRR] #1049844
08/10/11 11:47 AM
08/10/11 11:47 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
A good way to "guesstimate" the amount of milling is to measure the outside head bolt boss. Stock it is very close to 1.00 inch.
Re: 440 head gaskets [Re: marvo451] #1049845
08/10/11 11:57 AM
08/10/11 11:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had worked 516's
Re: 440 head gaskets [Re: marvo451] #1049846
08/10/11 12:03 PM
08/10/11 12:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
CC em and find out for SURE where they are...........I wouldn`t want to "estimate" my ring end gap.
Re: 440 head gaskets [Re: Mr.Yuck] #1049847
08/10/11 03:08 PM
08/10/11 03:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I had worked 516's
but the OP has 915's and they were also milled a bunch , as stated above , measure the head bolt boss under the exh ports , factory is 1.00
Re: 440 head gaskets [Re: JohnRR] #1049848
08/10/11 03:24 PM
08/10/11 03:24 PM
Arizona
Arizona
I had worked 516's
I will do that and CC them as well. May be a couple of days before I post the results.
Re: 440 head gaskets [Re: 68CoronetRT] #1049849
08/10/11 10:51 PM
08/10/11 10:51 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
HEH3237BL
110 LSA
i'm using the HEH3742BL which is one up from the cam you picked, i'm running 1.5 ratio. very nice cam, i like it a lot. not super serious with my racing. i have a '74 challenger, 11:1 440, indy E-Z heads. 4 speed 3.73 gears on 28" drag radials. it usually runs 11.6 to 11.8 @ 118mph. probably could do better with the ET
Re: 440 head gaskets [Re: 68CoronetRT] #1049850
08/10/11 11:54 PM
08/10/11 11:54 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Here`s what i did run on a 446 with a 150 shot and run 6.0s all day long Mr gasket #7115 it was a kit $43.99 they was 28" thick but with my 572 i run COMETIC 41" thick they are $100.00 a ea. But FEL PRO #1009 makes a 39" thick for $41.99 ea . hope this helps good luck.
Re: 440 head gaskets [Re: steeldust] #1049851
08/13/11 10:39 PM
08/13/11 10:39 PM
Arizona
Arizona
I purchased the Fel-Pro Marine Gaskets #17059 after a mental struggle over the Mr. Gasket #5784.
Hope to have the CC number on the heads by Wednesday.
Re: 440 head gaskets [Re: 68CoronetRT] #1049852
08/15/11 04:07 PM
08/15/11 04:07 PM
Arizona
Arizona
78 cc on the combustion chambers which I believe means they were only cleaned up not milled. Mopar Muscle article says the 915 heads were 78.5 cc stock. My stock 906s were about 88 cc IIRC.
