Re: 440 head gaskets
[Re: 68CoronetRT]
#1049835
08/09/11 11:19 AM
08/09/11 11:19 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
I run the Marines on my 12.5 440 with Stealths.Put my old reworked 516s on the 62 300 with the 1009s.My 440 will clatter a bit under heavy pull with 93 octane.The 300 runs on it just fine.Rocky
Chrysler Firepower
[Re: Mr.Yuck]
#1049837
08/09/11 01:47 PM
08/09/11 01:47 PM
Posts: 75,016 U.S.S.A.
JohnRR
U.S.S.A.
I'd think a zero deck 440 w/ 915's would be a tad high thant 11:1 even with fel-pro's. That said Fel-Pros.
How can you say that with the info he posted ?
I just ran the numbers assuming .040 overbore , 5cc valve reliefs, 80 cc heads and a 4.410/.039 gasket and get 10.55 , if the heads are 76 it's only 10.97.
[Re: Mr.Yuck]
#1049838
08/09/11 02:04 PM
08/09/11 02:04 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Toss a bit more camshaft at it if the worry is dynamic compression... I would love those numbers in a street car...
CrAzYMoPaRGuY
[Re: JohnRR]
#1049839
08/09/11 02:17 PM
08/09/11 02:17 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I was thinking they'd be closer to 76cc. not 80.
[Re: Mr.Yuck]
#1049841
08/09/11 04:03 PM
08/09/11 04:03 PM
JohnRR
U.S.S.A.
They are over 80 stock , the set I have are 81
[Re: JohnRR]
#1049842
08/10/11 09:51 AM
08/10/11 09:51 AM
Mr.Yuck
Brookeville, Md
Mine must have been milled a bunch because they were 74. I though stock 906's were 84?
[Re: Mr.Yuck]
#1049843
08/10/11 11:38 AM
08/10/11 11:38 AM
JohnRR
U.S.S.A.
yours were milled a bunch , 906's are 90-92cc factory fresh
[Re: Mr.Yuck]
#1049847
08/10/11 03:08 PM
08/10/11 03:08 PM
JohnRR
U.S.S.A.
I had worked 516's
but the OP has 915's and they were also milled a bunch , as stated above , measure the head bolt boss under the exh ports , factory is 1.00
[Re: JohnRR]
#1049848
08/10/11 03:24 PM
08/10/11 03:24 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
I had worked 516's
I will do that and CC them as well. May be a couple of days before I post the results.
[Re: 68CoronetRT]
#1049849
08/10/11 10:51 PM
08/10/11 10:51 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
Planning to use a Hughes cam and springs at present (haven't purchased a cam yet.) Here's what I am looking at:
HEH3237BL
110 LSA Intake/exhaust duration @ .050 232/237 Lift with 1.6 roller rockers: .576/.584
I'll go ahead and order the Felpro Marine Gaskets part #17059.
I really appreciate the help. BTW this is all for the car in my sig.
i'm using the HEH3742BL which is one up from the cam you picked, i'm running 1.5 ratio. very nice cam, i like it a lot. not super serious with my racing. i have a '74 challenger, 11:1 440, indy E-Z heads. 4 speed 3.73 gears on 28" drag radials. it usually runs 11.6 to 11.8 @ 118mph. probably could do better with the ET
[Re: 68CoronetRT]
#1049850
08/10/11 11:54 PM
08/10/11 11:54 PM
Posts: 469 Tennessee
steeldust
Tennessee
I am trying to settle on a head gasket set for my car. 11:1 compression, zero deck, .040 over TRW flat top pistons with 915 heads that will be a street car. Read all the posts I could find and for a .039" compression height (trying for quench here) it seems some are recommending the Felpro Marine Gaskets others insist on Cometic but the prices are quite high for my budget. Not sure if I need the fire ring style gaskets for this or if they are good insurance?
Any help/suggestions would be appreciated.
Here`s what i did run on a 446 with a 150 shot and run 6.0s all day long Mr gasket #7115 it was a kit $43.99 they was 28" thick but with my 572 i run COMETIC 41" thick they are $100.00 a ea. But FEL PRO #1009 makes a 39" thick for $41.99 ea . hope this helps good luck.
