Re: Fuel Pump Location
[Re: Viol8r]
#1049775
08/10/11 01:43 PM
08/10/11 01:43 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Talk to Weldon Pumps. Just put one of their in line A600-A on my car...self priming and sooo quiet. You can mount it horizontal, vertical, anyway you want.
that's a sweet looking pump but waaay to rich for my blood! i'll stick to my noisy Carter and crank up the tunes!
[Re: mikemee1331]
#1049776
08/10/11 01:48 PM
08/10/11 01:48 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
I hear ya...not cheap. Until I went to EFI, I ran the Mallory 140 pump. Also very quiet.
[Re: Viol8r]
#1049777
08/10/11 04:48 PM
08/10/11 04:48 PM
Posts: 2,256 IL
furious70
IL
unless the pump is designed to be a puller, it will live longer being gravity fed plane and simple.
I put the efi pump on my fury in the rear torque box area, OEM fuel line ran right through there and was a nice cubby to put it
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#1049778
08/10/11 09:28 PM
08/10/11 09:28 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I pulled my 2 EFI pumps from a Mercedes S500, they were mounted in a rubber suspended box behind the rear axle, like a fuel pump scrodum....and I doubt you can hear those running. If you run Holley style loud pumps, mount them from those rubber insulators and use short rubber sections of fuel line to and from to keep their vibrations from your chassis, and keep them at or lower than the fuel level line.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
