any "break in" oil recommendations ? #1049696
08/09/11 12:19 AM
08/09/11 12:19 AM
oregon
savoyracer Offline OP
oregon
Putting a new engine in the car, 523" roller cam, etc. was wondering if there is an off the shelf oil, that is better for engines during the initial break in period? And how long to leave the breakin oil in the engine? Will be using Mobil One 20-50 Synthetic after the first oil change. Also this motor will be race only, so looking for the best break in procedure?
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049697
08/09/11 12:43 AM
08/09/11 12:43 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I use BRAD PEN OIL 10w-40 it`s the green oil if your motor is clean break it in on same oil you are going to use and run it a race or two then change it but on my 572 i run it 3 warm ups and change it before i raced but on my motors i did have in the car i run 5w-30 GTX good luck.
Re: any "break in" oil recommendations ? [Re: steeldust] #1049698
08/09/11 12:58 AM
08/09/11 12:58 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I bought the Lucas break in oil.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049699
08/09/11 01:20 AM
08/09/11 01:20 AM
oregon
oregon
Thanks guys! I have heard of Brad Pen, never even knew about the Lucas.
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049700
08/09/11 04:12 AM
08/09/11 04:12 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I put Royal Purple break in oil then go to GTX 10/40. iT WORKS !
Re: any "break in" oil recommendations ? [Re: mosweethemi] #1049701
08/09/11 08:43 AM
08/09/11 08:43 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Bradd Penn makes a 30 wt break in oil.
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049702
08/09/11 09:20 AM
08/09/11 09:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont worry about break in oil on a roller cam...
but I dont put a synthetic in for the first weekend
then after the first weekend I change
Re: any "break in" oil recommendations ? [Re: MR_P_BODY] #1049703
08/09/11 12:57 PM
08/09/11 12:57 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i put royal purple in mine
but iv only had it running a total of bout 10 seconds as it didnt have a rad. in it and block was dry
how long to run the oil if not racing before change it out?(also a roller motor)
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: any "break in" oil recommendations ? [Re: toplescuda] #1049704
08/09/11 01:42 PM
08/09/11 01:42 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Joe Gibbs Breakin oil
Re: any "break in" oil recommendations ? [Re: MR_P_BODY] #1049705
08/09/11 02:06 PM
08/09/11 02:06 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
With the low tension rings now days, and a full roller set up there rearry isnt a "need" for break in oil. Most break in oils just have high zinc content for the cam. I never used it in my good engine, its a full roller 408, and I piss pounded it from the beginning, and have no issues. I run Brad Penn 20W50 in mine, and I havent made any extra holes in it yet.
Kasey
Re: any "break in" oil recommendations ? [Re: MR_P_BODY] #1049706
08/10/11 02:12 AM
08/10/11 02:12 AM
oregon
oregon
...............Simple and easy, thanks MR. "P"
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049707
08/10/11 03:29 AM
08/10/11 03:29 AM
Pgh, PA
Nino Offline
Nino  Offline
Pgh, PA
*Another vote for the Brad Penn. I get it from one of the local machine shops (I've never seen it sold in any of the local auto-part stores).
1970 Dodge Coronet 1968 Barracuda FB 1970 Duster 1974 Dart 1977 Dodge Custom Van
Re: any "break in" oil recommendations ? [Re: Nino] #1049708
08/10/11 08:53 AM
08/10/11 08:53 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
My opinion, forget about zinc additives and use Brad Penn break-in 30 wt oil (or equivolent j gibbs). When everything is factored in, the BP wont cost you any more and you will get an oil with an additive recipe carefully designed for exactly what you are doing.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: any "break in" oil recommendations ? [Re: Rapid340] #1049709
08/10/11 10:36 AM
08/10/11 10:36 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Re: any "break in" oil recommendations ? [Re: savoyracer] #1049710
08/10/11 01:00 PM
08/10/11 01:00 PM
I use regular 5W20Wt Valvoline in all of my motors from day one, race or street. I do use a cam oil additive(zinc or Comp Cams) if they are not steel billet roller cams I agree with Mike(MR Pbody) on not using synthetic to start a new motor out on but a lot of the new cars come that way(synthetic oil in them) If the custmer wants a "race oil" to start with then I use Pennzoil 25-50 WT race oil, it is way slicker than most other oils
