Custom dashes #1049685
08/08/11 11:52 PM
08/08/11 11:52 PM
70duster340 Offline OP
I know that many of you have made your own dashes, but the question is, how did you wire up such things as turn signals and emergency flashers? Also, the high beam indicator and warning lights? I'm considering making my own dash, and would like some input, please.
TIA!!!
Re: Custom dashes [Re: 70duster340] #1049686
08/09/11 01:14 AM
08/09/11 01:14 AM
Anybody???
Re: Custom dashes [Re: 70duster340] #1049687
08/09/11 02:09 AM
08/09/11 02:09 AM
Canada
CrAzYMoPaRGuY Offline
Canada
TIA!!!
I use a Ron Francis kit. If wiring from scratch it would be just as easy, the warning lights are usually grounded at the senders, turn signals and flashers are fairly straightforward unless odd switches and columns are used..?
CrAzYMoPaRGuY
Re: Custom dashes [Re: CrAzYMoPaRGuY] #1049688
08/09/11 08:09 AM
08/09/11 08:09 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I modified my stock harness. It was between spending a bunch of money on a replacement harness, or working with the factory one. In my case, the factory harness was in nice shape.
Anything I removed, I left enough lead that I can reattach at some point if I ever go back to the factory instruments. In the process I also removed the ammeter and feed through the bulkhead which is a bit hazardous.
Painless sells indicator lights in red, orange, green, and blue. They also sell the headlight switch assembly, wiper switch, etc.
383, Hemi 4-Speed, AlterKtion, D60
Re: Custom dashes [Re: Crazy68Dart] #1049689
08/10/11 12:32 AM
08/10/11 12:32 AM
Can anyone offer any wiring diagrams? That would be very helpful!
Re: Custom dashes [Re: 70duster340] #1049690
08/11/11 10:57 PM
08/11/11 10:57 PM
Nobody???
Re: Custom dashes [Re: 70duster340] #1049691
08/11/11 11:24 PM
08/11/11 11:24 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i used a kit from american auto wire. i used 5/16 led lights from jegs for the turn and high beam indicaters. just don't get blue for the high beam indicater. holy crap is it brite. way too brite. lights up the entire interior of the car. i'm going to buy a red one one of these days and replace it. a service manual should have all the diagrams you need to do it.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Custom dashes [Re: abodyjoe] #1049692
08/12/11 12:06 AM
08/12/11 12:06 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Not a biggee to dim the LED briteness, one needs to insert a series resistor to decrease the voltage..
Just my $0.02....
Re: Custom dashes [Re: abodyjoe] #1049693
08/12/11 11:06 PM
08/12/11 11:06 PM
Hey abodyjoe, where did you get that dash insert? Also, the wiring harness? That's really sharp!
