V8 radiator on a slant six #104929
08/14/08 05:37 PM
08/14/08 05:37 PM
Klamath Falls, Oregon
Dartslantsix Offline OP
Anyone try to use a V8 radiator in a slant six car for more cooling? What hoses did you use?
Re: V8 radiator on a slant six [Re: Dartslantsix] #104930
08/14/08 07:27 PM
08/14/08 07:27 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Which make/model/year?
The lower radiator inlet location should be the same, but you'll need to use a flex hose on the upper or scrounge the parts store's selection.
FWIW, I did the opposite (360 w/slant HD cooling radiator) and could not find a molded hose that worked. I ended up using a 22" flex hose.
Re: V8 radiator on a slant six [Re: Dartslantsix] #104931
08/14/08 08:40 PM
08/14/08 08:40 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
Prior to the swap to the the 360 I was using a 72 22" heavy duty small block radiator with my \6. As i recall I used the slant 6 lower hose and stretched it to fit the over the lower fitting on the radiator. I bent a piece of coat hanger to the shape I needed for the upper hose and went to the local parts store and matched an upper hose up. I had to trim some off the one I selected but it fit with no issues.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: V8 radiator on a slant six [Re: dgc333] #104932
08/16/08 09:38 AM
08/16/08 09:38 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
New 22" 2 core 318 radiator for that year car and I used a new molded hose for the 318 application on the top, the bottom hose was the same. Looks stock.
Re: V8 radiator on a slant six [Re: mopowergtx] #104933
08/16/08 11:20 AM
08/16/08 11:20 AM
Mopowergtx I have never seen a valve cover with breather cap, oil fill and pcv all on the same side.
Re: V8 radiator on a slant six [Re: RapidRobert] #104934
08/17/08 12:46 PM
08/17/08 12:46 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
The valve cover on my slant six in my '72 Swinger is that way...
vm
Re: V8 radiator on a slant six [Re: RapidRobert] #104935
08/17/08 04:03 PM
08/17/08 04:03 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
If you only have one valve cover.
Re: V8 radiator on a slant six [Re: JonC] #104936
08/17/08 08:39 PM
08/17/08 08:39 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: V8 radiator on a slant six [Re: JonC] #104937
08/17/08 10:54 PM
08/17/08 10:54 PM
man I missed that completely, that it was a /6. I am embarrassed
