Re: V8 radiator on a slant six
[Re: Dartslantsix]
#104930
08/14/08 07:27 PM
08/14/08 07:27 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Anyone try to use a V8 radiator in a slant six car for more cooling? What hoses did you use?
Which make/model/year?
The lower radiator inlet location should be the same, but you'll need to use a flex hose on the upper or scrounge the parts store's selection.
FWIW, I did the opposite (360 w/slant HD cooling radiator) and could not find a molded hose that worked. I ended up using a 22" flex hose. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: mopowergtx]
#104933
08/16/08 11:20 AM
08/16/08 11:20 AM
RapidRobert
Mopowergtx I have never seen a valve cover with breather cap, oil fill and pcv all on the same side.
[Re: RapidRobert]
#104934
08/17/08 12:46 PM
08/17/08 12:46 PM
Posts: 411 Texas
vynn3
Texas
The valve cover on my slant six in my '72 Swinger is that way... ![](/ubbthreads/images/graemlins/shruggy.gif)
vm
[Re: RapidRobert]
#104935
08/17/08 04:03 PM
08/17/08 04:03 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
If you only have one valve cover. ![](/ubbthreads/images/graemlins/shruggy.gif)
