Page 1 of 4 1 2 3 4
Edelbrock Victor heads: post your combos, please!!! #1049256
08/08/11 05:06 PM
08/08/11 05:06 PM
junction city oregon
V
viperblue72 Offline OP
V
Seems there's been a few posts before about victor heads with little resposnse. So I thought id give it a try in hopes that more people have gotten their hands on these.
So post your big block victor combos!
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049257
08/08/11 05:47 PM
08/08/11 05:47 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I can only post the parts that will be going together, not any actual results from using them.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: BradH] #1049258
08/08/11 06:39 PM
08/08/11 06:39 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
I am also in the parts collecting and research stages. wont have results till next spring. This is a maximum effort, CNC ported, very high lift combination.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: BradH] #1049259
08/08/11 06:51 PM
08/08/11 06:51 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
how about some pics of those fancy victors?
what rocker did you end up using?
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049260
08/08/11 07:02 PM
08/08/11 07:02 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Victor Max wedge heads, PAC 1325 springs, +0.100" Crower Ti retainers, 1.950" install height, 275# seat, 710# open at 0.714" lift. mild 264/264 duration @ 0.050" cam, 112 LSA, installed at 108. (Might be better at 110?) Idles nice and smooth at 800-1000 rpm, but not much vacuum.
Installed an a 4.15" stroke 400 block (500 cid) with the ICON flat top pistons, 12.4:1 compression. Indy 400-2 4150 flange single plane intake, hooker 2" super comp headers.
Holley 1,000 cfm HP carb (could use larger, but already had the carb.)
Chassis dynoed at 558 rear wheel HP, in street trim, TTI 3" exhaust, clutch fan, mopar waterpump, 136 amp alternator, 14"x3" air filter with filtered lid, power steering, auto trans, custom 9" converter. Should be easy over 650 flywheel HP?
Re: Edelbrock Victor heads: post your combos, please!!! [Re: 451Mopar] #1049261
08/08/11 07:28 PM
08/08/11 07:28 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i used the m/w victors with the super victor manifold on my 528ci. you'll have to spend some time enlarging the holes where the pushrods go thru the heads. put dummy springs on the heads so you can cycle the engine and you will see where the holes need clearancing. i used the t&d rockers and they worked out really nice. also buy the studs from indy to hold the rockers down. they are a full 1" long to give full thread engaugement. i'd use them again. if you start going over .700 lift, things get tricky. good luck witch ever way you go.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: Deepockets] #1049262
08/08/11 09:17 PM
08/08/11 09:17 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have them on my junk ported by Dwayne Porter. 350cfm At .650 lift. T&D rocker arms.
low tens but with me in it my junk is heavy. @3650lbs
Re: Edelbrock Victor heads: post your combos, please!!! [Re: 70blackfish] #1049263
08/08/11 09:48 PM
08/08/11 09:48 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Here's a thread documenting the build of my mw victor motor.
Maxwedge victor build
Dyno results
Race weight is 3530 and it's gone a best of 9.92 @ 135.
Never touched the tune since the day we dyno'd it,
so should be some more left in there.
Most likely won't be trying much until next year
when I should have more time for the car.
Haven't had it out since last November.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049264
08/08/11 10:02 PM
08/08/11 10:02 PM
usa
hot67cuda Offline
hot67cuda  Offline
usa
I am real happy with them,max wedge by modern cyl head flow 366 at .650lift.Small roller cam 265 at.50 int ext 270at.50 640 lift t and rockers mopar 337 intake I can tell you already my eng would like a bigger cam for the track but i do a lot of street driving.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: hot67cuda] #1049265
08/08/11 11:32 PM
08/08/11 11:32 PM
V
V
What size engine? Also did you just use the victor valley tray with the 337 intake?
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049266
08/09/11 12:03 AM
08/09/11 12:03 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I'm doing the MW Victor thing as well, Got the heads.
Not sure what size engine as I'm torn between winding it hard with a 470 or just going 512+ either on a B based block.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: RobX4406] #1049267
08/09/11 02:25 AM
08/09/11 02:25 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We built one maniily from left over parts when the Victors first came out. It was a 440 block with 4.15" stroke, flat top pistons and 12:1 CR, pump gas. Comp Cams 283/.683" roller cam, victor intake and a 1050 dominator. The ehads were home ported and since at the time there were no rockers available, we used Indy 440-1 rockers. They fit with minor grinding. The engine was in a 3200 lbs '69 Valiant with SS springs and run a best of 10.08/137 mph. The drivetrain also consisted of leftover parts and the engine was never really tuned, so it propably was never fully sorted out. Afterwards teh engine went in to a SC dragster, and it runs the same speeds as the common chevy revivals and has won one national championship.
Plynouth VIP '67 TT IC EFI
Re: Edelbrock Victor heads: post your combos, please!!! [Re: jyrki] #1049268
08/09/11 08:50 AM
08/09/11 08:50 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
Victor, standard port with 11.2:1. Victor intake 1050 Quick Fuel carburetor. Roller cam 275/282 @.050 & about 0.660 lift. Hughes rockers, pump gas, 10.03 132.55 in a 3280 pound Duster. 451 low deck. Pro Parts headers and they fit very well. Looks like I guessed about right to keep away from some of the requirements to run 9's.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: marvo451] #1049269
08/09/11 10:06 AM
08/09/11 10:06 AM
tboomer Online work
tboomer  Online Work
While the Victor is a good head,wouldn't it be easier to use an Indy MW head? I don't think the Indys require the fancy offset rockers...
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049270
08/09/11 12:11 PM
08/09/11 12:11 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
Fully CNC ported max wedge victors running comp cam 23-707-9 roller. heads flow numbers are 372 @ 700 lift. using Hughes 1.6 rockers. chambers are 70cc and 13.5 to 1 compression running on methanol. indy intake with 1050 dom. and 2 inch adapter. Hughes did all the port work. the combo works ok for me, car weights 3450 in race trim.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049271
08/09/11 02:42 PM
08/09/11 02:42 PM
V
V
Id rather not give anymore business to indy if I don't have to! That's just my
And what is so fancy about offset rockers? You can buy the expensive ones but hughes engines also makes a set that are very reasonable.
Re: Edelbrock Victor heads: post your combos, please!!! [Re: tboomer] #1049272
08/09/11 04:08 PM
08/09/11 04:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ted , Indy 440-1's use an offset intake rocker
Re: Edelbrock Victor heads: post your combos, please!!! [Re: JohnRR] #1049273
08/09/11 05:35 PM
08/09/11 05:35 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Maybe Ted was refering to the MW EZ head.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Edelbrock Victor heads: post your combos, please!!! [Re: JohnRR] #1049274
08/09/11 05:35 PM
08/09/11 05:35 PM
tboomer Online work
tboomer  Online Work
John....I should have said the EZ-1..If I keep my car,Those are the ones I want..Now...Back to the Victors!!!
Re: Edelbrock Victor heads: post your combos, please!!! [Re: viperblue72] #1049275
08/09/11 06:59 PM
08/09/11 06:59 PM
SoCal
Brian Hafliger Offline
SoCal
Exactly! Best bang for the buck IMO!!
Brian Hafliger
Page 1 of 4 1 2 3 4
