Horsepower and torque for this engine? #1049144
08/08/11 01:19 PM
08/08/11 01:19 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
451 with 11 to 1 cr using Ross pistons, good rods, fresh cut 440 crank
Don't want more compression so I can run pump fuel on street when I have to.
Ported Indy SR heads flowed with exh extension (not Max Wedge)
.200 155, 110
.300 225, 165
.400 280, 210
.500 315, 240
.600 345, 265
.700 350, 275
Victor 4150 intake and Quick Fuel 1050 4150 carb
Solid roller oval track lobes
290, 292 @.020
258, 260 @.050
178, 181 @.200
.664"(1.6), .631" (1.5)
110 LSA
2 inch Hooker headers for B-E body
What would you expect this to make for hp and torque?
Re: Horsepower and torque for this engine? [Re: PorkyPig] #1049145
08/08/11 01:33 PM
08/08/11 01:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
.200 155, 110
.300 225, 165
.400 280, 210
.500 315, 240
.600 345, 265
.700 350, 275
290, 292 @.020
258, 260 @.050
178, 181 @.200
110 LSA
560 to 590 HP at or near 6000 RPM and similar torque on pump gas
Re: Horsepower and torque for this engine? [Re: Cab_Burge] #1049146
08/08/11 04:26 PM
08/08/11 04:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Cab - You and I must not be looking at the same specs. I'm thinking 640-660 HP at 6600, but not sure where the torque would fall... maybe 560-580 around 5400?
Re: Horsepower and torque for this engine? [Re: BradH] #1049147
08/08/11 06:51 PM
08/08/11 06:51 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Re: Horsepower and torque for this engine? [Re: BradH] #1049148
08/08/11 10:04 PM
08/08/11 10:04 PM
Brad, look at the head flow, his SR heads are 440 size ports, not M.W. I hope he dyno tests it and post the results EDITED OOPS, my bad I was looking at the exhaust side thinking it was the intake side , Brad is probally a lot closer than I am on this one
Re: Horsepower and torque for this engine? [Re: Cab_Burge] #1049149
08/09/11 08:45 AM
08/09/11 08:45 AM
gregsdart Offline
gregsdart  Offline
I agree on the 650 + range. This a great combo, should make good power.
Re: Horsepower and torque for this engine? [Re: gregsdart] #1049150
08/09/11 01:53 PM
08/09/11 01:53 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I don't know how anybody can predict anything without some kind of cam specs. If you have a cam with 270* duration @ 0.050 with lift around .650" - .700", I would say it should make 630HP - 590TQ.
Re: Horsepower and torque for this engine? [Re: Biginchmopar] #1049151
08/09/11 02:06 PM
08/09/11 02:06 PM
The cam specs are under the intake and carb specs
Re: Horsepower and torque for this engine? [Re: PorkyPig] #1049152
08/09/11 05:53 PM
08/09/11 05:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'll guess 630 hp @ 6,300 RPM?
Re: Horsepower and torque for this engine? [Re: gregsdart] #1049153
08/10/11 03:46 PM
08/10/11 03:46 PM
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
I hope, and thanks. I was thinking of going bigger on the cam, but the guy who specd it out made sense on why he recommended that one.
No dyno time for this one since I spent all my money on the parts.
