Horsepower and torque for this engine?
#1049144
08/08/11 01:19 PM
08/08/11 01:19 PM
Posts: 610 long time lurker, short time p...
PorkyPig
451 with 11 to 1 cr using Ross pistons, good rods, fresh cut 440 crank
Don't want more compression so I can run pump fuel on street when I have to.
Ported Indy SR heads flowed with exh extension (not Max Wedge) .200 155, 110 .300 225, 165 .400 280, 210 .500 315, 240 .600 345, 265 .700 350, 275
Victor 4150 intake and Quick Fuel 1050 4150 carb
Solid roller oval track lobes 290, 292 @.020 258, 260 @.050 178, 181 @.200 .664"(1.6), .631" (1.5) 110 LSA
2 inch Hooker headers for B-E body
What would you expect this to make for hp and torque?
Re: Horsepower and torque for this engine?
[Re: PorkyPig]
#1049145
08/08/11 01:33 PM
08/08/11 01:33 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
560 to 590 HP at or near 6000 RPM and similar torque on pump gas
[Re: Cab_Burge]
#1049146
08/08/11 04:26 PM
08/08/11 04:26 PM
BradH
Cab - You and I must not be looking at the same specs. I'm thinking 640-660 HP at 6600, but not sure where the torque would fall... maybe 560-580 around 5400?
[Re: gregsdart]
#1049153
08/10/11 03:46 PM
08/10/11 03:46 PM
PorkyPig
I agree on the 650 + range. This a great combo, should make good power.
I hope, and thanks. I was thinking of going bigger on the cam, but the guy who specd it out made sense on why he recommended that one.
No dyno time for this one since I spent all my money on the parts.
