Blower motor experience #1048718
08/07/11 05:43 PM
08/07/11 05:43 PM
N.Y.
V
VZCharger Offline OP
V
N.Y.
Didn't want to highjack the other post "tell me about blowers", so a little about my experience building my latest blower motor.
First the motor itself:
Block is '69 440 with Barton main caps. Has a 4.15" stroke crank, Eagle 7.1" rods.
Heads are Indy SR's, Harland Sharpe roller rockers
Blower is Kuhl 8-71 sitting on an Indy blower manifold
Injection setup is a BDS 2 hole bugcatcher with FastXFI fuel injection with injectors above and below the blower.
Motor made 788 hp at 6400 rpm. This is when the injectors maxed out. Going to try upping the fuel pressure a bit to see if it helps out. But don't much care as this is plenty for what I need. The torgue maxed put at 700 lbft at 4600 rpm.
It is going into my '70 Charger, backed by a 727 and a Dana 60. Think it'll be a fun ride.
From my experience building this motor I can say the following about the vendors I used:
Bartons- bunch of great guys, pricey both worth it. Ray himslef is a real good guy too, dry sense of humor but very easy to talk to.
Indy- same opinion as most others. Seems like they thought they were doing you a favor by selling you parts.
FastMan- Rich has been a pleasure to deal with. Stands behind everything he sells. Every problem came down to his suppliers.
BDS- Screwed up so many things on my order that I cant even remember them all. Gave a hard time about straightening them out too.
Kuhl- shame they aren't in business anymore they were great to deal with.
Overall though can't wait to get it in the car. Been a while in the making.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: Blower motor experience [Re: VZCharger] #1048719
08/07/11 07:21 PM
08/07/11 07:21 PM
Hopefully your fuel regulator is boost referenced, is it?One other thing I went through on a EFI BDS provided was not all the injectors had the same impedence ratings Hopefully Rich and FAST didn't make that mistake BTW, I went through the same thing with BDS, I think most of it was through there ignorance, not intentionally screwing things up Maybe not I like Litlefield a lot when it comes to Roots type blowers
Re: Blower motor experience [Re: Cab_Burge] #1048720
08/07/11 08:35 PM
08/07/11 08:35 PM
N.Y.
V
V
N.Y.
Regulator is boost referenced.
The injectors being a bit undersized is my fault. During the build we went from a stock crank to the stroker and forgot to tell Rich .
Re: Blower motor experience [Re: VZCharger] #1048721
08/09/11 01:29 AM
08/09/11 01:29 AM
indiana PA
moparbob498 Offline
moparbob498  Offline
indiana PA
yes..i also had a crappy time with BDS---they screwed up..even though i explicitly ordered a top for dual dominators (4500 series) they sent me a dual 4150 top,..they gladly exchanged & paid for all shipping ect..but just the screw up...ok..now they got my $$$$$...and all of a sudden im no longer a priority...like technical issues..they didnt even care about me no longer,.i like their products,.but they need to work on customer relations--a good bit
lately i've been talking with a guy named JR from RBS SUPERCHARGERS.. he is great and totally helpful,.and if he don't know..he will direct you in the correct direction so you can run your machine,.without a disaster and they also have a nice selection of used and new parts---best speed shop i've dealt with yet---umm VZCharger,..what overdrive are you running & static compression
& cam ect..i kinda expected a bit more from that beast you built..? i have basically the same set up & i haven't dyno'ed mine yet,.but estimated HP was said to be @1,200 and TQ was to be @950+...im running dual 1150 HP dominators
at the moment,.but am going to a bug catcher---suppose to have better off idle
and top end over the bird catcher? dunno..im a noob to this...and do not want any mistakes--if that happens,..im back to headers,.glasspacks and a 600 vacum secondary---basically im doomed if i make a mistake..& blower engines are not forgiving i hear---well good luck..and if you'd like to chat tech my email is
moparbob498@yahoo.com
Bob Fedder
mopar or no car
Re: Blower motor experience [Re: moparbob498] #1048722
08/09/11 04:25 AM
08/09/11 04:25 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Our pacakage is as follows, 4.5" x 4.15", 8:1, Comp Cams mech roller, around 255 degrees at .050", Ported RPM heads, BDS intake and BDS 8-71 blower. Two 750 dp Holleys and water/methanol injection. It made 800 hp and 808 ft-lb in our local dyno and has run 9.51/143 mph on pump gas, SS springs and DOT tires in a car weighing 3400 lbs.
http://www.youtube.com/watch?v=WSlQ_HFQMXc
http://www.youtube.com/watch?v=-JsWg86YoJU
Plynouth VIP '67 TT IC EFI
Re: Blower motor experience [Re: jyrki] #1048723
08/09/11 02:08 PM
08/09/11 02:08 PM
N.Y.
V
V
N.Y.
I think the HP on my motor is a bit 'low' for what it is mostly due to me wanting to be extra careful. It is a stock block, pump gas motor after all. My injectors are on the small size to help with the drivability, HP was still climbing like a rocket when we ran out of injector. Also it is actually underdriven right now, but that can change. If it see track time once or twice a year it will be lucky. Built more for scaring the locals and cruising.
Re: Blower motor experience [Re: VZCharger] #1048724
08/10/11 05:03 PM
08/10/11 05:03 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i 1st got a BDS st2 and did not like what it put out so i got a blowershop w/teflon and put the BDS on the shelf.the rotor to rotor, to case clearence on the BDS is .020.i even sent the BDS back to get run tested and got it back without the snout coupler,eventualy thay sent me a used one to replace the new i had on there.learning this blower stuff gas been interesting.
Re: Blower motor experience [Re: Clanton] #1048725
08/10/11 05:35 PM
08/10/11 05:35 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
next time call "the blower shop" in simi valley ca., even if you need warranty work on the bds crap, if bds will not back up there product you would be better off sending it to the blower shop, better service, more reasonable, quicker,i could go on but i think you get the picture .
Re: Blower motor experience [Re: SV_MOPARS] #1048726
08/10/11 05:53 PM
08/10/11 05:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
in my end of town[OHIO] i believe Fowlers in Columbus would be able to do the job.it was 100$ to ship the blower to BDS each way from here.
Re: Blower motor experience [Re: Clanton] #1048727
08/10/11 10:20 PM
08/10/11 10:20 PM
N.Y.
V
V
N.Y.
In my case the blower itself is a Kuhl unit. My dealngs with BDS were for the bugcatcher and parts of the fuel injection setup, and most of that was through FastMan.
Re: Blower motor experience [Re: VZCharger] #1048728
08/11/11 09:14 AM
08/11/11 09:14 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have had some "interesting" experiences with BDS.It sorta remind me of INDY,the product is good but the customer service is marginal.I've had better luck with Good Vibrations.The latest saga was when I purchased a shorter competition snout,my swingarm belt tensioner would not fit had to "open up" the inside diameter to make it work.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Blower motor experience [Re: moparbob498] #1048729
08/12/11 12:32 PM
08/12/11 12:32 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Re: Blower motor experience [Re: Blown71X] #1048730
09/22/11 11:27 PM
09/22/11 11:27 PM
Richmond , Virginia
BEEQUIK Offline
BEEQUIK  Offline
Richmond , Virginia
I have no blower motor experience but I have wanted one for a long time.I am the proud owner of a very mild , almost complete 8-71 motor. I am hoping to have my 69 RR ready to put it in in the next year or so. I hope its not too hard to get a handle on...
Re: Blower motor experience [Re: BEEQUIK] #1048731
09/22/11 11:55 PM
09/22/11 11:55 PM
N.Y.
V
V
N.Y.
Well this is my third blower motor in my Charger, each a bit better than the last the first was very mild but still lots of fun. Hopefully I'm done.
Motor is now in the car, but need to finish up the fuel system and wiring for the injection. Probably be ready just in time to sleep for the winter.
Re: Blower motor experience [Re: BEEQUIK] #1048732
09/24/11 09:59 AM
09/24/11 09:59 AM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
hey chris,sounds like we can learn together.i`m in the same boat as you.i have a home for my blower motor.i`m building a 41 willys with a dyers 871 440 in it.mild pump gas motor but figure the huffer will make up the power and be fun on the street.after nothing but messing with ronnie and kenny`s darts this blower stuff is new to me.
joe
Re: Blower motor experience [Re: VZCharger] #1048733
09/24/11 12:59 PM
09/24/11 12:59 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Hey Vince, that's almost a copy of the motor I'm (still) building.
Half-filled 440, 4.15" crank, Roller cam, Kuhl 8/71, INDY intake, INDY 440-1 heads.
Building it mainly for street-use aswell.
What kind of cam and specs you have in that motor?
Re: Blower motor experience [Re: BigBlockMopar] #1048734
09/24/11 01:47 PM
09/24/11 01:47 PM
N.Y.
V
V
N.Y.
Your post just made me realize that I never got the cam spec/card when I got the motor. Have to call over to Bartons and get it.
Not a roller cam though, just a plain old mech. setup.
