Voltage limiter #1048608
08/07/11 02:11 PM
08/07/11 02:11 PM
Home of the Dream Cruise
FPD031 Offline OP
FPD031  Offline OP
What is that condenser looking item on the back of the dash that goes to the voltage limiter. I'm replacing my circuit board and VL and need to know what this is and should I replace it at the same time. I accidently fried the power circuit on the board checking it. I know, I know.
69 Charger
Re: Voltage limiter [Re: FPD031] #1048609
08/07/11 02:25 PM
08/07/11 02:25 PM
FPD031 Offline OP
FPD031  Offline OP
On a side note, has anyone used the circuit board with the built in voltage limiter?
Re: Voltage limiter [Re: FPD031] #1048610
08/07/11 02:54 PM
08/07/11 02:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
69 Charger
The condensor is for noise suppression of the AM radio, when the voltage limiter makes/breaks its internal contacts..
Also the condensor helps to absorb part of the spark that can burn/pit the voltage limiter's internal contact points..
Just my $0.02...
Re: Voltage limiter [Re: FPD031] #1048611
08/07/11 04:19 PM
08/07/11 04:19 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The voltage limiter works using a bimetal strip that makes and breaks contact at a predetermined rate so the output is 5 volts. Like anything that arc, sparks or interupts power it will generate radio interferrence. The capacitor or condensor (same thing, different nomenclature) lowers the amount of radio noise generated. Yes, they do wear out.
Craig
Re: Voltage limiter [Re: denfireguy] #1048612
08/07/11 04:37 PM
08/07/11 04:37 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
So where do you get the condensor?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Voltage limiter [Re: 70sixpkrt] #1048613
08/07/11 05:05 PM
08/07/11 05:05 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Best action is to upgrade to the solid state voltage limiter, no contacts so no condensor is required..
Sean @ RedLine Gauges carries them..
Here is the link..
http://www.redlinegaugeworks.com
Just my $0.02...
Re: Voltage limiter [Re: Sinitro] #1048614
08/07/11 05:31 PM
08/07/11 05:31 PM
FPD031 Offline OP
FPD031  Offline OP
Red Line's web site wasn't much help. Limited parts. Seems like it's more for service or conversions. Didn't see the voltage limiter. Found it alot of other places though.
Re: Voltage limiter [Re: FPD031] #1048615
08/07/11 05:40 PM
08/07/11 05:40 PM
FPD031 Offline OP
FPD031  Offline OP
Well, since nobody posted on the circuit board with the built in limiter, I think I'm gonna try that. It's actually cheaper than buying a board and limiter seperate. Year One is the only place I can find right now. Price is Ok with the discount. Thanks for the info on the radio suppressor. Won't need that with the Music Master radio.
Re: Voltage limiter [Re: FPD031] #1048616
08/07/11 06:14 PM
08/07/11 06:14 PM
Arizona
az426john Offline
az426john  Offline
Arizona
There was a magazine article in Mopar Muscle November 1992 issue that told how to build them using components from Radio Shack.
I have built at least 3 and they work great. I think Redline charges about $50.00 for them but you can do it yourself for less than $10.00 in parts and supplies and a couple of hours time.
Re: Voltage limiter [Re: az426john] #1048617
08/07/11 06:30 PM
08/07/11 06:30 PM
FPD031 Offline OP
FPD031  Offline OP
Thanks, but I'll pass. That's what got me in this mess in the 1st place, puttin volts where there wasn't supposed to be any. I"ll just go with the built-in limiter. Thanks though.
Re: Voltage limiter [Re: FPD031] #1048618
08/07/11 07:05 PM
08/07/11 07:05 PM
70sixpkrt Offline
70sixpkrt  Offline
I think there was a member here that was making circuit boards. I think it was in the New Products section. Just found it. http://premiumdashdecals.com/
4-speed
3:54 Dana
Re: Voltage limiter [Re: 70sixpkrt] #1048619
08/07/11 10:24 PM
08/07/11 10:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Go to Radio Shack and get a .05 micro-farad, 600 volt capacitor and wire it in parallel with the current one. When they go bad, they get leaky and placing a new one in parallel will increase the total capacitance.
Or you can replace the limiter with one from Dash Worx. Their ads are on this board.
http://rt-eng.com/mediawiki/index.php/Main_Page
I did go with the Dash Worx limiter. It is physically the same size.
I passed on the three terminal regulators as I have not had good luck with them in other applications, none of them automotive. The current on the dash is uncomfortably close to the device maximum current, I like to see around 75% head room in a design like that and it just isn't there.
Craig
Re: Voltage limiter [Re: az426john] #1048620
08/08/11 12:23 AM
08/08/11 12:23 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I got 1 from RedLine for about $30 @ the Spring Fling..
What I like about RedLine is that they are a small, fully experienced shop just for gauges and electrical things. They are located about 30 minutes away and I like to talk/deal directly to a live, knowledgible person...
Just my $0.02...
Re: Voltage limiter [Re: Sinitro] #1048621
08/08/11 10:45 AM
08/08/11 10:45 AM
Washington
69440 Offline
69440  Offline
Washington
Way back when, when I was in the parts business, that part was listed in the books as an Instrument Cluster Voltage Regulator. I've got dozens of em, and would be happy to donate one to your cause, Bill
Re: Voltage limiter [Re: 69440] #1048622
08/08/11 06:52 PM
08/08/11 06:52 PM
FPD031 Offline OP
FPD031  Offline OP
Thanks Bill, I appreciate it but I ordered the circuit board with the built in voltage limiter. Nice thought though.
Re: Voltage limiter [Re: FPD031] #1048623
08/08/11 07:28 PM
08/08/11 07:28 PM
70sixpkrt Offline
70sixpkrt  Offline
Who did you order it from?
4-speed
3:54 Dana
Re: Voltage limiter [Re: 70sixpkrt] #1048624
08/08/11 07:33 PM
08/08/11 07:33 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
anyone got a clue on what to do when the limiter is in the gauge itself? there are no more gauges,as in late 50 early 60 c bodies
Re: Voltage limiter [Re: 70sixpkrt] #1048625
08/09/11 11:20 AM
08/09/11 11:20 AM
FPD031 Offline OP
FPD031  Offline OP
Year One
