So...Apparently I don't have first gear *UPDATE*
#1048586
08/07/11 01:25 PM
08/07/11 01:25 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I thought it was just a linkage adjustment. When I adjust for Park (Shifter in P and tranny lever all the way back) I can turn the engine over but there is no first gear available. When I adjust for 1st gear ( 1 on the Shifter and tranny lever all the way forward) I have first gear but the engine wont turnover.
I suspect my shifting mechanism is welded in the wrong spot, about 1/2" too far back. When adjusted for Park....I have about another 1/2" of travel possible on the shifter.
Do I have to remove my seats/console/carpet and cut/reweld the shifter bracket a 1/2" forward?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: So...Apparently I don't have first gear
[Re: Pyper70]
#1048587
08/07/11 01:39 PM
08/07/11 01:39 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Sounds like a mismatch of linkage parts... If it were just welded in the wrong location you could adjust the linkage to compensate.... The lever on the trans doesn't have the same ratio as the shifter... Could also be a problem of the bellcrank ratio but I doubt it... Probably the trans lever is to long....
[Re: mopar_man]
#1048589
08/07/11 07:15 PM
08/07/11 07:15 PM
Pyper70
Athens, Greece
I did that...I took off the plate on the console to get a look at the shifter mechanism. It just doesn't make sense as to why I can get one and not the other. Park is more important obviously but I want 1st gear too. The shifter being all the way back in the mechanism nets me about half way through 1st and 2nd gear at the trans. I am gonna remove the three bolts holding that mechanism in tomorrow. move it down about 5/16" of an inch and vice grip it into place and check it that way. Its been like this for ooooooo...bout 11 years...I just always left it in Drive and went about my merry way...When I installed the Gear Vendors I was trying to figure out why I couldn't hit 1st gear and gear 1.5....at least now I know why.
[Re: Pyper70]
#1048590
08/07/11 07:26 PM
08/07/11 07:26 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Did this problem just pop up? New installation?
Crawl under the car and have somebody run the shifter through all the gears, look for lost motion; check for missing/worn bushings in the linkage.
[Re: Pyper70]
#1048592
08/08/11 11:12 AM
08/08/11 11:12 AM
Pyper70
Athens, Greece
Going by this picture attached....can I cut down this last part of the gear selector positions. I can't see why I can't adjust from the linkage but it only accepts one of the other. Its strange because I used this installation in the car as a guide to welding in the console unit for my 70 Charger and that one worked flawlessly.
Re: So...Apparently I don't have first gear *UPDATE*
[Re: 451Mopar]
#1048597
08/08/11 03:16 PM
08/08/11 03:16 PM
Pyper70
Athens, Greece
If you can and its not too much trouble I'd appreciate it.
If I have the wrong one....does anyone sell the correct lever?
[Re: Pyper70]
#1048601
08/08/11 07:34 PM
08/08/11 07:34 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
yes i have done that with a revers manual that would not always get third (1st position) when you got park. 1/16" to 1/8" 1.5mm to 3mm goes a long way!.
Make sure the leaver on the tranny is tight and not worn as sometimes they will move and it takes a fair amount of pressure to move it gear to gear!
[Re: 1_WILD_RT]
#1048602
08/08/11 08:26 PM
08/08/11 08:26 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Grinding the slot longer will allow you do hit at the detent locations but the shifter doesn't properly align the detents with the shift gate locations... Get the linkage sorted out..
What he said , you can easily modify the lever on your trans.
