So...Apparently I don't have first gear *UPDATE* #1048586
08/07/11 01:25 PM
08/07/11 01:25 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I thought it was just a linkage adjustment. When I adjust for Park (Shifter in P and tranny lever all the way back) I can turn the engine over but there is no first gear available. When I adjust for 1st gear ( 1 on the Shifter and tranny lever all the way forward) I have first gear but the engine wont turnover.
I suspect my shifting mechanism is welded in the wrong spot, about 1/2" too far back. When adjusted for Park....I have about another 1/2" of travel possible on the shifter.
Do I have to remove my seats/console/carpet and cut/reweld the shifter bracket a 1/2" forward?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: So...Apparently I don't have first gear [Re: Pyper70] #1048587
08/07/11 01:39 PM
08/07/11 01:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Sounds like a mismatch of linkage parts... If it were just welded in the wrong location you could adjust the linkage to compensate.... The lever on the trans doesn't have the same ratio as the shifter... Could also be a problem of the bellcrank ratio but I doubt it... Probably the trans lever is to long....
Re: So...Apparently I don't have first gear [Re: 1_WILD_RT] #1048588
08/07/11 05:55 PM
08/07/11 05:55 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Its a linkage problem. Pull the lever to neutral and see if it starts. jiggle from reverse to drive and see where it starts and then you know which way you have to adjust.
Re: So...Apparently I don't have first gear [Re: mopar_man] #1048589
08/07/11 07:15 PM
08/07/11 07:15 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I did that...I took off the plate on the console to get a look at the shifter mechanism. It just doesn't make sense as to why I can get one and not the other. Park is more important obviously but I want 1st gear too. The shifter being all the way back in the mechanism nets me about half way through 1st and 2nd gear at the trans. I am gonna remove the three bolts holding that mechanism in tomorrow. move it down about 5/16" of an inch and vice grip it into place and check it that way. Its been like this for ooooooo...bout 11 years...I just always left it in Drive and went about my merry way...When I installed the Gear Vendors I was trying to figure out why I couldn't hit 1st gear and gear 1.5....at least now I know why.
Re: So...Apparently I don't have first gear [Re: Pyper70] #1048590
08/07/11 07:26 PM
08/07/11 07:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did this problem just pop up? New installation?
Crawl under the car and have somebody run the shifter through all the gears, look for lost motion; check for missing/worn bushings in the linkage.
Re: So...Apparently I don't have first gear [Re: John_Kunkel] #1048591
08/07/11 08:01 PM
08/07/11 08:01 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Nope....been there for well over a decade...I didnt think too much of it since I just pop it in Drive to go cruisin....I know...its lame...shoulda been fixed.....a decade ago..I honestly haven't touched the car in 5 months...Life happened
Re: So...Apparently I don't have first gear [Re: Pyper70] #1048592
08/08/11 11:12 AM
08/08/11 11:12 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Going by this picture attached....can I cut down this last part of the gear selector positions. I can't see why I can't adjust from the linkage but it only accepts one of the other. Its strange because I used this installation in the car as a guide to welding in the console unit for my 70 Charger and that one worked flawlessly.
Re: So...Apparently I don't have first gear *UPDATE* [Re: Pyper70] #1048593
08/08/11 11:58 AM
08/08/11 11:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
sounds like you need a shorter lever on the transmission.
Re: So...Apparently I don't have first gear *UPDATE* [Re: 451Mopar] #1048594
08/08/11 12:03 PM
08/08/11 12:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: So...Apparently I don't have first gear *UPDATE* [Re: 451Mopar] #1048595
08/08/11 01:36 PM
08/08/11 01:36 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Aw jeez...don't tell me that...im on the other side of the world...Anyone have the correct length of lever available off hand for a 69 Charger (End of lever to center of shaft) I know we were piecing together linkages way back when....I wonder if we installed the one off the 67 Monaco by mistake...
Re: So...Apparently I don't have first gear *UPDATE* [Re: Pyper70] #1048596
08/08/11 02:00 PM
08/08/11 02:00 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
you can weld up the hole and re-drill it closer to the pivot. I can check the length of the lever later tonight or tomorrow.
Re: So...Apparently I don't have first gear *UPDATE* [Re: 451Mopar] #1048597
08/08/11 03:16 PM
08/08/11 03:16 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
If you can and its not too much trouble I'd appreciate it.
If I have the wrong one....does anyone sell the correct lever?
Re: So...Apparently I don't have first gear *UPDATE* [Re: Pyper70] #1048598
08/08/11 03:40 PM
08/08/11 03:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Is this a floor shift! If so you can grind the stop on the first gear end enough to allow 1st to engage. make sure all the nylon bushings are good and in place!
Re: So...Apparently I don't have first gear *UPDATE* [Re: Dodgem] #1048599
08/08/11 06:42 PM
08/08/11 06:42 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Yeah, in the picture I put up earlier its a floor shift. The arrow is pointing at the 1st gear position. I checked all the bushings and they are intact, smooth, and lubricated.
Re: So...Apparently I don't have first gear *UPDATE* [Re: Pyper70] #1048600
08/08/11 06:56 PM
08/08/11 06:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Grinding the slot longer will allow you do hit at the detent locations but the shifter doesn't properly align the detents with the shift gate locations... Get the linkage sorted out..
Re: So...Apparently I don't have first gear [Re: Pyper70] #1048601
08/08/11 07:34 PM
08/08/11 07:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yes i have done that with a revers manual that would not always get third (1st position) when you got park. 1/16"
to 1/8" 1.5mm to 3mm goes a long way!.
Make sure the leaver on the tranny is tight and not worn as sometimes they will move and it takes a fair amount of pressure to move it gear to gear!
Re: So...Apparently I don't have first gear *UPDATE* [Re: 1_WILD_RT] #1048602
08/08/11 08:26 PM
08/08/11 08:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said , you can easily modify the lever on your trans.
