world block with jesal key way lifters #1048572
08/07/11 12:26 PM
08/07/11 12:26 PM
nc
E
earthmover Offline OP
E
nc
my buddy ask me to post this and see if he could get some good answers...he has the world block and lifter bores bushed ,he has the jesal key way lifters ,and would like to know if he can push rod oil the motor or does it have to use spray bar covers??????he would like to push rod oil if possible ...thanka mike
Re: world block with jesal key way lifters [Re: earthmover] #1048573
08/07/11 12:31 PM
08/07/11 12:31 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
Yes it will work .
He will have to press out the old bushings from the block and install the proper keyed lifter bores .
Keyway lifters are no a drop in part .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: world block with jesal key way lifters [Re: go green] #1048574
08/07/11 12:39 PM
08/07/11 12:39 PM
nc
E
E
nc
the block was machined and set up for the keyway lifters ..he just didnt know if he could push rod oil..first build of this kind for him...just trying to make sure of whats the best way to go about some things ....do you guys think the push rod oil is better then the spray bar oil set up????whats the pros and cons of both
Re: world block with jesal key way lifters [Re: earthmover] #1048575
08/07/11 12:51 PM
08/07/11 12:51 PM
go green Offline
go green  Offline
If you are starting from scratch then pushrod oiling is by far the best .
Re: world block with jesal key way lifters [Re: go green] #1048576
08/07/11 01:11 PM
08/07/11 01:11 PM
nc
E
E
nc
thanks go green i love the cuda
Re: world block with jesal key way lifters [Re: earthmover] #1048577
08/07/11 06:30 PM
08/07/11 06:30 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
as long as the block is drilled for pushrod oiling he can, if its not nobody will want to drill it with the lifter holes drilled.
I just bought a new block to pushrod oil mine. works great will never do another mopar without pushrod oiling.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: world block with jesal key way lifters [Re: bigtimeauto] #1048578
08/07/11 07:09 PM
08/07/11 07:09 PM
nc
E
E
nc
how can you tell if its drilled for push rod oil..sorry for the unknown but new to this stuff..mike
Re: world block with jesal key way lifters [Re: earthmover] #1048579
08/07/11 08:43 PM
08/07/11 08:43 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
the back of the block where the cam goes will have 2 holes in line with where the lifters go about 10 and 2 oclock. or the easiest way is look in the hole where the lifter goes if there is a hole passing thru the top going from front to back thru all of the lifter bores it is.
Re: world block with jesal key way lifters [Re: bigtimeauto] #1048580
08/07/11 10:09 PM
08/07/11 10:09 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
same here
home of the
Sox and Martin Hemi Duster
Re: world block with jesal key way lifters [Re: bigtimeauto] #1048581
08/07/11 11:39 PM
08/07/11 11:39 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I have 572 and i have push rod oiling here i agree with you the only way to go if you can.
Re: world block with jesal key way lifters [Re: steeldust] #1048582
08/08/11 12:40 AM
08/08/11 12:40 AM
nc
E
E
nc
not sure if you are saying the hole in the lifter bore is going to the back or not but when you look at the block and the lifter bores it is a small hole in the bushing of the lifter bores.. mike
Re: world block with jesal key way lifters [Re: earthmover] #1048583
08/08/11 12:48 PM
08/08/11 12:48 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
take some picturs, one of the back of the block and one inside view of the lifter bore and we can tell you from there.
