Re: world block with jesal key way lifters
[Re: earthmover]
#1048577
08/07/11 06:30 PM
08/07/11 06:30 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
as long as the block is drilled for pushrod oiling he can, if its not nobody will want to drill it with the lifter holes drilled.
I just bought a new block to pushrod oil mine. works great will never do another mopar without pushrod oiling.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: earthmover]
#1048579
08/07/11 08:43 PM
08/07/11 08:43 PM
bigtimeauto
Trophy Winner
Trophy Winner
the back of the block where the cam goes will have 2 holes in line with where the lifters go about 10 and 2 oclock. or the easiest way is look in the hole where the lifter goes if there is a hole passing thru the top going from front to back thru all of the lifter bores it is.
[Re: bigtimeauto]
#1048581
08/07/11 11:39 PM
08/07/11 11:39 PM
Posts: 469 Tennessee
steeldust
Tennessee
I have 572 and i have push rod oiling here i agree with you the only way to go if you can.
[Re: steeldust]
#1048582
08/08/11 12:40 AM
08/08/11 12:40 AM
Posts: 2,449 nc
earthmover
nc
[Re: earthmover]
#1048583
08/08/11 12:48 PM
08/08/11 12:48 PM
bigtimeauto
Trophy Winner
Trophy Winner
take some picturs, one of the back of the block and one inside view of the lifter bore and we can tell you from there.
