Your Guess to the test... #1048545
08/07/11 10:33 AM
08/07/11 10:33 AM
USA
ramairthree Offline OP
USA
found in trunk of 74 RR,
I am guessing remote starter for underhood work
although could be a horn relay that lets you hit the horn from it
do any of you recoginize it for sure?
Re: Your Guess to the test... [Re: ramairthree] #1048546
08/07/11 10:36 AM
08/07/11 10:36 AM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
seat belt, or fuel, safety under hood cut off switch.
perception is 90% of reality
Re: Your Guess to the test... [Re: ramairthree] #1048547
08/07/11 11:18 AM
08/07/11 11:18 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
seat belt interlock bypass, 74 only.
BTW, could you please make the pictures fuzzier and bigger, they are almost, but not quite USELESS.
Don't be the exception.
Re: Your Guess to the test... [Re: Supercuda] #1048548
08/07/11 11:29 AM
08/07/11 11:29 AM
USA
USA
I wish I could say I take crappy pictures on purpose to test your skill, but sorry.
Both of you have strong kung fu and got it despite the pictures.
Should have been obvious to me,
but too many loose ends to sort out for it too have clicked.
It will plug into this
and lines up with the left two holes on the firewall.
I am not saying it's not fun getting together a car that sat after primer and disassembly and got it with lots still to sort out,
but I do wish I had hands on experience or one still all together to compare to.
Re: Your Guess to the test... [Re: ramairthree] #1048549
08/07/11 11:33 AM
08/07/11 11:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
it ain't kung fu, some problems stick in your mind forever. The 74 only seat belt interlock fiasco is one of them. You might want to reconsider restoring that part of the car altogether.
Re: Your Guess to the test... [Re: Supercuda] #1048550
08/08/11 12:19 PM
08/08/11 12:19 PM
dogdays Offline
dogdays  Offline
...or gut it and stick it back on the firewall...
Buzzer? We don't need no steenkin buzzer!
R.
Re: Your Guess to the test... [Re: dogdays] #1048551
08/08/11 08:30 PM
08/08/11 08:30 PM
USA
USA
i already had the interior out (and very happy with a mint floor!),
and from what I saw of those seat belt wiring, let alone I have a '73 Satellite SP interior with God knows what exactly buckets I have,
I assure you I won't be tryin to get the seat belt buzzer working.
Stick it on the fire wall with the connector near it, maybe.
But it starts and runs and drives now and I am not messing with the jumper.
Re: Your Guess to the test... [Re: ramairthree] #1048552
08/09/11 01:01 AM
08/09/11 01:01 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
You could clean it up, gut it (as suggested earlier), and jump it INSIDE the shell, so the connector could be plugged into it.
No martial arts skills required.
Down to just a blue car now.
Re: Your Guess to the test... [Re: ramairthree] #1048553
08/09/11 02:19 AM
08/09/11 02:19 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My 74 Duster had a relay very similar.
The 1974 seat belt interlock system would disable the starter if the seat belts were not clicked together. The front passenger seat had sensors in the seat bottom that sent a signal if they sensed any weight. An old mechanic told me that the system allowed 3 attempts before tripping the switch. The button on the relay "reset" the system.
