Page 1 of 3 1 2 3
Will a 3000lb electric wench #1048214
08/06/11 04:36 PM
08/06/11 04:36 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Will a 3000lb electric wench Pull my 3400lb car onto a trailer?? What lb rating is the avarage every one uses
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048215
08/06/11 04:53 PM
08/06/11 04:53 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Found this,,,,the link gives a table for ground effect percentages,,,and effort required,,,,,
Calculating Winch Loads
Total Weight = Vehicle Weight + Load weight
Winch Pull = ( <Slope degrees> * Total Weight /60)
Ground Factor Weight = Winch Pull * Ground Effect Percentage
Winch Load = Winch Pull + Ground Factor Weight
Example. Given:
* Vehicle weight = 4,400 pounds
* 300 pounds of total load weight
* winch up a 50 degree slope consisting of shallow mud
Total Weight - 4400 + 300 = 4700
Winch Pull - (50*4700/60) = 3917
Ground Factor Weight - 4,700 * 35% = 1645
Winch Load - 3917 + 1645 = 5562
http://www.4wd4all.com/forums/attachment...012&thumb=1
Re: Will a 3000lb electric wench [Re: 69CHARGERMD] #1048216
08/06/11 04:58 PM
08/06/11 04:58 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
not sure what the "slope" is your pulling your car up,,,,but,,,
eg,,if you use the 50* as below,, and your on pavement,,i think you would be ok...or close.....
Total weight = 3400
Winch pull = 50*3400/60 = 2833
Ground factor = (pavement) 3400 * 4% = 136
Winch load = 2833 + 136 = 2969
hope this helps....
Doug
Re: Will a 3000lb electric wench [Re: 69CHARGERMD] #1048217
08/06/11 05:04 PM
08/06/11 05:04 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
I dont think the sloap is even 60 deg its a flip down back door on the trailer, I also padded a couple of hundred lbs to the car its prob around 3200lbs
Re: Will a 3000lb electric wench [Re: 69CHARGERMD] #1048218
08/06/11 05:05 PM
08/06/11 05:05 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I use a 3000lb Superwinch to pull my 3250lb Duster on my open trailer. No problem at all.
Raul
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048219
08/06/11 05:10 PM
08/06/11 05:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most winches are rated to pull a vertical load...
as in your case 3000 lbs it should lift 3000 lbs
vertically... so when you induce a drag weight it will
pull MUCH more than the rated lift weight... I use
a 1500 lbs winch to pull my car up a pretty good angle
on my ramps.............. but I guarantee your 3000
lbs winch will pull your 3400 lbs car up a set of ramps
all day long
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048220
08/06/11 05:17 PM
08/06/11 05:17 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
You're calculating it backwards. The slope is the angle of the ramp to level ground, and is usually about 10° to 20° for trailer ramps. The 50° was just an example for winching a truck up a steep, muddy slope.
Total weight = 3400
Winch pull = 10*3400/60 = 567
Winch load = 567 + 136 = 703
Total weight = 3400
Winch pull = 20*3400/60 = 1134
Winch load = 1134 + 136 = 1270
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Will a 3000lb electric wench [Re: 67Charger] #1048221
08/06/11 05:19 PM
08/06/11 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You're calculating it backwards. The slope is the angle of the ramp to the ground, and is usually about 10° to 20° for trailer ramps. The 50° was just an example for winching a truck up a steep, muddy slope.
I dont think your talking to me on that
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048222
08/06/11 05:23 PM
08/06/11 05:23 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
I think you're calculating it backwards. The slope is the angle of the ramp off level, and is usually about 10° to 20° for trailer ramps. The 50° was just an example for winching a truck up a steep, muddy slope.
nope, 69CHARGERMD
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048223
08/06/11 05:26 PM
08/06/11 05:26 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Now i just need the rain to quit so i can go out and install my new toy,
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048224
08/06/11 05:30 PM
08/06/11 05:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just starting here(rain).... if you have a 3000 lb
winch it will pull 4500 lbs up a 45* slope(add 1/2
the rated weight... then if you want to figure the
rest of the angles.... go for it)
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048225
08/06/11 05:42 PM
08/06/11 05:42 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I just left 50* as a example...i assumed his angle was less than that...
thanks.
Re: Will a 3000lb electric wench [Re: 67Charger] #1048226
08/06/11 05:54 PM
08/06/11 05:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Total weight = 3400
Winch pull = 20° × 3400 ÷ 60 = 1134
Ground factor = (pavement) 3400 × 4% = 136
That looks better, but please note that the angle input is not proportionate to the actual forces. The usual test with a formula is to exaggerate a variable in both directions and see if the results make sense.
Here, a vertical pull would mean multiplying by 90, but 90 ÷ 60 isn't the vertical pull, it's much more.
I have a feeling that the variable you want is a trig function of the ramp angle, rather than the angle ÷ 60.
Example: with a 20° ramp, the variable should be .333 (20 ÷ 60). The sine of 20° is .342, pretty close (2.6% error).
Use 10°, should get .1666667 (10° ÷ 60). The sine is .174 (4.2% off)
Really steep ramps, like 45° and up, are where the angle/60 method begins to fail: 45 ÷ 60 = .75.
The sine of 45° is .707, a lower figure.
Using 60°: the above method says the load is 1.00 (same as vertical), but of course it isn't, it's probably the sine, .866.
Go to 90°: the sine of 90° is 1.0, so the calculation exactly equals a vertical pull (whereas the above method predicts 1.5).
If the winch is too small but has a long cable, just use a pulley (or more than 1). Running the line to a pulley at the load, then back to the winch almost doubles capacity (some minor loss through friction and cable bending). The cable length must be doubled, but of course if splicing it the added cable can safely be as small as 50% of the original rated load.
Boffin Emeritus
Re: Will a 3000lb electric wench [Re: RATTRAP] #1048227
08/06/11 05:56 PM
08/06/11 05:56 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
also what you need to know and is very important is the line speed. I just removed one that took so long to get the car into the trailer you could take a nap.
home of the
Sox and Martin Hemi Duster
Re: Will a 3000lb electric wench [Re: HEMIFRED] #1048228
08/06/11 06:14 PM
08/06/11 06:14 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I think i figured it out LOL...
(Im going to leave the math to you guys,,,lol)
Re: Will a 3000lb electric wench [Re: 69CHARGERMD] #1048229
08/06/11 06:33 PM
08/06/11 06:33 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Does anyone want to go out on a limb and recommend a winch
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Will a 3000lb electric wench [Re: BloFish] #1048230
08/06/11 06:43 PM
08/06/11 06:43 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Harbour Freight has a new line of winches and currently have a 5000lb unit on sale for I believe $250.
Re: Will a 3000lb electric wench [Re: MR_P_BODY] #1048231
08/06/11 06:54 PM
08/06/11 06:54 PM
Az
Crizila Offline
Crizila  Offline
Az
all day long
For sure. I pull a 4K car on to my trailer with a 3K winch with ease.
Fastest 300
Re: Will a 3000lb electric wench [Re: Blucuda413] #1048232
08/06/11 06:55 PM
08/06/11 06:55 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Warn and your safe
home of the
Re: Will a 3000lb electric wench [Re: HEMIFRED] #1048233
08/06/11 07:25 PM
08/06/11 07:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
My ATV had a small wench which was 1500 maybe 2000 lbs rated. It pulled my Dakota onto a flat bed open trailer a few times... No problems... if a 3000 wench cant do this, its JUNK.. I would avoid the cheaper harbor freight type wench's.
Page 1 of 3 1 2 3
