1990 plymouth laser rs #1047580
08/05/11 12:51 PM
08/05/11 12:51 PM
Ruby, Michigan USA
rabidue Offline OP
rabidue  Offline OP
Ruby, Michigan USA
anybody know anything about these cars? cant find a decent service manual for it. runs ok but there are some broken wires by the alternator that I cant figure out where they go. any help would be grateful
Re: 1990 plymouth laser rs [Re: rabidue] #1047581
08/05/11 01:16 PM
08/05/11 01:16 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Yes I know about DSMs, is it a 1.8, 2.0 N/A or 2.0 turbo?
Re: 1990 plymouth laser rs [Re: CokeBottleKid] #1047582
08/06/11 02:08 AM
08/06/11 02:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used to work on them years ago at the dealer. I have a manual on them around my house somewhere. I will try to find it. Ron
Re: 1990 plymouth laser rs [Re: 383man] #1047583
08/06/11 04:43 AM
08/06/11 04:43 AM
Iowa
P
plumcrazyb Offline
plumcrazyb  Offline
P
Iowa
Being a RS its probably a turbo, had two of them, father in law is still driving one.
http://www.dsmtuners.com/ Probably the best search engine and forum for these cars. FSM and haynes etc are pretty much all you need usually.
Let me know if you need more help, I have the FSM for electrical.
Re: 1990 plymouth laser rs [Re: plumcrazyb] #1047584
08/08/11 08:29 AM
08/08/11 08:29 AM
Ruby, Michigan USA
rabidue Offline OP
rabidue  Offline OP
Ruby, Michigan USA
thanks for the response. It is a rs but non-turbo. not sure how common that combination is. trying to locate the crank position sensor. I have a haynes manual for it but the book does not tell me where it is. any help would be grateful
Re: 1990 plymouth laser rs [Re: 383man] #1047585
08/08/11 08:31 AM
08/08/11 08:31 AM
Ruby, Michigan USA
rabidue Offline OP
rabidue  Offline OP
Ruby, Michigan USA
thanks Ron. If you can find it and are willing to sell it, let me know. I could really use it.
Re: 1990 plymouth laser rs [Re: CokeBottleKid] #1047586
08/08/11 08:34 AM
08/08/11 08:34 AM
Ruby, Michigan USA
rabidue Offline OP
rabidue  Offline OP
Ruby, Michigan USA
its a 2.0 dohc non turbo, automatic trans. 95k miles. runs like chit when it warms up. think it might be the 02 sensor but dont want to guess on this one. parts are hard to come by and not cheap.
Re: 1990 plymouth laser rs [Re: rabidue] #1047587
08/08/11 03:27 PM
08/08/11 03:27 PM
Iowa
P
plumcrazyb Offline
plumcrazyb  Offline
P
Iowa
If its a 1g 2.0 dual overhead cam 4g63 then it doesn't have a crank position sensor, its probably the camshaft angle sensor. You can adjust base timing with that. But as you said probably a good chance of a bad o2 or vacuum leak. They make loggers for the ob1 or you can use a buzzer to get the trouble code if there is one.
Won't let me post a picture, but just search for 1g cas in google.
