340 Block Cast Date #1047344
08/05/11 12:03 AM
08/05/11 12:03 AM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
What is the acceptable range for a cast date vs the build date for a 340 block?
If a block was cast in 5/69 could it be the original block for a car built in 11/69?
Thanks Matt
Re: 340 Block Cast Date [Re: Matt M] #1047345
08/05/11 12:08 AM
08/05/11 12:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Possible but not likely, most were assembled within a month of the casting date. Look on the front of the block (drivers side under the deck surface) the 10,000 day assembly date will be there, an assembly date that is within a few days or weeks prior to you cars SPD will be "most correct" in most peoples opinions.
Re: 340 Block Cast Date [Re: Matt M] #1047346
08/05/11 12:19 AM
08/05/11 12:19 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Wouldn't the easiest way be to check the VIN stamped on the block or are you concerned the block has been restamped?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 340 Block Cast Date [Re: 69CoronetRT] #1047347
08/05/11 12:29 AM
08/05/11 12:29 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I can't say if yours is correct or not, but its possible. But my 71 340 is an exception to what is considered correct. My 340 blocks julian date is July 8th 1970 and the cars SPD was in Oct 14th 1970.
Re: 340 Block Cast Date [Re: NV69B7RR] #1047348
08/05/11 12:33 AM
08/05/11 12:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Hey NV69B7RR
check your e-mail
Re: 340 Block Cast Date [Re: Matt M] #1047349
08/05/11 12:45 AM
08/05/11 12:45 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Could it... sure.
Not the norm but not outside the range.
seen some 71-72 cars with blocks cast in say jan and feb in cars SPD in the aug/sep ranges. Anything is possible.
Re: 340 Block Cast Date [Re: RobX4406] #1047350
08/05/11 12:48 AM
08/05/11 12:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My guess is a block with that casting date went into a 1970 model year car. get those numbers and you will know for sure.
Re: 340 Block Cast Date [Re: NV69B7RR] #1047351
08/05/11 12:49 AM
08/05/11 12:49 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
what is the casting date?
Re: 340 Block Cast Date [Re: ademon] #1047352
08/05/11 12:54 AM
08/05/11 12:54 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I'll look it up this weekend.
Re: 340 Block Cast Date [Re: 69CoronetRT] #1047353
08/05/11 09:55 AM
08/05/11 09:55 AM
USA
big-block-dave Offline
USA
Yes look at the vin#. What's all the other #'s on the block? I have a 6/30/69 SPD car looking for a close motor.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 340 Block Cast Date [Re: Matt M] #1047354
08/05/11 10:54 AM
08/05/11 10:54 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
A friend of mine had a 73 340 Cuda with the original motor that was cast 11/71. I figured it was the last year for the 340 so Chrysler used whatever was laying around. I dont remember any other dates on the car or block. It's been a few years ago.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: 340 Block Cast Date [Re: BradD] #1047355
08/05/11 11:01 AM
08/05/11 11:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
When it comes to engine casting dates vs assembly dates vs installation dates one needs to speak in general terms as far as what was the "norm" because there were MANY exceptions over the years. Proving possible exceptions to be indisputable facts all boils down to originallity and documentation.
Re: 340 Block Cast Date [Re: ScottSmith_Harms] #1047356
08/05/11 11:36 AM
08/05/11 11:36 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have found that any Mopar engine cast after 1969 could be used in cars up to 1974, those before the 70 model year usually are cast pretty close to 2 months before the SPD.
JB Rhinehart, Realist
A-Body's RULE!
Re: 340 Block Cast Date [Re: Rhinodart] #1047357
08/05/11 01:29 PM
08/05/11 01:29 PM
RobX4406 Offline
RobX4406  Offline
Wasn't any JIT inventory going on at chrysler back then... bell curve anyone?
Re: 340 Block Cast Date [Re: RobX4406] #1047358
08/05/11 10:31 PM
08/05/11 10:31 PM
Georgia
Matt M Offline OP
Matt M  Offline OP
Georgia
Guys
Thanks for all the replys
The reason for the post is I did get a photo of the VIN on the block, and It looks a little funky, but the photo is crap.
This is what my friend told me to look at also
"Possible but not likely, most were assembled within a month of the casting date. Look on the front of the block (drivers side under the deck surface) the 10,000 day assembly date will be there, an assembly date that is within a few days or weeks prior to you cars SPD will be "most correct" in most peoples opinions."
I need to get more information
The car is a 1970
Thanks again guys.
Matt
Re: 340 Block Cast Date [Re: Matt M] #1047359
08/05/11 10:53 PM
08/05/11 10:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
FYI, VIN # stampings were quite OFTEN poorly done, what you decribed doesn't surprise me at all. Post a decent pic of it and we can let you know what we think.
Re: 340 Block Cast Date [Re: ScottSmith_Harms] #1047360
08/05/11 11:44 PM
08/05/11 11:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
had a numbers match original 69 340 dart, block was cast in 11-67, as was the intake etc.
the vin numbers were correct, un altered Car had been parked since 74. Suprised me hope this helps
Re: 340 Block Cast Date [Re: TJP] #1047361
08/06/11 12:55 AM
08/06/11 12:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My best guess is that this is an original stamping, scrape the paint and take a better pic and I would have a stronger opinion one way or the other. Also, those numbers on the face of the block would come into play, get those as well.
