Re: 340 Block Cast Date
[Re: Matt M]
#1047346
08/05/11 12:19 AM
08/05/11 12:19 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
If a block was cast in 5/69 could it be the original block for a car built in 11/69?
Wouldn't the easiest way be to check the VIN stamped on the block or are you concerned the block has been restamped?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: NV69B7RR]
#1047351
08/05/11 12:49 AM
08/05/11 12:49 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I can't say if yours is correct or not, but its possible. But my 71 340 is an exception to what is considered correct. My 340 blocks julian date is July 8th 1970 and the cars SPD was in Oct 14th 1970.
what is the casting date?
[Re: Matt M]
#1047354
08/05/11 10:54 AM
08/05/11 10:54 AM
Posts: 543 Indiana, Just Off I-70
BradD
A friend of mine had a 73 340 Cuda with the original motor that was cast 11/71. I figured it was the last year for the 340 so Chrysler used whatever was laying around. I dont remember any other dates on the car or block. It's been a few years ago.
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: ScottSmith_Harms]
#1047360
08/05/11 11:44 PM
08/05/11 11:44 PM
Posts: 15,418 Omaha Ne
TJP
Omaha Ne
had a numbers match original 69 340 dart, block was cast in 11-67, as was the intake etc. the vin numbers were correct, un altered Car had been parked since 74. Suprised me hope this helps
