Re: Is a 4.30 rear end right for me? [Re: GTXKen] #104704
08/14/08 03:44 PM
08/14/08 03:44 PM
W/a 4.30 and a 27" tire, in an ideal world with no converter slippage at highway cruise, you'd be doing 3200rpm at 60mph. Can you live with that? Make sure you make that decision before you pull the trigger. Play around with this calculator here if you need help deciding.
http://vexer.com/68rt/speed.html
useful tool,(and fun) thanks for sharing
Thats AWESOME!
What is typical converter slippage at the high end? I cant see that there is NO slippage. there has to ve some
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104705
08/14/08 04:02 PM
08/14/08 04:02 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
The reason I was thinking of 4.30s over 4.10s or 3.91s is that you can find so many of them
Probably because the seller figured out that 4.30:1 was too much gear for their liking...
'69 Plymouth GTX
See you on the street...
Re: Is a 4.30 rear end right for me? [Re: Black_Sheep] #104706
08/14/08 04:06 PM
08/14/08 04:06 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
That sounds likely
I am running 3:55s and I couldn't imagine going to anything more than 3:91s on the street. Most of my driving is around town with some occasional highway driving.
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104707
08/14/08 05:09 PM
08/14/08 05:09 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
After I sell my 3.91's, I'll be going with 4.30's
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104708
08/14/08 06:58 PM
08/14/08 06:58 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
I have 3.55's and a fairbanks 2600-2800 stall converter, this works very well with my 284/484 with "fast-bleed" lifters. It is a GREAT combo and has TONS of low end torque. 440's don't need gear, just the right combination..........
Like many others have suggested, get a good 2800 converter first. If your idle vacuum is less than 13" at idle I would also recommend fast-bleed lifters to smooth it out and ADD torque.
Good luck,
Re: Is a 4.30 rear end right for me? #104709
08/14/08 07:10 PM
08/14/08 07:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Thats AWESOME!
Yeah I know, that calculator is great. I use it all the time. Best of all it was made by a moparts member, tho I can't remember his user name off hand.
I'm not 100% sure on the converter slippage issue. I think a stock converter is around 95% and aftermarkets are around 90 for a good quality unit, and low 80's for a cheapie. There's a slider bar on there for efficiency so you can experiment.
Re: Is a 4.30 rear end right for me? [Re: DaytonaTurbo] #104710
08/14/08 07:53 PM
08/14/08 07:53 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
4.30's? Hope you have a gas tanker truck following you around!
Re: Is a 4.30 rear end right for me? [Re: Kudakidd] #104711
08/15/08 05:44 PM
08/15/08 05:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run 4.30's in my 63 with my mild 440 and I love them. But I use a 29" tire as I wanted a fairly tall tire to fill the wheelwell. I drive it on the highway at 60 mph all the time and it tach's between 3000 to 3200 running 55 to 60 mph. I wanted the gear to still give me a good launch with the 29" tires. And I love it as I just drive at 60 mph on the highway and still have a great launch when I get to the track. And you would be surprised at the gas milage I get. But I dont care because if I did I am in the wrong hobby. Ron
Re: Is a 4.30 rear end right for me? [Re: MoparforLife] #104712
08/15/08 09:12 PM
08/15/08 09:12 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
For 100% street driving you will be much happier with a 3.91 than a 4.30. 4.30 is pretty deep for a street car. 3.91 at 60 mph will spin your engine approx. 3000. 4.30 a lot more than that.
The 4.30s would spin the engine 300 more RPM (3300)in your senario. Whether or not that is "a lot more" is up to interpretation.
Re: Is a 4.30 rear end right for me? [Re: mopowers] #104713
08/15/08 10:03 PM
08/15/08 10:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Looks good on paper. In the real world 300-500 makes a big differnce and it usually doesn't work out that way. That 4.30 to me just wouldn't be that nice to drive until you put about a 30+ inch tire on. Deepest I would go is a 3.91. Been there done that.
Re: Is a 4.30 rear end right for me? [Re: MoparforLife] #104714
08/15/08 11:50 PM
08/15/08 11:50 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have run 3.55, 3.91,and 4.30 on the street and track. I think you are on the right track by getting a quality converter in the 2800-3000 range. When I bracket raced my steet car, I swapped the chunks regularly and kept good records and the 4.30's were good for only 3-4 tenths with my combo. With a lot of torque, gears are not quite as critical, but deep gears just get to be a pain in the butt for all around driving. After years of experimenting and shelling ring gears at the track, I went to a Dana with 3.54's and have been very happy ever since. My .02.
Re: Is a 4.30 rear end right for me? [Re: DaytonaTurbo] #104715
08/16/08 12:14 AM
08/16/08 12:14 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
After nearly 18 years since the day I did it, this calculator gave me flashbacks of the time I had my 3.54 geared, 4-speed at 6000 RPM in 4th with 255-65 15's all around. I remember tunnel vision closing in around 135MPH, and the tunnel kept getting smaller the faster I went.
I thought I could hold it until it hit 6500 rpm, but when it hit 6000 prm, I took my foot out of it. Self preservation got the best of me. It wasn't until I got a rice rocket in the late 90's that I broke that personal top speed record.
Wow, what a rush. I'll always believe Mopars were made to dominate the half mile, as well as, the quarter. The real fun is just begining when you pass the quarter mile mark and bang it into 4th, the front end lifts back up and your glued to the seat!
Thanks for the memories!
Re: Is a 4.30 rear end right for me? #104716
08/26/08 10:24 PM
08/26/08 10:24 PM
Re: Is a 4.30 rear end right for me? [Re: Sledge_57] #104717
08/26/08 10:50 PM
08/26/08 10:50 PM
I like my 4.30's however if I wanted to drive 60mph on the freeway I'd go back to 3.91
Mines spins 3000 at 50mph with 275-60-15 tires and a 9 1/2" PTC 4200 converter. Cruisin at 60mph ain't happening for me with the 4.30's
i checked my 4.30s out this weekend. I can do 55 mph at 3000 rpm. but my converter stalls lower than yours- around 3200.
Re: Is a 4.30 rear end right for me? [Re: DaytonaTurbo] #104718
08/27/08 01:48 AM
08/27/08 01:48 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
To much gear for a street car, go with 391`s if you must have a somewhat low gear.
Re: Is a 4.30 rear end right for me? [Re: SCATPK] #104719
08/27/08 02:30 PM
08/27/08 02:30 PM
P
Paul_Fancsali Offline
P
I drive 110 miles to track and back with4.30s and 28.5 tall street tires. Done it with 24.5 street tires too the gas mileage is 10-11mpg not good but what do you want??? The one thing to consider is the weight of the car my car is heavy and needs the gear to get moving with a small block I ran 3.91s in the car for close to 15 years the 4.30s gave me the .25 I wanted so they stay. I have a set of 3.91 sure grip which I may install but have been leaning toward 4.56s
Re: Is a 4.30 rear end right for me? [Re: Paul_Fancsali] #104720
08/27/08 10:46 PM
08/27/08 10:46 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
4.30 is a great gear for a B-body! The 2.75 r60's are about 28" which is a good diameter. It may seem much at first but you'll get used to it fast...especially if you're going to run it a lot. You will have to practice your hole shot but there won't be many on the street that will stay with you off the line.
