Is a 4.30 rear end right for me? #104684
08/14/08 10:56 AM
08/14/08 10:56 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
1970 GTX, original 440/727. Has the old 284/484 purple cam. Stock compression forged pistons, ported 906's shaved 0.020", FBO ignition, Eddy intake, Holley 750 DP. I currently have a 3.55 but have very little low end power with this cam. I'm sure the torque converter is part of the problem but I plan on replacing that too. I drive the car 100% street with most of that in town. When I hit the highway I am content driving 60 mph.
So, with this motor what would you think about dropping in a 4.30 and a converter that flashes about 2800???
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104685
08/14/08 11:03 AM
08/14/08 11:03 AM
i love my 4.30's. especially with the 284/484 cam.
put a higher stall converter in it and LET ER RIP! You'll say "YEEEEEEEEEEEEEEHAAAAAAAAAAAAAAA!"
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104686
08/14/08 11:05 AM
08/14/08 11:05 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would get a 10 inch converter in there and leave the rear alone.
Re: Is a 4.30 rear end right for me? [Re: buildanother] #104687
08/14/08 11:08 AM
08/14/08 11:08 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Swap the convertor first, then see if you like the results before putting in gears.
Ride eternal, shiny and chrome
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104688
08/14/08 11:09 AM
08/14/08 11:09 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Just making sure. You haven't had a converter built around the 3.55s and are going to 4.30s, right? You will be getting the converter tailored to 4.30s?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Is a 4.30 rear end right for me? [Re: GoodysGotaCuda] #104689
08/14/08 11:23 AM
08/14/08 11:23 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The converter in there now was supposed to be the 340 converter. I don't think that's what I got though. Others around here that are using them have a lot better luck than I do. I will be getting a new converter, something very street friendly.
I did pony up the cash for a PTC from Kenny for the Demon (3600 flash) and it's great on the track, drivable on the street but I think one like that is a little to much for this car. Thinking maybe ~2800-3000ish??
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104690
08/14/08 11:29 AM
08/14/08 11:29 AM
Pittsburgh, Pa
Jeff_383 Online content
Jeff_383  Online Content
Pittsburgh, Pa
What does the coverter flash to now, and how was the that cam installed? Advanced, straight up?
Re: Is a 4.30 rear end right for me? [Re: Jeff_383] #104691
08/14/08 11:56 AM
08/14/08 11:56 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
For 100% street driving you will be much happier with a 3.91 than a 4.30. 4.30 is pretty deep for a street car. 3.91 at 60 mph will spin your engine approx. 3000. 4.30 a lot more than that.
Re: Is a 4.30 rear end right for me? [Re: buildanother] #104692
08/14/08 12:10 PM
08/14/08 12:10 PM
Columbia Station, Ohio
69RTSE Offline
69RTSE  Offline
I have a Comp cams .507/.510 lift hydraulic cam, iron heads with big valves, TM7 intake and 750 BG carb, 3400 converter. With slicks and 4.10s in my 69 Charger I went 12.20s. With street tires (275/60-15 GY Eagle Sts) and 3.23s it went 12.80s. I really like the 3.23s now, great for cruising. Don't forget a tranny cooler with the higher stall converter.
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104693
08/14/08 12:23 PM
08/14/08 12:23 PM
Stuart, FL
Grassosgarage Offline
Stuart, FL
4.30 + 275/75/15 tire + your 440 combo =
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: Is a 4.30 rear end right for me? [Re: Grassosgarage] #104694
08/14/08 12:40 PM
08/14/08 12:40 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Right now I have 275/60-15 with 3.55's. I'm guessing my converter hooks up at 2000-2200ish. My tach isn't accurate (electronic ignition).
I know this isn't the best indication but when I power brake the car it breaks loose at about 2000-2100.
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104695
08/14/08 12:45 PM
08/14/08 12:45 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The reason I was thinking of 4.30s over 4.10s or 3.91s is that you can find so many of them. I had a really hard time finding a 3.91 for my Demon. And 4.10s seem impossible to find.
Re: Is a 4.30 rear end right for me? [Re: VITC_GTX] #104696
08/14/08 12:46 PM
08/14/08 12:46 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
go with a 4000 stall converter. 3:55s are great on the street.
Re: Is a 4.30 rear end right for me? [Re: MoparforLife] #104697
08/14/08 01:13 PM
08/14/08 01:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
For 100% street driving you will be much happier with a 3.91 than a 4.30. 4.30 is pretty deep for a street car. 3.93 at 60 mph will spin your engine approx. 3000. 4.30 alot more than that.
My small block Dart had 3.91s in it and I went to 4.30s and saw very little difference in et, something like .06 in 60' IIRC. On the street I can tell a huge difference, I run 275/60 ET Streets. Power braking will not tell you the stall of you're converter. At a slow speed in high gear floor board it, the tach will flash to the converters stall rpm. My 9.5" 4400 will only power brake to about 2800 rpm.
Re: Is a 4.30 rear end right for me? [Re: justinp61] #104698
08/14/08 01:36 PM
08/14/08 01:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
W/a 4.30 and a 27" tire, in an ideal world with no converter slippage at highway cruise, you'd be doing 3200rpm at 60mph. Can you live with that? Make sure you make that decision before you pull the trigger. Play around with this calculator here if you need help deciding.
http://vexer.com/68rt/speed.html
Re: Is a 4.30 rear end right for me? [Re: DaytonaTurbo] #104699
08/14/08 01:39 PM
08/14/08 01:39 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
daytona-
i love that thing! it is very useful to pick your 4speed ratios too. very cool!
Re: Is a 4.30 rear end right for me? [Re: nutso suave] #104700
08/14/08 03:11 PM
08/14/08 03:11 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I would do the converter first. Have it made for the car not what you think it need.
Re: Is a 4.30 rear end right for me? [Re: AdamR] #104701
08/14/08 03:17 PM
08/14/08 03:17 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
A convertor for 3.55s may not be what you need for 4.30s.
Re: Is a 4.30 rear end right for me? [Re: AdamR] #104702
08/14/08 03:21 PM
08/14/08 03:21 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I like my 4.30's however if I wanted to drive 60mph on the freeway I'd go back to 3.91
Mines spins 3000 at 50mph with 275-60-15 tires and a 9 1/2" PTC 4200 converter. Cruisin at 60mph ain't happening for me with the 4.30's
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Is a 4.30 rear end right for me? [Re: DaytonaTurbo] #104703
08/14/08 03:24 PM
08/14/08 03:24 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
useful tool,(and fun) thanks for sharing
