you guys add anything in water for your alum heads/rad. #1046895
08/03/11 10:15 PM
08/03/11 10:15 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i got brand new alum rad. and the alum heads wonder if you guys add anything to it?
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: you guys add anything in water for your alum heads/rad. [Re: toplescuda] #1046896
08/03/11 10:40 PM
08/03/11 10:40 PM
IN
ahy Offline
ahy  Offline
IN
I use distilled water 50/50 with extended life Prestone anti-freeze. 5+ years and no signs of corrosion or cooling performance loss with one coolant change.
Re: you guys add anything in water for your alum heads/rad. [Re: ahy] #1046897
08/03/11 11:18 PM
08/03/11 11:18 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Everything except the race car gets distilled water & anti-freeze, 50/50, plus a bottle of Water Wetter. Race car omits the anti-freeze. The cars with aluminum heads and/or radiator also have a zinc anode in them.
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046898
08/04/11 02:01 AM
08/04/11 02:01 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
how many gallons total will a empty hemi and 3 core alum rad. hold??can you buy this anode thing at parts store?
1971 charger
Re: you guys add anything in water for your alum heads/rad. [Re: toplescuda] #1046899
08/04/11 01:31 PM
08/04/11 01:31 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Water Wetter
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046900
08/04/11 08:57 PM
08/04/11 08:57 PM
IN
ahy Offline
ahy  Offline
IN
I'll guess 3-4 gallons. Two gallons each of anti freeze and water should cover it. Anodes I've seen screw into the lower radiator tank in place of the drain petcock. Don't know where to get them... I'd try Summit.
Re: you guys add anything in water for your alum heads/ [Re: ahy] #1046901
08/04/11 10:16 PM
08/04/11 10:16 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
went to local parts store...had no clue what i was talking about and said...if its not in the self help then we dont have it
1971 charger
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046902
08/04/11 11:20 PM
08/04/11 11:20 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I got the anodes off of Ebay.They fit in place of the drain valve.
Nautilus Racing-
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046903
08/04/11 11:21 PM
08/04/11 11:21 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: you guys add anything in water for your alum heads/ [Re: Ply72rr] #1046904
08/05/11 07:16 AM
08/05/11 07:16 AM
distilled (not demineralized) water/good green antifreeze (iirc the GO-5 even better)/zinc anode/several drops of liquid dish soap (cheap water wetter,reduces surface tension for better heat transfer). 2 gal of AF will b enough (50/50 protects to -35 F below zero). Ply72rr thanks for the anode link as I need to get one
Re: you guys add anything in water for your alum heads/ [Re: RapidRobert] #1046905
08/05/11 12:30 PM
08/05/11 12:30 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
im not worried so much about the anti freeze as the car has a heated garage car is never left outside
just wanted something to keep from eat/coroding the heads new rad.
1971 charger
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046906
08/05/11 12:49 PM
08/05/11 12:49 PM
dogdays Offline
dogdays  Offline
Well with that kind of an engine ($$$$) I'd be SURE to run antifreeze. Stranger things can happen and you leave the car at the side of the road and it freezes overnight. You are incapacitated and your help is out of town. You can probably imagine 30 different ways to have it happen.
In my long-term storage is a ford model B engine that froze in August. They had just gotten it back from the machine shop, put it back in the B pickup, were intending to start it (water in the radiator) when Ma called them in for supper. It got late and they didn't think to drain the block. That engine never ran, still has the brand-new oversize pistons in it.
"A word, to the wise, is sufficient."
R.
Re: you guys add anything in water for your alum heads/ [Re: dogdays] #1046907
08/05/11 02:10 PM
08/05/11 02:10 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
it will have a gal. of anti freeze in it but no reason to as said before it has its own heated garage under the house it does not go out side unless it is really nice no chance of rain
in 10 years the car has seen rain one time(in front of the garage)
its angies pride and joy and she pampers the heck out of it lol
just got back from buying some red line water wetter to add to it
1971 charger
Re: you guys add anything in water for your alum heads/ [Re: toplescuda] #1046908
08/05/11 09:54 PM
08/05/11 09:54 PM
IN
ahy Offline
ahy  Offline
IN
The anti-freeze also carries the corrosion protection additives designed for a 50/50 mix. With a big investment in the engine and big expensive aluminum parts I'd give it as much corrosion protection as possible.
Re: you guys add anything in water for your alum heads/ [Re: ahy] #1046909
08/05/11 10:20 PM
08/05/11 10:20 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
run a 1:1 mix of a high quality anti-freeze and distilled or de-mineralized water. Do not run straight water as it will corrode the hell out of anything metal in the engine.
