you guys add anything in water for your alum heads/rad.
#1046895
08/03/11 10:15 PM
08/03/11 10:15 PM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i got brand new alum rad. and the alum heads wonder if you guys add anything to it?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: you guys add anything in water for your alum heads/
[Re: toplescuda]
#1046898
08/04/11 02:01 AM
08/04/11 02:01 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
how many gallons total will a empty hemi and 3 core alum rad. hold??can you buy this anode thing at parts store?
[Re: toplescuda]
#1046900
08/04/11 08:57 PM
08/04/11 08:57 PM
Posts: 7,664 IN
ahy
IN
I'll guess 3-4 gallons. Two gallons each of anti freeze and water should cover it. Anodes I've seen screw into the lower radiator tank in place of the drain petcock. Don't know where to get them... I'd try Summit.
[Re: ahy]
#1046901
08/04/11 10:16 PM
08/04/11 10:16 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
went to local parts store...had no clue what i was talking about and said...if its not in the self help then we dont have it
[Re: toplescuda]
#1046902
08/04/11 11:20 PM
08/04/11 11:20 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I got the anodes off of Ebay.They fit in place of the drain valve.
[Re: toplescuda]
#1046903
08/04/11 11:21 PM
08/04/11 11:21 PM
Posts: 553 DE
Ply72rr
DE
[Re: Ply72rr]
#1046904
08/05/11 07:16 AM
08/05/11 07:16 AM
RapidRobert
distilled (not demineralized) water/good green antifreeze (iirc the GO-5 even better)/zinc anode/several drops of liquid dish soap (cheap water wetter,reduces surface tension for better heat transfer). 2 gal of AF will b enough (50/50 protects to -35 F below zero). Ply72rr thanks for the anode link as I need to get one
[Re: RapidRobert]
#1046905
08/05/11 12:30 PM
08/05/11 12:30 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
im not worried so much about the anti freeze as the car has a heated garage car is never left outside just wanted something to keep from eat/coroding the heads new rad.
[Re: dogdays]
#1046907
08/05/11 02:10 PM
08/05/11 02:10 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
it will have a gal. of anti freeze in it but no reason to as said before it has its own heated garage under the house it does not go out side unless it is really nice no chance of rain in 10 years the car has seen rain one time(in front of the garage) its angies pride and joy and she pampers the heck out of it lol
just got back from buying some red line water wetter to add to it
