Dual throttle springs #1046461
08/03/11 11:22 AM
08/03/11 11:22 AM
wisconsin
1BAD68 Offline OP
1BAD68  Offline OP
wisconsin
How many of you are using two throttle return springs?
I hammer my gas pedal frequently and wonder when my single spring will break and destroy my engine.
Tried using two springs but it made the pedal stiff and jerky when just driving normal.
One spring or two?
single choice
Votes accepted starting: 08/03/11 10:21 AM
You must vote before you can view the results of this poll.
Re: Dual throttle springs [Re: 1BAD68] #1046462
08/03/11 11:24 AM
08/03/11 11:24 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Safety first - hence Ma using two springs on the throttle - good leg work out ! ha ha ha
Cheers
Mark
Re: Dual throttle springs [Re: 1BAD68] #1046463
08/03/11 11:38 AM
08/03/11 11:38 AM
NY usa
540challenger Offline
NY usa
I first tried the dual spring kit that comes with 1 large and 1 small spring that passes through the larger when installed. The pedal was to stiff IMO.
I purchased this one thorugh jegs.
http://www.jegs.com/i/JEGS+Performance+Products/555/15228/10002/-1
I like it plus you can adjust the tension since too.
Re: Dual throttle springs [Re: a12rag] #1046464
08/03/11 11:44 AM
08/03/11 11:44 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I agree that 2 springs make the pedal a little stiffer than I'd like, but I found just 1 spring sometimes isn't enough to bring the carb back to the idle stop every time.
Re: Dual throttle springs [Re: 1BAD68] #1046465
08/03/11 12:37 PM
08/03/11 12:37 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
We use 2 springs on the race car. The 1st setup was very stiff, so we moved it around, adjusting it so it wasn't as stiff, but still pull the throttle so it snaps back. At the track we race at the 1st turn off is a sign "500 feet" till the end of the track/last turn off. Then a sand pit, then a river and I don't like swimming.
Re: Dual throttle springs [Re: aquamist60] #1046466
08/03/11 12:42 PM
08/03/11 12:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Double springs on everything; you can get one of those assortments in the "help" section at the auto parts store and use a lighter spring inside the main spring or at another location and it won't be too stiff. Or one of the double setups on non-restoration cars. It just needs enough tension to close the butterflies.
Re: Dual throttle springs [Re: topside] #1046467
08/03/11 01:20 PM
08/03/11 01:20 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Years ago when I was a wee boy I used one spring and it broke while I was showing off going in reverse. The brakes would not stop the car. I totaled a Toronado and a wall and broke my leg, in the process. My brother was on top of the car and got tossed when I hit the wall.
Coulda been worse if some one were standing in the way. Not a shining moment. Use two springs.
I have mechanical Aptitude.
I can screw up anything.
Re: Dual throttle springs [Re: bboogieart] #1046468
08/03/11 01:25 PM
08/03/11 01:25 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
With all due respect, there is more wrong with that than the lack of an additional spring. LMAO
Re: Dual throttle springs [Re: 1BAD68] #1046469
08/03/11 01:25 PM
08/03/11 01:25 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Try two slightly weaker springs.
Re: Dual throttle springs [Re: Dodgeguy101] #1046470
08/03/11 01:35 PM
08/03/11 01:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
LMOA now but not then.
You bet, and is stupid, and so were we, but the spring did break and some cause trouble. Guess it was bound to happen the way we played. At least I have survived my stupid faze. Like I said not a shining moment.
Re: Dual throttle springs [Re: bobs66440] #1046471
08/03/11 02:02 PM
08/03/11 02:02 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
x 2 ... it is has been a while since I bought a set but the pair I got a while ago did not increase pressure much at all. And they separately returned the throttle back fine.
Re: Dual throttle springs [Re: dOOc] #1046472
08/03/11 02:12 PM
08/03/11 02:12 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I have 2 springs on mine and it isn't hard to push down. Ronnie
Re: Dual throttle springs [Re: bobs66440] #1046473
08/03/11 02:18 PM
08/03/11 02:18 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Or use the 'srong' spring you already have and go to the local Autozone, Advanced, Etc. In the HELP! section they carry a universal sping that is cut-to-fit. Make it the 'weak spring'
I have the Locar set-up. My 'Primary' spring is on the carb, but the 'seconday' or back-up is on the lever arm of the Transmission. So it is hidden. Still does the job though.
Just my pennies,
CC.
Re: Dual throttle springs [Re: chargincharles] #1046474
08/03/11 02:43 PM
08/03/11 02:43 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I still have my FACTORY spring, and DAMN!! THAN THING IS STIFF SO STIFF THAT MY KNEE GET HURTS, specially traveling in the country... maybe metal its somehow cristalized. Got a new one to replace it but engine is not build yet
Re: Dual throttle springs [Re: NachoRT74] #1046475
08/03/11 03:52 PM
08/03/11 03:52 PM
scratchnfotraction Offline
to much spring wears the shaft/bushings on the carb at a fast rate.
one reason most carbs need the shafts bushed when rebuilt
I use one medium spring on mine,i am always ready to kill the switch if it sticks WOT
Re: Dual throttle springs [Re: scratchnfotraction] #1046476
08/03/11 06:33 PM
08/03/11 06:33 PM
Under My Car
Mopar_Country Offline
Under My Car
Two springs set up properly will not be hard to push. I can't tell the difference on mine at all, you just need the right combo of springs.
Re: Dual throttle springs [Re: Mopar_Country] #1046477
08/03/11 06:37 PM
08/03/11 06:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
ACE hardware carries a large assortment of springs that would work. I'm using two of them and one fits inside the other without making the accelerator hard to push.
scratchnfotraction, you really do need two springs because as fast as you are you may still be too slow.
Re: Dual throttle springs [Re: Mopar_Country] #1046478
08/03/11 06:48 PM
08/03/11 06:48 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Two light springs, one slightly stronger than the other and pulling from the opposite direction and on the opposite side of the throttle shaft, can help offset a throttle cable and a single spring's constant pull and wear on the throttle shaft bushings.
When properly sized and located, they help counter each others tendency to pull the throttle shaft into the bushing.
Some carbs have a return spring built into the throtle shaft.
Re: Dual throttle springs [Re: jbc426] #1046479
08/03/11 08:47 PM
08/03/11 08:47 PM
Maryland
cudaboone Offline
cudaboone  Offline
Maryland
I run 2 springs on my 1050 dominator. One (1) is not worth the risk and i does not feel overly hard to push.
Re: Dual throttle springs [Re: jbc426] #1046480
08/03/11 11:05 PM
08/03/11 11:05 PM
100%
