Things to be aware of when inspecting a 68 Hemi GTX..? #1045703
08/02/11 10:51 AM
08/02/11 10:51 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
I am looking at getting into the B-body crowd and thus far have been involved with E-Bodys more than anything else, so I am looking for some advice when going to check out a potential 68 Hemi GTX.
Mod- if there is a better forum please let me know.
Thanks in advance for the advice. Here's a link to the car in question
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWAX%3AIT
-C
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: ramman5600] #1045704
08/02/11 01:39 PM
08/02/11 01:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Paging Scott Harms Smith.. And all the other Knowledgable 68 Hemi B body guys...
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: ramman5600] #1045705
08/02/11 01:54 PM
08/02/11 01:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
J-code in VIN, #s may be stamped @ bellhousing near oil PSI sender, K-member skid plate, reinforcements at leaf springs, 3/8" fuel line, engine harness along rt valve cover with big plug & single plug, trans cooler on 727 cars, 3-speed/variable style wiper motor, 26" rad & shroud on Hemis...those are the easiest to see. No A/C or dash vents for same.
'68 Hemi cars also had specific owner's manuals.
'68 GTX VINs start with RS. They had rocker moldings, side stripes (check door edges & jambs for evidence), XHD rear springs, of course the cast trunklid panel & deep grille & bucket interior with woodgrain inserts on the dash & door/qtr trim panels.
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: ramman5600] #1045706
08/02/11 06:22 PM
08/02/11 06:22 PM
ohio
silverhemiboy Offline
ohio
I believe early 68's had 66 blocks. Check the carbs are they original or the edelbrocks. There should be a stamped serial number on the radiator sub frame. Should have a dana rear with the four speed. I believe there should be a 73 on the trim tag in tha lower left corner after the carline and body type (Roadrunner would be RM 21).
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: silverhemiboy] #1045707
08/02/11 08:13 PM
08/02/11 08:13 PM
Michigan, USA
Michigan, USA
Any value in the Galen report he mentions in the ad?
-C
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: ramman5600] #1045708
08/02/11 10:47 PM
08/02/11 10:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, engine code 73, and commonly cast in '66. In case I wasn't clear about the block VIN stamping, some are not stamped but look for 8 digits, like 8('68model)/alpha(plant)/000000 (last 6 of VIN). 727 car would originally have an 8.75 rear. Eddy carbs won't fit the stock Hemi air cleaner base, air cleaner rings are too big.
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: topside] #1045709
08/02/11 11:11 PM
08/02/11 11:11 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
radiator support and left side under under the trunk weatherstip, should have the SO number stamped.
Also there is an "extra support" plate for the rear axle pinion bump stop in Hemi cars.
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: ramman5600] #1045710
08/03/11 09:50 AM
08/03/11 09:50 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
-C
Re: Things to be aware of when inspecting a 68 Hemi GTX..? [Re: Commando1] #1045711
08/03/11 12:15 PM
08/03/11 12:15 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
C'mom commando, if you are lucky he will remember that he's 'documented' the car and won't molest it at a car show. That's gotta be worth something!
