Re: hard brake pedal ,no stop
[Re: dvw]
#1045441
08/01/11 11:59 PM
08/01/11 11:59 PM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi on the 66 i think you need a master cyl from a c body to get the correct preasure to the wheel cyl . and maby some larger wheel cyl . does the 70 have a proportioning valve ? also old hoses cause problems !get new !
[Re: dvw]
#1045442
08/02/11 12:01 AM
08/02/11 12:01 AM
moparpollack
Lil Herman
Lil Herman
85086
[Re: DAYCLONA]
#1045444
08/02/11 07:38 AM
08/02/11 07:38 AM
Posts: 114 Adelaide Australia
peter
Adelaide Australia
i have just done the same thing and have the same problem ive in stall hemi style brake booster and disc brakes when i drive the car ive got use both feet to try and get it to pull up pete
[Re: dvw]
#1045446
08/02/11 11:30 PM
08/02/11 11:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The push rod adjustment has been to long,to short,and right on. Pads are not the issue,it won't even stop well at an idle. I believe the booster is bottomed before the master has enough travel. Could a drum booster have shorter travel than a disc booster? Come to think of it this is the 3rd car I've known of with this problem. The 3rd car was a 69 Hemi Charger Originally power drum brakes converted to disc. The booster was removed and converted back to manual disc. Problem solved. Removing the power brakes on this car is not an option. Doug
Let's assume everything is A-OK, as far as the install and mechanical soundness of the parts,...is this car an automatic?....a healthy cam lift?, if so what is the engine vac at idle?, if it's under 12"vac, you need a vacumm resv./assist pump,...been there done that
[Re: DAYCLONA]
#1045447
08/03/11 05:35 AM
08/03/11 05:35 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
After what my brother just went through with his drum brakes on his Barracuda, I wouldn't overlook the pads depending on where they came from. He put new drums and shoes on the front of his 65 and it would not stop, like scary not stop. He pulled them back down and the shoes still looked new, he slapped his old shoes back on just to see and voila, stopping on a dime. A new set of Wagner shoes and he's good to go. The offending shoes were from Autozone. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#1045448
08/03/11 03:42 PM
08/03/11 03:42 PM
Posts: 740 Anderson, IN
1969RR
Anderson, IN
Hello, Did a 70 Challenger last year, and just today, finished a 71 Cuda...exact issue you are having!! 1st the Challenger. If you are using the valves from a 70 (two separate valves) make darn sure the lines are hooked correctly. Believe me, you can hook them up wrong! That was my problem. Could not get the car to bleed. Had a hard pedal tho. Switched the lines to the correct positions, problem solved. Now, the 71 Cuda from today. Kit came from Inline. It is to use the 70 valves. Shouldn't make a difference tho. Anyway, couldn't for the life of me get fluid to the rear. Bled, and bled..no luck. Ended up being a collapsed rear hose. Why it worked with the drum...I don't know. Replaced hose, all's good. When you are bleeding, crack open fitting closest to master and work your way back. I bet you'll find the problem. Take care, Jeff
[Re: DAYCLONA]
#1045449
08/03/11 06:28 PM
08/03/11 06:28 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Or manual brakes. I have the same issue, I'm about to drop the booster.
[Re: Mopar_Country]
#1045450
08/03/11 08:17 PM
08/03/11 08:17 PM
RapidRobert
At this point, me I'd hookup a 1500-2000 psi gauge to the 4 corners & see if it's a psi or a pad/lining prob. You can get a 5" round gauge in that range for 10-$15 plus need several fittings to adapt it (I think the gauge is 1/4" male NPT)
[Re: phantomx]
#1045451
08/03/11 09:46 PM
08/03/11 09:46 PM
Posts: 1,294 Under the big sky
stateline
Under the big sky
How are the carbon metallic shoes Firm Feel sells ?? Ive been having poor stopping on my street rod, Im sure its the shoes on it
[Re: dvw]
#1045453
08/04/11 12:06 AM
08/04/11 12:06 AM
Posts: 18,157 Mass
DAYCLONA
Mass
It does have the stock drum brake valves. Doug
get rid of the drum distribution block, use the correct proportioning valve,... are you using a drum/drum master or the correct disc/drum master?????????
[Re: TheRamMan]
#1045458
08/05/11 02:50 PM
08/05/11 02:50 PM
Posts: 543 Indiana, Just Off I-70
BradD
A POWER DRUM booster will not work with disc brakes! We just went through this on a 68 Charger R/T. We put all of the disc brake parts on the car except for the original Power drum booster that was originally on the car. We had a hard pedal but the car was not stopping well. Changed to a Power Disk booster and stops great now.
Brad Dorn Restorations
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
