Cam is very mild,218@.050". Has well over 12" vacuum. There is plenty of fluid flow out of the rear bleeders. Pads were switched last summer with no improvement. I'm going to rig up a pressure gauge this weekend. It does have the stock drum brake valves. I may rig a temporary line from the master to the rear axle as well.
Doug
