Page 3 of 4 1 2 3 4
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044958
08/23/11 04:41 PM
08/23/11 04:41 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
hit everything with 2 coats of zero rust today.
Resto Rick sells an awesome product! thinned it down a bit and it sprayed super easy. Also allowed me to test out my new HVLP guns.
I've got the air set to where the literature says to...I might do some more experimenting though...air pressure just seems too low, and I don't get a lot of atomization of this paint. maybe it's too thick, maybe I need more air, not sure yet. it sprayed ok, and I wasn't too worried about it being that it's just going on the "hidden areas" but when it comes time to paint, I think I'll want a "finer" mist pattern. I was using the 1.3 tip today too.
after this dries good and hard for a day or so, I'll start adding the re-popped panels back on!
**Photobucket sucks**
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044959
08/23/11 04:42 PM
08/23/11 04:42 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
another angle
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044960
08/23/11 05:32 PM
08/23/11 05:32 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
another angle
How hard is it to remove that stuff? Looks like your window roller got a liberal dosing of it.
We had a primer that was so hard once you couldn't scratch it off with a screw driver.
Re: 1970 Blues Cuda "Rejuvination" [Re: moparpollack] #1044961
08/24/11 08:43 AM
08/24/11 08:43 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
it dries pretty hard. I wasn't too worried about the roller guide for the window. that was such a loose and sloppy fit before, that I doubt it'll block the roller from movement, and after it dries for awhile, it'll be so hard that it shouldn't gum it up.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044962
08/25/11 05:59 PM
08/25/11 05:59 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
it's on now!
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044963
08/25/11 06:00 PM
08/25/11 06:00 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
the back corner. tucked up nicely. I was worried when trying to fit it, this area was giving me some trouble. had to move the tail panel flange in a bit, as well as the flange on the quarter to allow the edges to "tuck" together.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044964
08/25/11 06:02 PM
08/25/11 06:02 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
nice...you can see my "gobs of seam sealer" through the tail light hole....is that as good as factory?
here's the upper edge. I fabricated patches for the window channel and the trunk gutter area on the deck filler piece. managed to get an acceptable seam there, I think good enough for a little filler....plus, with the lid closed...you'll never see it anyway.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044965
08/25/11 06:03 PM
08/25/11 06:03 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
another angle of the quarter seam with the trunk gutter piece. AMD for the gutter piece, goodmark quarter.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044966
08/25/11 06:04 PM
08/25/11 06:04 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
body lines look pretty good. a skim coat of filler at the door and quarter, and some block sanding, and it'll be perfect (I think!)
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044967
08/25/11 06:05 PM
08/25/11 06:05 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
door seam--not the greatest job, but with some seam sealer, maybe a little filler it'll be ok I think
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044968
08/25/11 06:06 PM
08/25/11 06:06 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
end result -- 100 times better than the rusty crusty panel I had before.
now, to grind down the welds, add some seam sealer and get to work on the other side.
it's a "quarter panel" so...I'm 25% of the way done, right?!
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044969
08/25/11 06:13 PM
08/25/11 06:13 PM
85086
Lil Herman
Lil Herman
85086
How did the trunk lid line up? The rear valance etc? When I did the quarter on my dart I thought it looked good. Boy am I glad it fitted everything than welded.
Re: 1970 Blues Cuda "Rejuvination" [Re: moparpollack] #1044970
08/25/11 09:05 PM
08/25/11 09:05 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
trunk lid is great. I bolted it on as I was moving the panel around, then removed it again to weld the quarter.
I can't hang the valence because there's nothing left of the other side to hang it to!
the trunk floor extension/quarter panel was so rusted away and previous owner filled with bondo and sculpted it, that when I did the trunk floor, that part of the quarter panel basically fell off!
the lip to the driver side trunk extension and quarter panel is left un-welded right now (all th way up to the rear wheel well actually), in case I need to try to move them around after I get the passenger side on, to widen or narrow the gap to hang the valence.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044971
08/25/11 11:10 PM
08/25/11 11:10 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Looking good!
Re: 1970 Blues Cuda "Rejuvination" [Re: FuryUs] #1044972
08/27/11 06:35 PM
08/27/11 06:35 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Looks good!
Ah, you can work the valence if you have to anyway, you can always cut the end off and reweld it....
Re: 1970 Blues Cuda "Rejuvination" [Re: wally426ci] #1044973
08/28/11 11:29 AM
08/28/11 11:29 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Great progress so far!! Keep up the good work.
Re: 1970 Blues Cuda "Rejuvination" [Re: NV69B7RR] #1044974
08/28/11 09:24 PM
08/28/11 09:24 PM
KS
68SportSatvert Offline
KS
Looks GREAT! The problem with the flow of the Zero Rust is you need a larger tip. A 1.3 is too small. I shot my ZR with at least a 1.8. I don't remember the exact size but is was a primer gun with at least a 1.8.
Re: 1970 Blues Cuda "Rejuvination" [Re: 68SportSatvert] #1044975
08/28/11 09:28 PM
08/28/11 09:28 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
OK. I'll try that too...but I thinned it down the way Resto Rick says to, and it was pretty watery and "self leveled" nicely once it was on the surface. I'll try the bigger tip when I do the next side.
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044976
09/01/11 11:49 PM
09/01/11 11:49 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Time to start in on the other side!!
Re: 1970 Blues Cuda "Rejuvination" [Re: 70Cuda383] #1044977
09/01/11 11:50 PM
09/01/11 11:50 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
some area's look better than the driver side...some area's look worse.
the outer wheel well.
Page 3 of 4 1 2 3 4
