Re: 1970 Blues Cuda "Rejuvination"
[Re: 70Cuda383]
#1044958
08/23/11 04:41 PM
08/23/11 04:41 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
hit everything with 2 coats of zero rust today. Resto Rick sells an awesome product! thinned it down a bit and it sprayed super easy. Also allowed me to test out my new HVLP guns. I've got the air set to where the literature says to...I might do some more experimenting though...air pressure just seems too low, and I don't get a lot of atomization of this paint. maybe it's too thick, maybe I need more air, not sure yet. it sprayed ok, and I wasn't too worried about it being that it's just going on the "hidden areas" but when it comes time to paint, I think I'll want a "finer" mist pattern. I was using the 1.3 tip today too. after this dries good and hard for a day or so, I'll start adding the re-popped panels back on!
**Photobucket sucks**
[Re: 70Cuda383]
#1044960
08/23/11 05:32 PM
08/23/11 05:32 PM
moparpollack
Lil Herman
Lil Herman
85086
another angle
How hard is it to remove that stuff? Looks like your window roller got a liberal dosing of it.
We had a primer that was so hard once you couldn't scratch it off with a screw driver.
[Re: moparpollack]
#1044961
08/24/11 08:43 AM
08/24/11 08:43 AM
70Cuda383
Marysville, O-H-I-O
it dries pretty hard. I wasn't too worried about the roller guide for the window. that was such a loose and sloppy fit before, that I doubt it'll block the roller from movement, and after it dries for awhile, it'll be so hard that it shouldn't gum it up.
[Re: 70Cuda383]
#1044963
08/25/11 06:00 PM
08/25/11 06:00 PM
70Cuda383
Marysville, O-H-I-O
the back corner. tucked up nicely. I was worried when trying to fit it, this area was giving me some trouble. had to move the tail panel flange in a bit, as well as the flange on the quarter to allow the edges to "tuck" together.
[Re: 70Cuda383]
#1044964
08/25/11 06:02 PM
08/25/11 06:02 PM
70Cuda383
Marysville, O-H-I-O
nice...you can see my "gobs of seam sealer" through the tail light hole....is that as good as factory? here's the upper edge. I fabricated patches for the window channel and the trunk gutter area on the deck filler piece. managed to get an acceptable seam there, I think good enough for a little filler....plus, with the lid closed...you'll never see it anyway.
[Re: 70Cuda383]
#1044965
08/25/11 06:03 PM
08/25/11 06:03 PM
70Cuda383
Marysville, O-H-I-O
another angle of the quarter seam with the trunk gutter piece. AMD for the gutter piece, goodmark quarter.
[Re: 70Cuda383]
#1044966
08/25/11 06:04 PM
08/25/11 06:04 PM
70Cuda383
Marysville, O-H-I-O
body lines look pretty good. a skim coat of filler at the door and quarter, and some block sanding, and it'll be perfect (I think!)
[Re: 70Cuda383]
#1044967
08/25/11 06:05 PM
08/25/11 06:05 PM
70Cuda383
Marysville, O-H-I-O
door seam--not the greatest job, but with some seam sealer, maybe a little filler it'll be ok I think
[Re: 70Cuda383]
#1044968
08/25/11 06:06 PM
08/25/11 06:06 PM
70Cuda383
Marysville, O-H-I-O
end result -- 100 times better than the rusty crusty panel I had before. now, to grind down the welds, add some seam sealer and get to work on the other side. it's a "quarter panel" so...I'm 25% of the way done, right?!
[Re: 70Cuda383]
#1044969
08/25/11 06:13 PM
08/25/11 06:13 PM
moparpollack
Lil Herman
Lil Herman
85086
How did the trunk lid line up? The rear valance etc? When I did the quarter on my dart I thought it looked good. Boy am I glad it fitted everything than welded.
[Re: moparpollack]
#1044970
08/25/11 09:05 PM
08/25/11 09:05 PM
70Cuda383
Marysville, O-H-I-O
trunk lid is great. I bolted it on as I was moving the panel around, then removed it again to weld the quarter.
I can't hang the valence because there's nothing left of the other side to hang it to!
the trunk floor extension/quarter panel was so rusted away and previous owner filled with bondo and sculpted it, that when I did the trunk floor, that part of the quarter panel basically fell off!
the lip to the driver side trunk extension and quarter panel is left un-welded right now (all th way up to the rear wheel well actually), in case I need to try to move them around after I get the passenger side on, to widen or narrow the gap to hang the valence.
[Re: 70Cuda383]
#1044977
09/01/11 11:50 PM
09/01/11 11:50 PM
70Cuda383
Marysville, O-H-I-O
some area's look better than the driver side...some area's look worse.
the outer wheel well.
