First 9 Second pass!!
#1043968
07/31/11 04:57 PM
07/31/11 04:57 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
I have been hovering on the 10.000000 bubble for almost a full season. I tweaked and poked around trying to sqeeze that little bit extra out, but to no avail. Finally stepped up to a pair of Hoosier radial slicks (30x10.5RX15) from a Hoosier 29.5x10.5x15 bias slick. All I can say is WOW! Ran a 9.98 at 134 with a 1.395 60'. That was with a corrected altitude of 3300' . Previous best was 10.004 with a 1.414 60'. Had tire pressure set to 20 psi! That took some getting used to! Plus the car drove so much smoother and more stable as well. All is not perfect though, as I did spin real bad a few times, but the track was pretty bad. I am still pumped over it and cant wait to go out again. Dont know if I'll go through all the hassle of licensing just yet, I've spent enough money this year!!
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
Re: First 9 Second pass!!
[Re: Dodgem]
#1043970
07/31/11 05:38 PM
07/31/11 05:38 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
That's cool. I've driven two cars with radials, a stocker and an altered and I have nothing bad to say about them. I'd put them on my car but I already have a spare set of bias plys and the ones on it now are nowhere near worn out.
I believe we ran 15 psi in the stocker and 13 in the altered.
[Re: Dave_S]
#1043973
08/01/11 02:07 AM
08/01/11 02:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
To be honest be happy with the 9 second pass BUT dont go through all the BS you need to do for it on a regular basis... for me racing was alot more fun running 10.0.............. congrats
[Re: JD Dart]
#1043975
08/01/11 04:40 AM
08/01/11 04:40 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Well done Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
