EBODY TRANS COOLER PICS NEEDED #104374
08/13/08 03:51 PM
08/13/08 03:51 PM
boogie down bronx, ny
stevenjuliano Offline OP
hi guys.....it seems silly that i have no access to my own cars to check this so i need to reach out to some of you. does anyone have photos of the inlet and outlet tubes coming off their EBODY automatic tranny cooler? the one on my latest (never ending) project has been snipped for rubber hoses so i need to figure out exactly how to repair and bend the last few inches of both lines. much appreciated! steven
rapidduster@aol.com
www.stevenjuliano.com
Re: EBODY TRANS COOLER PICS NEEDED [Re: stevenjuliano] #104375
08/13/08 05:29 PM
08/13/08 05:29 PM
cataclysm80 Offline
cataclysm80  Offline
Hi Steven
While you guys are looking... I've been curious if it's possible to install the trans cooler on a car with air conditioning, or does the condenser get in the way?
Tav
Re: EBODY TRANS COOLER PICS NEEDED [Re: cataclysm80] #104376
08/13/08 06:33 PM
08/13/08 06:33 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Here's one Steve, gives a bit of reference relative to the core support.
As I said in my reply to your email, I'll look through some prints later too...
Rick
Re: EBODY TRANS COOLER PICS NEEDED [Re: RestoRick] #104377
08/13/08 09:37 PM
08/13/08 09:37 PM
thanks rick. as soon as i get near my junk again i should have this answered. between the rj reynolds car and the 71 charger i have 2 virgin cars to look at BUT i do need to see an example out of a car. thanks again. steve
Re: EBODY TRANS COOLER PICS NEEDED [Re: stevenjuliano] #104378
08/13/08 09:57 PM
08/13/08 09:57 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Steve
Here's a crude picture of an orignal with one line tampered with a bit.
I sent you a few others via email.
Re: EBODY TRANS COOLER PICS NEEDED [Re: mccannix] #104379
08/13/08 10:03 PM
08/13/08 10:03 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
and a repro..
Re: EBODY TRANS COOLER PICS NEEDED [Re: mccannix] #104380
08/14/08 08:30 AM
08/14/08 08:30 AM
cataclysm80 Offline
cataclysm80  Offline
Who makes the repros again? Maybe they could answer my question about condensers.
I like the idea of having a factory style trans cooler, but if I can't install it properly on my car due to having AC then I'd rather not buy one just to find out. They're expensive.
Tav
Re: EBODY TRANS COOLER PICS NEEDED [Re: cataclysm80] #104381
08/14/08 02:07 PM
08/14/08 02:07 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
The E body trans cooler sits in front of the rad, the top two tabs being held in place by the rad resting against side rad supports.
The bottom brackets bolt to the lower rad support and the lines go through above the suport and beside the lower corner of the rad.
With an AC condensor in place, the cooler would not line up to be supported and the lines would be too short to reach the transmission lines.
You could put the cooler in the correct location and the condensor in front of it but you again run into mounting problems for the condensor.
Re: EBODY TRANS COOLER PICS NEEDED [Re: mccannix] #104382
08/14/08 10:15 PM
08/14/08 10:15 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
same as 71 bbody
